Old 07-09-2014, 10:37 AM   #1
STX118
Drives: STX - BRZ
Arrow Racing Brake Front and Rear Kits
Okay I bit thebullet and installed a front and rear BBK on my BRZ… I’m not too big on postingetc but I used this site soooo much when I trying to make decisions on my car Ifeel obligated to “feed the system”. Ilooked at every kit out there I think… I considered just a rotor/pad kit andevery other available option. After too many hours of research I decided RacingBrake was the best direction. And I won’t say that I never looked back becauseI certainly have, many times and every time I do I reconfirm that I absolutelymade the right decision. The battle between drilled/slotted/fish hook seems tobe a very dynamic battle of semantics and perspectives all difficult to processwhen contemplating a significant purchase. RB addressed this of course with thedrilled slots that makes perfect sense and works like a champ. Also the splitveins are a unique and logical step to address limitations of standard ventingand cooling again works great as well.
The reasonsfor buying brakes made for a pretty short list...basically weight and appearancebeing the primary ones… the stock brakes seemed to work quite well even withthe tire and wheel upgrade…But after using these brakes for a half dozenautocross weekends the actual braking performance is now at the top of that list,and really easily justifies the purchase… the weight drop and appearance gainsas totally bonuses!
AgainI am not a perpetual blogger so I did not do a great job.. or any job.. oflogging images of the process etc.. but I will add pics at some pointsoon. I appreciate this community beinga resource, it certainly has a great deal of value to a new owner.
Thanksall.
STX118 is offline   Reply With Quote
The Following 3 Users Say Thank You to STX118 For This Useful Post:
Anthonytpt (07-09-2014), DAEMANO (07-09-2014), rb6freak (08-05-2014)
Old 07-09-2014, 03:44 PM   #2
D K
Stig's dark passenger
Pics or it didnt happen
D K is offline   Reply With Quote
Old 08-04-2014, 03:59 PM   #3
STX118
Drives: STX - BRZ
Pics Finally!
Here are the pics... so it did happen!! And these are after some hard miles; still love them!!!
The Following User Says Thank You to STX118 For This Useful Post:
DAEMANO (08-04-2014)
Old 08-04-2014, 04:48 PM   #4
mike the snake
Your rear rotors still show the cross-hatch.
Did this kit change the braking balance/bias front-to-rear?
Looks like a nice brake kit.
Old 08-04-2014, 07:47 PM   #5
himbo
Drives: Lightening Red BRZ Ltd.
Nice. Can you give specs on weight savings? Also, do you still have use of your parking brake?
himbo is offline   Reply With Quote
Old 08-19-2014, 11:46 AM   #6
STX118
Drives: STX - BRZ
Thumbs up
Initially I believe it did to some degree because I was running different pads front and rear. The XR70's in the front and ETs in the rear. Still worked very well but for my primary use of autocrossing the fronts were really aggressive... more than what's necessarily optimum for below 70mph.I just switched to the XT910's all around and felt an overall improvement with both modulation and; difficult to tell but; probably bias as well.
Old 08-19-2014, 11:53 AM   #7
STX118
Drives: STX - BRZ
Don’t recall the weights off the top of my head but it's on their website. And yes that is 1 of the unique features of this setup OEMparking brake is fully functional no change/adjustment whatsoever. Just had to trim the splash guard like they show you on the site… wasn’t as bad as I thought it would be, used standard tin snips and a 4” grinder to clean up.
Old 09-11-2014, 11:01 PM   #8
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Thanks, may have to budget for this kit
Jmonty is offline   Reply With Quote
Old 09-12-2014, 08:04 AM   #9
wparsons
wparsons's Avatar
Until you're exceeding the thermal capacity of the stock brakes on good pads, there's no need for a BBK.
The weight savings is nice, but the money is better spent on entry fees or tires.
flickr
Dipstik-sportech (09-12-2014)
Old 09-15-2014, 05:14 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
There are other benefits though. I stopped tracking the BRZ but I made up a good bit on consumables savings towards the price of the kit before I stopped
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-15-2014, 09:55 PM   #11
Simok
Drives: 2013 FRS
Kit looks great. How dose it feel?
Simok is offline   Reply With Quote
Old 09-16-2014, 10:03 AM   #12
wparsons
wparsons's Avatar
Agreed, but if you're at the level where you going through more than one set of rotors and multiple sets of pads in a year, you're probably also beyond the thermal capacity of the stock stuff.
flickr
bbk, big brake kit, brakes, racing brake
New Products: Front/Rear AP Racing Formula Brake Systems- fit stock wheels! JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 165 11-20-2013 06:10 AM
AP Racing / Essex brake kits fit 16's? Yes! And even 15's!! diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-06-2013 07:07 PM
Baer front and rear brake kits JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-04-2012 06:47 PM
StopTech Introduces Big Brake Kits for 2013 Scion FR-S! At Vivid Racing vividracing Brakes, Suspension, Chassis 2 09-18-2012 02:19 PM
