Old 08-19-2014, 02:35 PM   #1863
Calum
That Guy
Drives: 2013 asphalt FRS MT
Unfortunately it doesn't look like we'll be able to do custom Bilsteins for this platform.
Might have something else up our sleeves, but too early for a timeline.
- Andy
Shit.
Originally Posted by STV3 View Post
So still nothing on the TRD springs as to whether they positively or negatively affect the handling of the FRS?
Really just looking to keep the cars ride quality and handling as close to stock as possible.
The ride quality and handling with RCE yellows, a little more caster, and a good alignment is better than stock. I was actually very surprised when my car was smoother going over bumps AND could hold more speed mid corner.
Old 08-19-2014, 02:44 PM   #1864
STV3
Señor Member
STV3's Avatar
Originally Posted by Calum View Post
Shit.
Yeah I've heard a lot of good things about these and the drop is just shy of an inch correct? This may be another option for me, but I was interested in the TRD springs because of the warranty on the stock shocks.
STV3 is offline   Reply With Quote
Old 08-19-2014, 02:52 PM   #1865
As far as I know the spring rates were never released, so it's hard to say.
- Andy
Racecomp Engineering is online now   Reply With Quote
Old 08-20-2014, 12:56 AM   #1866
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
Absolutely true. Similar setup here (RCE yellows, stock struts), MPSS tires, a bunch of Whiteline bushings and a great alignment has equalled an incredible corner monster. Much smoother over bumps than stock. Especially after the bushings and alignment.
Sirsimon is offline   Reply With Quote
Old 08-20-2014, 01:15 AM   #1867
CSG Mike
CSG Mike's Avatar
Recently put on MPSSs and now when I'm approaching the new found limits I find the car bouncy/floating mid corner when going over even mildly uneven pavement. Is it possible to keep it predictable and steady going over bumps while the bump stops are well compressed? Without either spending a shit ton of money, or turning the limit into a knife edge that I wont feel comfortable with either?
Set up is stock unless otherwise stated:
RCE Yellows
Whiteline: diff inserts, subframe inserts (I doubt these would have much to do with it, but it's possible, camber bolts, and front control arm bushings.
And of course, the 215-45-17 pilot super sports.
Time for some dampers
Old 08-20-2014, 06:46 AM   #1868
Calum
That Guy
I'm pretty sure I have the answer to this question, but I'm gonna ask anyway.
Which dampers would anyone recommend?
Old 08-20-2014, 06:51 AM   #1869
Calum
That Guy
Also while I'm posting in this thread, I'd like to rehatch the sway bar debat.
I'm also finding the car understeers mid corner. I'm thinking of upgrading to a 16 mm adjustable rear bar to help tune out some of that understeer. Is this a mistake? If so, why?
Thanks guys!
Old 08-20-2014, 11:05 AM   #1870
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Bilstein would be my preference, probably the B6's in your scenario, although the B8's would probably also work too.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 08-20-2014, 11:08 AM   #1871
Koni and Bilstein are like Pepsi and Coke. Coke is better.
Just kidding. I run Koni on my personal Mini Cooper S and like them but I'm about to switch to custom valved Bilsteins (which would be like pure cane sugar fancy hispter soda). You could still do that with Bilstein HDs, the price just adds up.
In general I do like the gas pressure and monotube feel from Bilsteins...over big bumps they feel a little smoother and the response is a little quicker. The twintube Koni feels better on small and medium bumps. The rebound adjustment is pretty nice too but I really dig the fast response of the Bilstein.
The current price on the Koni Yellow full replacements from FT86club is hard to pass up. Bilstein HDs would work for you really well too and you could revalve them sometime down the line. I would be happy with either.
- Andy
Old 08-20-2014, 11:09 AM   #1872
Thanks guys!
How much front camber are you running?
I usually don't like running a bigger rear bar without a bigger front. You could still bias the sizes so that you get an overall increase in rear roll stiffness.
- Andy
Old 08-20-2014, 11:16 AM   #1873
gramicci101
Off Topic
- Andy
Old 08-20-2014, 11:25 AM   #1874
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Thanks guys!
what are your other mods?
are you on the gas mid corner?
FYI I'm doing c-stock in an FRS and I put in a Strano FSB because the oversteer was just too much for me. I now really enjoy the car's handling and any understeer is usually a result of me driving too fast for the radius of the corner (autocross)
I wouldn't even consider a RSB at this point
Old 08-20-2014, 01:13 PM   #1875
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Thanks guys!
Maybe you ought to try playing with alignment setting and tire pressure before you go add a rear sway bar.
Old 08-20-2014, 02:06 PM   #1876
Calum
That Guy
- Andy
The fact that Bilstein's can be rebuilt by more shops alone is a big selling point. I was leaning that way anyway.
- Andy
Right now I'm around 1.5 deg negative. I'm planning to take it to a competent shop and have them slot the struts. My goal would be 2.5-2.75. Of course I'd do this and see how it feels before I install sway bars.
I was thinking of running a 20mm front with a 16mm rear. Both adjustable so I should be able to play with it if the base setup is too much for me. Would that be more to your liking?
Other mods are a drop in filter and a Delicious Tuning tune.
I am squeezing the gas, but only enough to keep the suspension settled and maintain speed.
I certainly agree. Education is power though. If I can't accomplish what I want through basic setup of what I have, then I'll look at further mods.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
