#2143 |
Drives: Raven Black FR-S
Umm... So i think I'm the first to have the welds crack on my header? :/
started hearing an exhaust leak that was really annoying that progressively got worse in the past month. Went under the car and bam. Sad boy todayyy
#2144 |
Drives: Yes
Damn it, Bad Luck Brian T_T
Which weld... got pics?
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#2145 |
So elite I'm 1338
Drives: WRB Subaru BRZ
Sorry if this is gonna offend anyone, but the entire situation with ft86 and these headers rub me the wrong way.
I want to get it on a dyno.
-Jack Burton |
#2146 | |
Drives: asphalt fr-s
Lets just hope the weld failure is an isolated case... any detail to the wear its seen?? lot of tracking maybe? still not an excuse, but more flex would certainly put more strain on the headers.. what other parts is it combined with? |
#2147 | |
So elite I'm 1338
3d scan will show that its identical in dimension, but not in air flow and harmonics. I still don't believe going from a weld to a bend didn't change those factors.
-Jack Burton |
#2148 | |
Maybe so, I dont know much about 3d scanning. but if dimensions are the same at all point of a 3d model and materials are unchanged... interior of piping should also be identical. |
#2149 | |
So elite I'm 1338
Materials have changed, or at least the amount, density and location of materials.
-Jack Burton |
#2150 | |
Drives: GT86
As I understand it, bends are identical, there are just less welds on the straight parts. If anything, less welds means less pipe joints where the flow can vary and thus better (more consistent) quality for us, the customer. Until proven otherwise, or, until even remote actual indications exist that performance has changed, I think it is safe to exhale and.... relax
#2151 | |
So elite I'm 1338
So you agree that the flow can be different? and you are assuming that it is an improvement. The entire reason I chose an ft86 UEL header was ability to remove the torque dip w/o a tune. That being said. There has not been any data showing information on the new headers; from FT86 or a 3rd party. I did give them the benefit of the doubt, but after installing the header I am not convinced it has the same graph. That being said. when I originally purchased the header, I did so based on the information given. When a retailer shows you data on a product and you purchase the product based on that data. Then the seller changes the product and assures you that its the same product w/o any data to reinforce their claims. It is due diligence to be skeptical. I don't have the blind faith you have.
-Jack Burton |
#2152 | |
Drives: GT86
So original product = More joints = wider variance between each header delivered. Modified product = Less joints = less variance between each header delivered = better quality What I am saying is that if you trusted the original product offering, you can also trust the modified one. Trust me, I'm an engineer
#2153 |
here you go
| The Following 3 Users Say Thank You to Tylub For This Useful Post: |
#2154 | |
So elite I'm 1338
I am not speaking about build quality... Air flow and harmonics are affected. So is it reasonable to say the dyno graph has changed since the new design? The only way to be sure is to get a dyno graph of the installed header. Which I will have to do. I really don't want to put it on a dyno because I don't trust that it has the same graph as what I was sold. But it definetly feels like the graph has changed.
-Jack Burton |
#2155 |
Drives: Yes
Ooooh that's nasty... Hope ft86sf takes care of you man.
| The Following User Says Thank You to chas3wba0 For This Useful Post: | Tylub (08-22-2014) |
#2156 |
Drives: 2013 Whiteout Scion FR-S 6MT
| The Following 2 Users Say Thank You to husker741 For This Useful Post: | FT-86 SpeedFactory (08-22-2014), Tylub (08-22-2014) |
| Tags |
| catted uel header, ft86speedfactory header, is my order ready yet? |
| Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 107 | 03-29-2016 10:48 AM |
| catted header or catted front pipe? | gabeg86 | Engine, Exhaust, Transmission | 28 | 10-13-2015 12:32 PM |
| P&l EL catted and coated header. | wootwoot | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2013 12:50 AM |
| Catted UEL Header | Cjymiller | Engine, Exhaust, Transmission | 20 | 05-24-2013 12:01 PM |
| ***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 12 | 10-24-2012 10:12 PM |
