alpine, ATL BRZ, CSG David, CSG Mike, DaDr00, Dave-ROR, Dezoris, Frs300, ftc~brz, FullBlown, glamcem, gramicci101, husker741, jamesm, JasperNoone, King Tut, Luis_GT, Marchy, nelsmar, OrbitalEllipses, phastafrican, raul, Reaper, sklimo, SmsAlSuwaidi
Old 08-25-2014, 03:53 PM   #1
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thumbs up King Tut's Time Attack Build
It says member's car journals. It doesn't say it has to be a BRZ/FR-S.
This is for my new to me 2006 Honda S2000 in stunning Laguna Blue Pearl. I ended up buying it two days after my Laguna Seca Blue E92 M3 sold. I had been searching for months while waiting for the right buyer to come along for the M3, and as soon as it was gone I made my decision. I ended up with this 2006 model with 102,000 miles on the clock for $17,000. It was all stock other than the powder coated OEM AP2 V2 wheels and a set of Ground Control coilovers on OEM struts. The previous owner was the owner of a Honda performance shop in the Tampa/St. Pete area called LHT Performance. He had only had it for a short time and decided that driving a small S2000 was too uncomfortable for his taller frame. In that time he put on a brand new OEM Honda soft top, new clutch, new flywheel, new starter, new primary O2 sensor, and new Potenza tires. This was the lowest priced Laguna Blue S2000 I had found, and it seemed to have been really well cared for considering the mileage. The prices on these were all over the place from $30k for one with 4k miles to $25k for one with 25k miles.
The plan from the time I decided to sell my M3 was to make a full out time attack / NASA time trials car that I can still drive on the streets occasionally. I had considered doing an air cooled Porsche, but they don't really seem to be competitive and are more just for DE weekends. The choice then came down to another BRZ or an S2000. I found some decent deals on the BRZs with relatively low mileage 2013 Limiteds listing for as low as $21k. In the end though I had already built one of those, and I was still not 100% sure the aftermarket support was there to have one survive the kind of track driving I intend on doing.
As you will notice, the car has a Forbidden USA Double Sided 1x1 Carbon Fiber Mugen Replica Hard Top installed. I had wanted this exact hard top since before I purchased the car, and through the S2ki classifieds I happened to find a nearly brand new one for sale locally in Fort Walton Beach, so I snagged it as my first and only modification thus far. The plans include a turbo kit, V mount radiator/intercooler setup, big wing, front splitter, a high end coilover setup, 17x9s mounted with 245 width Hoosier A7s, and the Essex AP Racing front brake kit just to mention some of the bigger items.
The goal will be running in the NASA Time Trials TT3 class which is the lowest of the three weight to horsepower classes where you still have to take a penalty for non OEM aero. I also have to take a penalty for the Mugen replica hard top as it modified the "OEM roofline", but I plan to run around 315 whp at 3000 lbs with me in the car. The plan with the turbo kit is to have it make max boost and that 315 whp at as low an RPM as I can and then use timing/boost level manipulation to keep a flat horsepower curve all the way to 8000 RPM to fully maximize the horsepower limitation. I may later up the power and move up to TT2 as well in the future if the 245s can handle the additional power.
I hope to keep this car for quite a long time as I build it and track it. Now for what everyone has been waiting for, the pictures. As always, comments and questions are more than welcome.
Engine / Performance Modifications:
HKS Hi-Power Single 75mm Exhaust
Hondata FlashPro
Full Blown 270 Fuel Pump
Wheel / Suspension / Brake Modifications:
WedsSport TC105N 17x9 +49 Dark Blue Metallic Wheels (Square)
Michelin Pilot Super Sport 245/40/17 Tires (Square)
949 Racing Hub Centering Rings (Track)
WedsSport TC105N Center Caps (Street)
Ohlins Road and Track DFV Coilovers
J's Racing S2 Camber Joints
Stoptech Trophy STR40 Front Big Brake Kit
Stoptech/Centric Premium OEM Rear Rotors
Stoptech SS Brake Lines
PFC08 STR40 Caliper Front Pads (Track)
PFC97 OEM Rear Pads (Track)
Stoptech Street Performance Pads (Street)
Motul RBF 600 DOT 4 Racing Brake Fluid
Vorshlag 17mm Hex M12-1.5 Black Lug Nuts
Interior Modifications:
Hard Dog Double Diagonal Roll Bar
Exterior Modifications:
Forbidden USA Mugen Replica Double CF Hardtop
APR GT-250 67" Wide Carbon Fiber Wing (S2000 specific mount)
Rockstar Garage Front and Rear Hardtop Brackets
Sparco Tow Straps Front and Rear
Future Modifications:
PTUNING GTX3076R Turbo Kit & Oil Cooler
PTUNING Oil Distribution Block
Injector Dynamics 1000cc Fuel Injectors
Honda OEM AP1 Flywheel, Clutch Disk, and Bearings
ACT H021 Pressure Plate
Hyperco 700 lb Front and 600 lb Rear Springs
Eibach Adjustable Front and Rear Sway Bars
Anorexicpoodle Front and Rear Adj End Links
AMB Tranx 260 Transponder Direct Power
AEM Failsafe Boost/AFR Gauge
Innovate Oil Pressure/Temp Gauge
Autometer Dual Gauge Pod
McMaster-Carr Vacuum Block
Summit Racing Catch Can
Pictures:
The Following 23 Users Say Thank You to King Tut For This Useful Post:
akahenry (09-10-2014), Ammonia (09-03-2014), ATL BRZ (08-25-2014), civicdrivr (08-28-2014), Creole (08-26-2014), CSG Mike (08-25-2014), dattran86 (05-19-2017), Draco_PR23 (08-25-2014), drewbot (10-11-2014), Figo (06-15-2015), flippy (01-15-2016), ftc~brz (08-25-2014), glamcem (08-25-2014), Jive Turkey (09-08-2014), Marchy (08-25-2014), MooseWRX (09-09-2014), phastafrican (08-25-2014), PineappleFriedRice (08-25-2014), Sideways&Smiling (03-30-2015), sklimo (08-25-2014), Sportsguy83 (08-25-2014), Turbowned (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 03:58 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
HOREEEEE F*CKKKK I love it!!!!
