Old 08-26-2014, 01:49 AM   #2017
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by SPCorBUST View Post
Did you up the pump?
After polling, I believe that the injectors are the bottleneck and not the in-tank pump. I have one but I don't want to hassle with the install so I'll be selling it as soon as the dyno proves it's not needed.
nlowell is offline   Reply With Quote
Old 08-26-2014, 01:51 AM   #2018
captain_jack
captain_jack's Avatar
I wouldn't imagine you will as a local guy just changed injectors and ran 18lbs of boost on e85...turbo but still comparable demand on fuel.
The Following User Says Thank You to captain_jack For This Useful Post:
nlowell (08-26-2014)
Old 08-26-2014, 03:47 PM   #2019
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
The car is "tuned" by delicious tuning, the car seemed to run pretty good but after looking at the logs he sent a revision and it seems to be worse, We may need Bill to relook at it. This was one of the first few C38's he did so he may have come a long way since then.. a different BRZ that thats turbo'd put 277 to the wheel, completely embarrassed the supercharged BRZ.. we also have injectors, pump and smaller pulley to add to the C38 now and run e85
-Thomas
86SPEED is offline   Reply With Quote
Old 08-26-2014, 07:50 PM   #2020
TmP
TmP's Avatar
Drives: A bunch of 'em...
Question: Does anyone make a nostril that can be cut into the bumper to get air into the filter?
My IATs down here in MX are ridiculous.
TmP is offline   Reply With Quote
Old 08-27-2014, 02:33 AM   #2021
CSG David
CSG David's Avatar
What's the ambient temperature in Mexico and what's your IAT right now? It wouldn't make any difference if both are the same temps.
Old 08-27-2014, 07:52 PM   #2022
TmP
TmP's Avatar
IATs got as hot as 165 F.
Ambient is closer to 110...
Old 08-27-2014, 08:35 PM   #2023
CSG David
CSG David's Avatar
While you were moving or while sitting at grid?
Old 08-27-2014, 11:41 PM   #2024
TmP
TmP's Avatar
Right after a 20 minute track session.
Old 08-28-2014, 12:12 AM   #2025
CSG David
CSG David's Avatar
IAT should be the same as ambient temperature while you're moving. If you stop, you will heat soak and the IAT will rise. Considering the KW claims it's a cold air intake, this kind of moots their point. You can just cut the bumper and put a tiny scoop to funnel the air directly to the air filter and wrap the piping with gold DEI tape like what Cem did.
Old 08-28-2014, 12:56 AM   #2026
TmP
TmP's Avatar
I know I can cut a hole, my question was, if there is a good looking solution out yet?
If there is, I'd make sure the dimensions I cut fit whatever nostril may be available
Edit: I know the 350Z has one available...
Might just try these...
http://www.ebay.com/itm/FOR-NISSAN-3...f75f2a&vxp=mtr
Old 08-28-2014, 01:11 AM   #2027
CSG David
CSG David's Avatar
Look at Ken Gushi's setup. It looks like the 350Z.
Old 08-28-2014, 01:59 AM   #2028
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I think I'm going with Seibon FA hood to deal with the engine bay heat issue. Side note Oil cooler kit ready for install. As you can see the hose are now pre-assembled and just wondering if I still need to clamp the lines. I think I'll visit my local Parker Store tomorrow.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
glamcem (08-28-2014)
Old 08-28-2014, 02:50 AM   #2029
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Are you planning to add a thermostat as well? This will be my next mod but since the season is almost over I might postpone it for a while
glamcem is offline   Reply With Quote
Old 08-28-2014, 09:34 AM   #2030
TmP
TmP's Avatar
I have a home grown oil cooler kit using the KW sandwich.
Not a big fan of their choice on placement and hoses...
The sandwich is a billet work of art though!
Need to check out Ken's car. BRB
Edit: Don't seem to find a pic of Ken's FRS with a nostril... Got a link?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
