Old 08-18-2014, 08:06 PM   #5209
whataboutbob
AutoX-10/10ths every run
Originally Posted by michael_king View Post
Thanks-
I'm assuming it to be tune related so I'm going to switch to their custom tune where I can at least get support if the problem persists. I understand raising the idle setting may help, @whataboutbob said his is set to like 1100 rpm on his custom tune.
-mk
No, I said like 850-900
Build thread:Here
Old 08-18-2014, 08:10 PM   #5210
michael_king
Drives:
@whataboutbob haha thanks. It appears the CARB tune is set at about 600 from
michael_king is offline   Reply With Quote
Old 08-18-2014, 09:07 PM   #5211
TONYpepperon1
TONYpepperon1's Avatar
Drives: 2013 CBS BRZ
Do you think this kit can safely approach 270whp on 93 pump gas?
TONYpepperon1 is offline   Reply With Quote
Old 08-18-2014, 10:55 PM   #5212
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I don't think it has the capability to reach those numbers on pump gas.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
DeliciousTuning (08-18-2014)
Old 08-18-2014, 11:26 PM   #5213
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Here is something you guys might get a kick out of. I believe this is the first forced induction Toyota 86 the Top Gear crew was able take for a spin. Just thought you Twin Screw owners would like to know "The Stig" loved it...
Here is a little more on the story along with more photos.
Top Gear, The Stig, RMS Innovations and Delicious Tuning
Cheers,
William Knose
P.S. It is a Twin Screw 210+ Supercharger Kit.
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
civicdrivr (08-19-2014), MidnightRunner (11-03-2014), TemeCal (08-19-2014)
Old 08-19-2014, 02:26 AM   #5214
sam69
Drives: GT 86
Would running a slightly heavier oil help with blow by as have noticed that this is a bit of an issue and are still running 0w 20.
Have ordered a catch can and waiting for that but would like some advice on if a 0w30 or 5w30 would slow the oil use down a bit.
Any first hand experience would be appreciated and maybe William could chime in.
sam69 is offline   Reply With Quote
The Following User Says Thank You to sam69 For This Useful Post:
CK_Bladesmith (08-19-2014)
Old 08-19-2014, 10:18 PM   #5215
TONYpepperon1
Well what about 250 whp? Even with 93, intercooler and 69mm pulley?
Old 08-19-2014, 11:00 PM   #5216
DeliciousTuning
Those numbers are definitely reachable on 93 octane with those parts. We have done it on 91 octane. We are making about 220 on a Mustang Dyno which baselines as 153 on a stock BRZ. This would equate to about ~257 on a DynoJet. So yes very doable.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
TONYpepperon1 (08-26-2014)
Old 08-19-2014, 11:04 PM   #5217
Dustin
Twin Screw You
Dustin's Avatar
With the right supporting mods and under the right conditions you could hit 250 depending on the dyno.
Old 08-20-2014, 09:06 PM   #5218
TONYpepperon1
Cheers,
William Knose
That's def good news. I had some more questions about your OTS tune that comes with the kit. How does this tune account for varying modifications across different twins if it's the same for everyone? Would you always recommend a custom dyno tune at some point? And lastly, can a custom tune provide higher numbers then the ones you just listed or is this the max the blower can handle.
Old 08-26-2014, 01:50 AM   #5219
DeliciousTuning
You shouldn't need a custom tune if you stick with the standard setups that are within spec of what our tune encompasses.
A custom tune could provide higher numbers when running a full exhaust system but we have designed the kit around a stock configuration to be versatile.
The tune itself accounts for small variances via the MAF sensor. Though there are minor differences between setups, they are very consistent from vehicle to vehicle.
Cheers,
William Knose
Old 08-26-2014, 03:12 AM   #5220
8686
8686's Avatar
Drives: 86
Cheers,
William Knose
I remimber that the complete tune kit comes with two free revisions.
based on your experince, Do I need more than that to get the maximum out of my headers and exhaust with Innovate SC.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 08-26-2014, 11:38 AM   #5221
choi0706
Drives: t
speaking of squeaks, anyone else have a really short squeak (less than 5sec) only at start up and at the idle dip?
choi0706 is offline   Reply With Quote
Old 08-26-2014, 12:01 PM   #5222
TemeCal
Drives: 86
When my engine is cold (sitting for >4hrs), and I start it...it'll squeak shortly. It goes away within 30sec(?), or once I start driving. It sounds like it's coming from the alternator pulley, but I could be wrong.
Initially, I thought it was the idler pulley so I replaced that. No luck. Others speculated that it could be the "blue" gates belt I installed. I haven't tried going back to the standard "black" belt, so I can't confirm if this works.
TemeCal is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
