Old 04-05-2014, 05:47 PM   #57
D88
D88's Avatar
Drives: 2014 Scion FRS
Really sweet ride! It gives a throwback vibe to the original F&F Eclipse!
D88 is offline   Reply With Quote
The Following User Says Thank You to D88 For This Useful Post:
Ironsquid (04-07-2014)
Old 04-07-2014, 03:18 PM   #58
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by Brody602 View Post
@Ironsquid at what rpm is the turbo spooling and what rpm does it reach peak?
@jamesm
James has the log from this past weekend
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
Brody602 (04-17-2014)
Old 04-07-2014, 03:20 PM   #59
jamesm
it depends on what boost you're targeting. it hits 10psi by around 4500rpm. higher boost targets take a bit longer, lower boost targets reach peak a bit sooner of course.
Note that this only tells 1/3 of the story though. Driving around the 35r is as responsive (or more so) than a 60-trim.
The Following User Says Thank You to jamesm For This Useful Post:
Old 08-20-2014, 05:09 PM   #60
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Haven't posted in a while..
New Varis bumper is wrapped and installed. Fitment was a little rough but the sledge hammer made it easy. Had some issues with the wrap on one of the side skirts, so no photos yet. Front bumper is getting gelcoat blacked in the grill area before I wrap that, maybe 1-2 weeks.
charged86 (12-01-2014)
Old 08-20-2014, 05:11 PM   #61
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Flex Fuel has been installed as well, dyno numbers soonish.
May need more parts, bigger fuel pump ( @FullBlown ) and aftermarket crash bar for the rear (varis kit doesnt fit with stock rear crash bar fyi)
Old 08-20-2014, 05:14 PM   #62
Redlinedfrs86
Redlinedfrs86's Avatar
Drives: 2013 Firestorm FR-S
amazing ! I have only seen your car once in Orlando
Redlinedfrs86 is offline   Reply With Quote
The Following User Says Thank You to Redlinedfrs86 For This Useful Post:
Ironsquid (08-20-2014)
Old 08-20-2014, 05:22 PM   #63
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Oh forgot about the brembo brake install. We used '11 subie brembos, painted them black, applied kiwi green brembo vinyl and cleared over top. DBA 5k rotors in front, 4k in rear. SS stoptech lines, dot600 fluid. Also new RS3's
Old 08-20-2014, 05:28 PM   #64
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Dont have any pics of the new rear suspension.
Long story short we had fitment issues with our wheel offset and 265 wide tires. The only option we had in order to keep the wheel/tire combo was lots of negative camber up top, and then correct the camber on the bottom. We also had wheel hop issues last track event as well so we put in some adjustable trailing arms. We also bought adjustable toe arms in the rear as well.
We picked up the rear diff brace and mount brace kit also for some stiffness.
Old 08-24-2014, 07:19 PM   #65
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Update from the track:
Ran a best of 12.5 @ 121mph
@FullBlown
Old 08-25-2014, 12:32 PM   #66
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
@FullBlown
60 foot? RS3 street tires?
Old 08-25-2014, 12:36 PM   #67
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
street tires, 2.2 60'
The track was pretty well prepped, one of the 86s had already broken an axle, so I was afraid to launch any faster than 2.2
I was more interested in the mph
Old 09-08-2014, 12:21 PM   #68
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
AutoX from last weekend. Shot from toe hook gopro.
[ame]http://youtu.be/UB6DtgdRLpg[/ame]
@FullBlown
Sportsguy83 (09-08-2014)
Old 12-01-2014, 12:16 PM   #69
charged86
charged86's Avatar
what braces did you use? i only have adjustable trailing arms so far on 245's
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 12-02-2014, 10:44 AM   #70
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Beatrush
carbon, fullblown, green, turbo, vinyl
DashCommand, PLX Kiwi 2 WiFi & Pioneer AppRadio Alfalasy Electronics | Audio | NAV | Infotainment 7 09-12-2013 02:50 AM
Green light for Nissan GTR R36 Giccin Other Vehicles & General Automotive Discussions 39 06-05-2013 02:48 PM
Neon Green meeskee2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-15-2013 08:56 PM
Would FB Green or Red fit any existing kit? HighLife Forced Induction 17 01-04-2013 06:18 PM
CBS FRS at Green Toyota Integratedfool Great Lakes 0 06-25-2012 01:24 PM
