Old 08-21-2014, 04:17 PM   #1
richpow
Drives: Soon to be an FRS owner
I'm new to turbo kits, and need help deciding what else to get in addition to a kit.
Hey everyone, I'm new here and will be purchasing an frs in the next month or so. I have been looking into getting the Greddy turbo kit, but I would like to know what else, other than the kit, I should purchase so that I can properly get the most out of the kit. What I mean is, what other than the kit should I be purchasing to get this car to about 300whp?
richpow is offline   Reply With Quote
Old 08-21-2014, 04:20 PM   #2
ftc~brz
Done
Drives: WRB BRZ
you need to start here:
http://www.ft86club.com/forums/forumdisplay.php?f=78
ftc~brz is offline   Reply With Quote
The Following 2 Users Say Thank You to ftc~brz For This Useful Post:
cdrazic93 (08-21-2014), sklimo (08-21-2014)
Old 08-21-2014, 04:25 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
lol^ specifically look in the stickies. There's a thread about pricing out kits and components.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
ftc~brz (08-21-2014), sklimo (08-21-2014)
Old 08-21-2014, 04:27 PM   #4
ftc~brz
Done
Drives: WRB BRZ
^shhhhhh don't give away all the secrets now.....
The Following User Says Thank You to ftc~brz For This Useful Post:
sklimo (08-21-2014)
Old 08-21-2014, 04:28 PM   #5
BadBRZ
Drives: Subaru
In the order;
Kit
Tune
Oil cooler
Injectors+pump
Clutch
Over pipe
Mid pipe
Exhaust
Motor mounts
Flex fuel kit
Coil overs
Rims+tires
Built motor
M85 rear end
V160swap
Unicorn semen
BadBRZ is offline   Reply With Quote
Old 08-21-2014, 04:29 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
FA20Club has some good turbo kit dynos if you'd search for them you'd find some...is that better @ftc~brz? Lol
Old 08-21-2014, 04:31 PM   #7
ftc~brz
Done
Drives: WRB BRZ
YESSSSSSS....
lmmfao
sklimo (08-21-2014)
Old 08-21-2014, 04:32 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by BadBRZ View Post
In the order;
Kit
Tune
Oil cooler
Injectors+pump
Clutch
Over pipe
Mid pipe
Exhaust
Motor mounts
Flex fuel kit
Coil overs
Rims+tires
Built motor
M85 rear end
V160swap
Unicorn semen
Gauges...custom driveshaft to hook up that V160...accusump...you forgot a few
Although I guess that unicorn semen could be traded for some of those items.
Old 08-21-2014, 04:33 PM   #9
ftc~brz
Done
Drives: WRB BRZ
In the order;
Kit
Tune
Oil cooler
Injectors+pump
Clutch
Over pipe
Mid pipe
Exhaust
Motor mounts
Flex fuel kit
Coil overs
Rims+tires
Built motor
M85 rear end
V160swap
Unicorn semen
that last one is a MUST HAVE
sklimo (08-21-2014)
Old 08-21-2014, 04:39 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
A clutch and a tune from James M, but I am guessing you haven't done enough research to know who that is.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
cdrazic93 (08-21-2014), ftc~brz (08-21-2014), sklimo (08-21-2014)
Old 08-21-2014, 04:41 PM   #11
Ugm... personally I would prefer Pegasus wings, but hey to each their own!
Old 08-21-2014, 04:47 PM   #12
ftc~brz
Done
Drives: WRB BRZ
i didn't see this was his absolute 1st post or I would have been meaner.
**But really start reading through that link I posted. Start with the stickies and work your way down. Read build threads of peoples stuff you like. And know all the stuff you need BEFORE you start tearing up the car for the love of god.
i spent 6 months doing daily solid research before even buying parts and I made several expensive changes. You can't just slap a turbo kit in and go and there are too many of us assh0les around here to learn from. Don't ask what you should do or need to get, do the leg work and know yourself.
much luck to you
sklimo (08-21-2014)
Old 08-21-2014, 04:49 PM   #13
richpow
Thanks guys, I'll give those threads a look, and figure out exactly how I want to build everything.
The Following User Says Thank You to richpow For This Useful Post:
Old 08-21-2014, 04:51 PM   #14
sklimo
Where in CT are you?
Best Turbo kit / kits to stay away from? bren5279 Forced Induction 137 07-26-2018 11:50 AM
Poll: Oil cooler kits with oil fed turbo kit sw20kosh Forced Induction 0 07-27-2014 12:19 PM
Why is no one using sti turbo kits? diss7 Forced Induction 12 05-16-2014 12:10 PM
New FI Kits- AVO Turbo and Innovate Superchargers JM Auto Racing Forced Induction 98 03-22-2014 01:18 PM
Turbo/SC Kits Comparison Chart ft_sjo Forced Induction 48 05-03-2013 02:19 PM
