Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 08-28-2014, 06:55 AM   #2199
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
Send a message via ICQ to pcuerpo Send a message via Yahoo to pcuerpo
@pearlhatchiroku, afaik, there are Asian counterparts of Pioneer HUs, just look it up in the local site to get the model number, usually ad 10 or 100 lang sa US models and thats the Asian version na
2013 Toyota 86
Sterling Silver Metallic
IG: @pcuerpo.images
pcuerpo is offline   Reply With Quote
Old 08-28-2014, 10:19 PM   #2200
pearlhatchiroku
pearlhatchiroku's Avatar
Drives: pearl white eighty six
@pcuerpo thanks il look into that sir
pearlhatchiroku is offline   Reply With Quote
Old 08-28-2014, 10:25 PM   #2201
pearlhatchiroku
Originally Posted by Bongertz View Post
this is for the pioneer head units so that we can use the oem aux and usb right?
Sir this is just the assembly, the thing showed in my previous pic, but if you have that in your car no need to buy it just get the harness for you to use that aux USB thing, you can use this - Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles
Old 08-28-2014, 11:02 PM   #2202
ciotime
Drives: FR-S Lightning Red
Guys Im planning on getting 3 60mm Defi gauges for the 86...any suggestions on where to place it best?
ciotime is offline   Reply With Quote
Old 08-29-2014, 07:12 AM   #2203
pcuerpo
pcuerpo's Avatar
Drives: Toyota 86
usually sa pillars, on top of the aircon vents, or in front of the passenger just on top of the compartment
2013 Toyota 86
IG: @pcuerpo.images
Old 08-29-2014, 09:56 AM   #2204
ciotime
Thanks for the help pcuerpo...the pillars are a good option coz one can easily hide the wires...any ideas on how to hide/run the wires if placed on the top of the compartment or ac vents? Sample pics would be nice.
Old 08-29-2014, 04:04 PM   #2205
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
The problem in installing the gauges in the pillar is that it could interfere with the pillar airbag deployment. I went with the cravenspeed gauge mount and I think it's the cleanest option. It only holds two though. Look up the A.C.E. gauge mount too, it holds three gauges.
Tye300 is offline   Reply With Quote
Old 08-29-2014, 11:12 PM   #2206
pearlhatchiroku
Guys anyone have the the borla headers and experienced the rattling issue?
Old 08-29-2014, 11:13 PM   #2207
ciotime
Ive also been told that if I'm gonna be getting the Defi Racer's oil temp/pressure that I'd need to have the adaptors for the sensors? Being a newbie I'm kinda at a loss here...guess its the adaptors that'll make it compatible to our 86's. Any of you guys know the specific name of this adaptor?
Old 08-30-2014, 01:27 AM   #2208
Tye300
Tye300's Avatar
Yes. For the sensor to be installed, you need to get the OEM Subaru oil galley plug and OEM Subaru oil galley gasket. I ordered mine thru rallysportdirect. Here's the part links: https://www.rallysportdirect.com/Sub...il-Galley-Plug and https://www.rallysportdirect.com/Sub...ey-Plug-Gasket.
Old 08-30-2014, 01:28 AM   #2209
Tye300
Tye300's Avatar
I think @HRTROB had the issue a while back but I'm not sure.
The Following User Says Thank You to Tye300 For This Useful Post:
pearlhatchiroku (08-30-2014)
Old 08-30-2014, 02:36 AM   #2210
ciotime
Thanks!!! :-)
Old 08-30-2014, 04:26 AM   #2211
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yup I experienced the rattling issue. It's the flex joints. I wrapped the flex joints with header wrap and clamped them with three hose clamps each. No more rattles. No need to remove the header or lift the car. Just remove the airbox
HRTROB is offline   Reply With Quote
The Following User Says Thank You to HRTROB For This Useful Post:
Old 08-30-2014, 04:31 AM   #2212
HRTROB
HRTROB's Avatar
Drives: Toyota 86
See Tye's post about the Subaru oil gallery plug. You can mount your oil pressure sender there. For the oil temp sender, you can remove the stock oil pressure switch below the oil filter. It's the one with a single wire and spade connector. You can then mount your oil temp sensor there. That's what i did. The stock oil pressure switch is useless, by the time it lights up, it's too late.
