Old 08-22-2014, 08:30 PM   #1835
CSG Mike
CSG Mike's Avatar
Originally Posted by BRZ NA View Post
How much? $300?
They're $699 MSRP, but PM me if you're interested.
Old 08-22-2014, 08:39 PM   #1836
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Originally Posted by Model Citizen View Post
this was fun,
lol an unsettled car, takeoffs that were driving terrible and lift off oversteer
That was actually pretty awesome. At least you kept it out of the wall. :-)
Your "who me?" recovery reminds me of one of my cats on the rare occasion I catch them falling or otherwise looking ungraceful. Well played!
DJ
Sirsimon is offline   Reply With Quote
Old 08-23-2014, 07:20 AM   #1837
ZionsWrath
Thanks
ZionsWrath's Avatar
oil change interval? I have 5000 miles and 5 HPDE on my motul 300v.
Have 5 days scheduled for the rest of the year and probably will add about 3000 miles.
Old 08-23-2014, 11:11 AM   #1838
BRZ NA
Drives: WR blue
Wow for a timer?um... thx but too much for me
BRZ NA is offline   Reply With Quote
Old 08-23-2014, 11:56 AM   #1839
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Got a track related question? I'll try to answer.
I change mine after every HPDE which during the season is ~once per month. Might be overkill but better for the engine.
nlowell is offline   Reply With Quote
Old 08-23-2014, 12:03 PM   #1840
CSG Mike
CSG Mike's Avatar
AMB transponders run in the 400 range... as does the AIM Solo (non-DL).
Old 08-26-2014, 10:57 AM   #1841
gramicci101
Off Topic
Here's a good example of why wheel-to-wheel racing is best.
Old 08-26-2014, 12:32 PM   #1842
Darnold
Darnold's Avatar
Drives: 04' 400whp S2000, 01' DD S2000
Back in '13 you answered S2K vs BRZ, would you still do the same?
I have two S2Ks currently and am looking to get into a bit of road course work. Unfortunately my project 04 is over built for my driving ability and my01 has 130k miles and i'd prefer to either upgrade to a new CR for a daily or a BRZ limited. Looking to get some input as you made this reference in the past!
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car)
Darnold is offline   Reply With Quote
Old 09-02-2014, 06:38 PM   #1843
troek
troek's Avatar
Drives: 2012 Toyota 86
I did a little road trip up to sportsland yamanashi this weekend, and on the slow, almost 1st gear hairpins i was getting severe understeer(hankook v12s roughly -2 camber). To get around the corners i was playing the throttle right after turn in to get the car to rotate, but i felt this was robbing alot of speed. other than car set up, such as more camber, better tires etc, what would some driving techniques be to fix this? High speed corners understeer isnt as much of an issue and im usually on throttle more. Maybe im not trail-braking properly?
troek is offline   Reply With Quote
Old 09-02-2014, 07:09 PM   #1844
CSG Mike
CSG Mike's Avatar
Using shark throttle inputs to induce rotation is a perfectly valid technique, and I do it all the time!
Try -3 camber in the front; leave the rear alone.
Old 09-02-2014, 07:13 PM   #1845
gramicci101
Off Topic
Is a shark throttle part of an ECU tune, or a new piece of hardware?
Old 09-02-2014, 07:17 PM   #1846
CSG Mike
CSG Mike's Avatar
super secret CSG mod
That should be sharp.... typo
Old 09-02-2014, 07:18 PM   #1847
troek
troek's Avatar
Ok well other than im sure i need to refine the technique, it sounds like im on the right track. As for camber im pretty much maxed out until i can afford camber plates(running the dreaded double camber bolt setup now). I may look into slotting the upper hole in my strut when i have some more free time.
Old 09-02-2014, 07:46 PM   #1848
kavanagh
Fat on Corn Syrup
That brings up a good question for me.
Is it 'better' in this car to gain camber at the knuckles or plates? I have one crash bolt only at this point in the top knuckle holes, and I'm deciding on what path to take for more negative front camber.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