The Following 10 Users Say Thank You to Sportsguy83 For This Useful Post:
cdrazic93 (11-28-2014), Creole (08-26-2014), fstlane (08-26-2014), ftc~brz (08-25-2014), King Tut (08-25-2014), mit_peid (03-18-2015), phastafrican (08-25-2014), SkAsphalt (08-25-2014), sklimo (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:01 PM   #3
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Love the hard top. Beautiful car
fantah is offline   Reply With Quote
The Following 4 Users Say Thank You to fantah For This Useful Post:
ftc~brz (08-25-2014), King Tut (08-25-2014), MooseWRX (09-09-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:03 PM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@alpine
@sklimo
@phastafrican
@sklimo
@ftc~brz
@ATL BRZ
@Reaper
@SmsAlSuwaidi
@jamesm
@OrbitalEllipses
@whitefrs
@JasperNoone
@CSG David
@CSG Mike
The Following 6 Users Say Thank You to King Tut For This Useful Post:
ATL BRZ (08-25-2014), CSG Mike (08-25-2014), ftc~brz (08-25-2014), sklimo (08-25-2014), Sportsguy83 (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:05 PM   #5
ftc~brz
Done
Drives: WRB BRZ
Tags errrywhere lol majority banned lmao
ftc~brz is offline   Reply With Quote
The Following 3 Users Say Thank You to ftc~brz For This Useful Post:
cdrazic93 (11-28-2014), sklimo (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:15 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
NEVER FORGET
cdrazic93 (11-28-2014), CSG Mike (08-25-2014), ftc~brz (08-25-2014), sklimo (08-25-2014), Sportsguy83 (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:15 PM   #7
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
engine bay looks more like its done 10,000 miles! nice buy
Canehda is offline   Reply With Quote
The Following 4 Users Say Thank You to Canehda For This Useful Post:
ftc~brz (08-25-2014), King Tut (08-25-2014), rosol16 (12-13-2015), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:19 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah the fact that the previous owner had done all the maintenance at a local Honda dealer and the car came with tons of maintenance just performed as well such as new spark plugs, oil change, transmission fluid change, diff fluid change, and a valve adjustment. It drives great for a 100,000 mile car, and I have no fears of turbocharging a high milage Honda. I will probably run it near 400 whp on 93 octane on the street.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
Canehda (08-25-2014), ftc~brz (08-25-2014), Sportsguy83 (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:22 PM   #9
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Thanks for the mention, ass hat.
husker741 is offline   Reply With Quote
The Following 4 Users Say Thank You to husker741 For This Useful Post:
CSG Mike (08-25-2014), ftc~brz (08-25-2014), sklimo (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:24 PM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You sexy mitch you. Car looks great. Look forward to checking out another wonderful honda build (My friend is building a Civic Type R over in the UK..mmmm type r)
The Following 3 Users Say Thank You to SkAsphalt For This Useful Post:
ftc~brz (08-25-2014), King Tut (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:24 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Thread tags for all bro. David tagged me in my own thread, haha.
ftc~brz (08-25-2014), husker741 (08-25-2014), sklimo (08-25-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:42 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
Dat airbox tho
twin turbo?
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 08-25-2014, 04:44 PM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Dat airbox tho
twin turbo?
Dat engine placed so far back in chassis for dat front/mid engine configuration. Just leaves more room for the V mount setup. Single turbo, most likely GTX3076R and possibly twin scroll.
CSG Mike (08-25-2014), ftc~brz (08-25-2014), sklimo (08-26-2014), ZionsWrath (08-25-2014)
Old 08-25-2014, 04:50 PM   #14
CSG David
CSG David's Avatar
Hmmm...you better win.
honda, king tut, nasa, s2000, time attack
Robispec TIME ATTACK Build robispec Tracking / Autocross / HPDE / Drifting 254 11-18-2014 04:27 AM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 08:01 PM
AJ BRZ at Global Time Attack ! AJ PwR Tracking / Autocross / HPDE / Drifting 5 11-26-2013 10:33 PM
One Bad MoFo Time Attack FRS! Element Tuning BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-13-2013 09:27 PM
My FR-S In Time Attack Mode!! track_warrior FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 09-25-2012 02:13 AM
