Old 08-23-2014, 03:47 PM   #183
Brinks
Brinks's Avatar
Originally Posted by Readytoxplod View Post
lemme know if the problem is resolved. I already have a slight amount of VVT "rasp" with OFT (especially uphill) paired with a catback, and would like to know if the new design works before spending 600$
I'll post vid's once I get the new pipe in. Most likely a month from now.
Brinks is offline   Reply With Quote
Old 08-23-2014, 04:34 PM   #184
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
I encountered the "VVT rasp" with my old 2.5" over/front pipe with the old style helmholtz.
I have the new style over/front pipe. I went with the 3" which has the standard style resonator AND the new ball type helmholtz.
I can confirm that the "VVT rasp" is gone.
RiskyTrousers is offline   Reply With Quote
The Following 3 Users Say Thank You to RiskyTrousers For This Useful Post:
Account Attempt No. 4 (08-24-2014), Brinks (08-24-2014), Readytoxplod (08-24-2014)
Old 08-24-2014, 12:36 PM   #185
deliroast
Drives: 2014 SSM BRZ
I just got mine tuned after searching for a leak over the last two weeks. Gave up after new gaskets. Didn't realize it was vvt that was causing the rasp. Would I need to retune for new resonator design or am I good to go even with 3in. Are all the new fp/op on their site shipping with new style resonators?
M3 > BRZ
deliroast is offline   Reply With Quote
Old 08-24-2014, 03:32 PM   #186
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Nameless Performance Overpipe/Downpipe Combo
So the new 3" has the ball style helmholtz? I thought only the 2.5" had them and the 3" had a regular long tube resonator? Either way is good to know the rasp is gone.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Jrdad (08-24-2014)
Old 08-24-2014, 06:49 PM   #187
RiskyTrousers
The 3" I have has both.
Old 08-24-2014, 07:15 PM   #188
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Does the EL header you're running have a catalytic converter?
My setup is the FA20club EL Header with primary cat, Perrin Overpipe, Nameless Catted Front Pipe with older style Helmholtz resonator, stock exhaust, Perrin Tips. Running OFT 2.0 EL Header 93 octane tune, MAF rescaled
No drone and just a hint of "buzz" from 4000-4800 rpm's during wide open throttle only
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-24-2014, 09:07 PM   #189
yomny
yomny's Avatar
Does it have a cat? That's weird, its got two resonators? Oh well, as long as it does the job.
Old 08-24-2014, 10:27 PM   #190
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Thanks for the reply, any reason why you went with a 3" when you have a 2.5 exhaust?
Readytoxplod is offline   Reply With Quote
Old 08-25-2014, 02:15 PM   #191
RiskyTrousers
To better match the 3" header collector. The front pipe does taper down to 2.5" at the cat-back flange. As a bonus, this actually fit better than the 2.5" and has a deeper exhaust note.
The Following User Says Thank You to RiskyTrousers For This Useful Post:
Rosticles (08-26-2014)
Old 08-25-2014, 02:30 PM   #192
deliroast
Making me want to switch over. All new op/fp have ball resonator even though it doesn't show it right?
M3 > BRZ
Old 08-25-2014, 07:41 PM   #193
Brinks
Brinks's Avatar
I was told all the new orders of downpipes were getting the new design, they just haven't had a chance to update there photos. I would specify you specifically want the new design in the purchase notes just to be safe.
Old 08-26-2014, 01:17 PM   #194
RiskyTrousers
It's the Nameless header so it's catless.
Yeah, 2 resonators and a high-flow cat.
Here's a pic.
ofuts (11-23-2014), Rosticles (08-26-2014), yomny (08-26-2014)
Old 08-26-2014, 06:35 PM   #195
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Here's a pic.
So it's a straight through resonator and the ball one. What are you running after the downpipe? I see a flex joint. Also have sound clips?
I wanted to go that route but was worried about noise level and cost as I already have the 2.5" dp and 3" axleback.
Mad_Mike is offline   Reply With Quote
Old 08-26-2014, 07:28 PM   #196
Studabaker340
Thank you for adding the pictures! It is a great help.
Studabaker340 is offline   Reply With Quote
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 05:57 PM
Vitamin R from Nameless Performance. Jason@Nameless BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-22-2012 12:27 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-19-2012 12:32 AM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 05:32 AM
