Old 08-26-2014, 11:38 PM   #1947
CSG Mike
CSG Mike's Avatar
Originally Posted by troek View Post
I don't have any opinion of the whiteline as I've not yet experienced it myself...
CSG Mike is online now   Reply With Quote
Old 08-27-2014, 12:58 AM   #1948
troek
troek's Avatar
Drives: 2012 Toyota 86
looks like ill have to bite the bullet on these and right a review.
troek is offline   Reply With Quote
Old 08-27-2014, 11:07 AM   #1949
Racecomp Engineering
im about to order these as well, just searching threw the forums for that last post that pushes me over the edge. im lowered about 25-30 mm on rsr springs 3.16k spring rate front. i do seem to notice the excessive dip on the front outside corner when truning hard at speed, but it may just be my imagination. ive read mikes posts where he dosnt think front control arms that adjust roll center are cost effective for the average track day goer, but now that whitline has the kit out for 200 dollars, is it worth it?
3.16k front spring rate is very very soft (177 lbs/in). There will be a lot of dip on the outside front corner.
The WL roll center kit will help, but that's still a very soft spring.
- Andy
Old 08-27-2014, 12:59 PM   #1950
jdubious
Drives: 13 Scion FR-S
Originally Posted by Calum View Post
I just checked my white line bushings that I haven't installed yet. The adjuster does bottom out in the bushing; the hole doesn't go all the way through. Hopefully you'll be able to put enough torque on the longer bolt that the tension of turning either direction wont cause it to come lose.
Thanks! the rest of that stuff I can figure out on my own.
jdubious is offline   Reply With Quote
Old 08-27-2014, 01:32 PM   #1951
fika84
fika84's Avatar
Right on! Looking forward to what you have to say.
fika84 is offline   Reply With Quote
Old 08-27-2014, 01:40 PM   #1952
ThatManAnt
Drives: Whiteout FR-S 6spd
I just got Vorshlag plates in and i wanna know if i need to take off the coilovers or can i just take off the 3 nuts holding the coil to the shock tower and just slide it on then fasten it down? Thanks
ThatManAnt is offline   Reply With Quote
Old 08-27-2014, 02:01 PM   #1953
fika84
fika84's Avatar
I really wish some smart person could relate the difference to a spring rate % increase. It would make it much easier to perceive the difference and understand approximately how much of a difference the change will make to the front roll stiffness.
This is hard for anyone to do. It all depends on what your goals are. With the suspension points measured one can relate ride height to a percent spring rate increase to maintain the _____ front roll stiffness (fill in ____ with stock, softer, stiffer) and same for rear. Then do the same thing but also take into account playing with the roll center height for different spring rates. This method would analyze this using the kinematic roll center which is useful but not as accurate as it would be with the force based roll center.
In the end it comes down to personal preference and what balance you're most comfortable with (neutral, oversteer, understeer). Without having a full tire model it would be more of a roll stiffness distribution value, instead of an actual balance value.
Also keep in mind that playing with toe and camber can have a HUGE affect on your vehicle balance in corners.
Oh so many factors
Old 08-27-2014, 02:09 PM   #1954
You'll probably want to take the coilover completely off the car.
- Andy
Old 08-27-2014, 07:34 PM   #1955
troek
troek's Avatar
- Andy
yeah, it was kind of an impulse buy because i found them on sale.
I thought id give it a shot. theyre not as bad as i thought, but maybe its because i havnt felt something better. we'll see how this does i suppose.
Old 08-27-2014, 08:26 PM   #1956
jdubious
The best way to do it is to get a set of proper rear lower control arms, and front camber plates. Everything else is a hack, literally.
Tag me in a post with @CSG Mike if you need a response; I can't watch the whole forum
I'm not 100% sold on the control arm bushings but don't want to spend the money on proper lower control arms right now.
Slotting the front struts seems like a perfectly viable option. Some cars(used to anyways) come straight off the assembly line with this exact setup. The price is right and I would think this is where you would want the adjustment to be made. Is there an advantage to adjusting at the top of the strut? Loosing a rubber upper strut mount seems like a disadvantage as well.
Old 08-27-2014, 11:13 PM   #1957
CSG Mike
CSG Mike's Avatar
You're playing with the angle of the damper when you do that... smaller angles don't have too much of a negative effect, but there's limits to the angle..
Old 08-28-2014, 02:50 PM   #1958
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Question, I've really tried to wrap my head around spending $3k+ on coilovers but I just can't afford it. I would like to run coilovers for their adjustability, allows for more room when running certain wheels, height adjustment. Most in my price range 1-$1600, are single adjust either rebound or rebound/compression and i opt for swift springs as I understand they're much better than springs that come with coils at this price range. If you had to choose between the fortune autos, feal, BC... What would you recommend. I do mostly steer driving and maybe once a month HPDE. Thanks.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-28-2014, 04:12 PM   #1959
Calum
That Guy
Drives: 2013 asphalt FRS MT
RCE T0.
Old 08-28-2014, 08:00 PM   #1960
yomny
yomny's Avatar
RCE T0.
Are they really that much better than FA, real..They're on the top range of my budget and don't even have top hats or adjustability to damping. I don't mind because i could always use the factory and adjust camber with bolts. Camber plates would should the price over the 2k with these.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
