Old 08-22-2014, 03:48 AM   #2143
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
Umm... So i think I'm the first to have the welds crack on my header? :/
started hearing an exhaust leak that was really annoying that progressively got worse in the past month. Went under the car and bam. Sad boy todayyy
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline
Old 08-22-2014, 05:21 AM   #2144
chas3wba0
chas3wba0's Avatar
Drives: Yes
Damn it, Bad Luck Brian T_T
Which weld... got pics?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
Old 08-22-2014, 10:55 AM   #2145
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Sorry if this is gonna offend anyone, but the entire situation with ft86 and these headers rub me the wrong way.
I want to get it on a dyno.
-Jack Burton
tahdizzle is offline
Old 08-22-2014, 11:23 AM   #2146
SCharged
Drives: asphalt fr-s
I sure hope no one ever gets offended with what they read on this forum.. and especially that your asking a legit question... FT86SF have provided some answers on that front if your talking new design vs old design.. basically saying it was 3d scanned and is identical.
Lets just hope the weld failure is an isolated case... any detail to the wear its seen?? lot of tracking maybe? still not an excuse, but more flex would certainly put more strain on the headers.. what other parts is it combined with?
SCharged is offline
Old 08-22-2014, 11:26 AM   #2147
tahdizzle
So elite I'm 1338
3d scan will show that its identical in dimension, but not in air flow and harmonics.
I still don't believe going from a weld to a bend didn't change those factors.
-Jack Burton
Old 08-22-2014, 11:32 AM   #2148
SCharged
3d scan will show that its identical in dimension, but not in air flow and resonance.
Maybe so, I dont know much about 3d scanning. but if dimensions are the same at all point of a 3d model and materials are unchanged... interior of piping should also be identical.
SCharged is offline
Old 08-22-2014, 11:33 AM   #2149
tahdizzle
So elite I'm 1338
Materials have changed, or at least the amount, density and location of materials.
-Jack Burton
Old 08-22-2014, 12:58 PM   #2150
Trettiosjuan
Drives: GT86
With all those welds on the original, how come you trusted so much more that every header produced before the change were identical for flow with all those pipe joints?
As I understand it, bends are identical, there are just less welds on the straight parts. If anything, less welds means less pipe joints where the flow can vary and thus better (more consistent) quality for us, the customer.
Until proven otherwise, or, until even remote actual indications exist that performance has changed, I think it is safe to exhale and.... relax
Trettiosjuan is offline
Old 08-22-2014, 01:06 PM   #2151
tahdizzle
So elite I'm 1338
So you agree that the flow can be different? and you are assuming that it is an improvement.
The entire reason I chose an ft86 UEL header was ability to remove the torque dip w/o a tune.
That being said. There has not been any data showing information on the new headers; from FT86 or a 3rd party.
I did give them the benefit of the doubt, but after installing the header I am not convinced it has the same graph.
That being said. when I originally purchased the header, I did so based on the information given.
When a retailer shows you data on a product and you purchase the product based on that data. Then the seller changes the product and assures you that its the same product w/o any data to reinforce their claims. It is due diligence to be skeptical.
I don't have the blind faith you have.
-Jack Burton
Old 08-22-2014, 01:20 PM   #2152
Trettiosjuan
Drives: GT86
Not in that way. For every pipe joint, there can be a minimal variance in flow. Remember, variance includes a perfect joint, as if no weld was there.
So original product = More joints = wider variance between each header delivered.
Modified product = Less joints = less variance between each header delivered = better quality
What I am saying is that if you trusted the original product offering, you can also trust the modified one. Trust me, I'm an engineer
Old 08-22-2014, 01:22 PM   #2153
Tylub
Tylub's Avatar
here you go
instagram @Tylub
Tylub is offline
The Following 3 Users Say Thank You to Tylub For This Useful Post:
chas3wba0 (08-22-2014), DarkSunrise (08-22-2014), sato (08-22-2014)
Old 08-22-2014, 01:29 PM   #2154
tahdizzle
So elite I'm 1338
I am not speaking about build quality...
Air flow and harmonics are affected. So is it reasonable to say the dyno graph has changed since the new design?
The only way to be sure is to get a dyno graph of the installed header. Which I will have to do. I really don't want to put it on a dyno because I don't trust that it has the same graph as what I was sold. But it definetly feels like the graph has changed.
-Jack Burton
Old 08-22-2014, 01:31 PM   #2155
chas3wba0
chas3wba0's Avatar
Drives: Yes
here you go
Ooooh that's nasty... Hope ft86sf takes care of you man.
The Following User Says Thank You to chas3wba0 For This Useful Post:
Tylub (08-22-2014)
Old 08-22-2014, 01:40 PM   #2156
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
here you go
Well that's what their warranty is for!
husker741 is offline
The Following 2 Users Say Thank You to husker741 For This Useful Post:
FT-86 SpeedFactory (08-22-2014), Tylub (08-22-2014)
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
