Old 08-16-2014, 06:35 AM   #491
KenTK808
Drives: White 2014 Scion FRS
I did this trick with my turbo Del Sol and it made a marginal 15 degree temp difference. Pulled that thin rubber gasket off the windshield cowl and stuck a washer between the hood and the hinges. It let out some of the hot air through the back of the hood.
KenTK808 is offline   Reply With Quote
Old 08-18-2014, 08:44 AM   #492
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
Originally Posted by crazyfrenchbiker View Post
I was curious about these types of systems as well and was considering putting one on my intercooler. Is there any downside?
The only thing i can think of is if you take something very hot and and water to it, that doesnt go well.
however, if the spray is not an extremely heavy drenching it should be ok. I'm seriously going to look into this soon.
Die$eL is offline   Reply With Quote
Old 08-18-2014, 09:16 AM   #493
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
It was a light spray on the hot side of the intercooler. I've seen systems rigged up to automatically spray whenever the intake was over a certain boost level. Works pretty well.
Bonus: it helps cool the radiator too...
Sellout is offline   Reply With Quote
Old 08-18-2014, 10:10 AM   #494
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I've seen people rig them up to their wiper bottles and simply spray them manually to help with cool down.
crazyfrenchbiker is offline   Reply With Quote
Old 08-18-2014, 10:20 AM   #495
ML
ML's Avatar
Drives: 13 White MT FR-S
Shit, I posted this 3 months ago and nobody noticed.
http://www.ft86club.com/forums/showp...&postcount=292
The Following 2 Users Say Thank You to ML For This Useful Post:
blackfireball5 (08-18-2014), Boba_kz (08-22-2014)
Old 08-19-2014, 02:12 AM   #496
Die$eL
Die$eL's Avatar
lol. that looks like an awesome solution!
Especially with the fan to pull air through the cooler
Old 08-22-2014, 05:40 AM   #497
Boba_kz
FBM Stage 1
1) FBM shroud with Spal fans
2) Koyo radiator
3) FBM oil cooler
4) Additional hood and bumper ventilation
5) Motul Mocool
6) Heat wrap
Still have a problem with heat after pushing turbo.
Boba_kz is offline   Reply With Quote
Old 08-22-2014, 07:33 AM   #498
Raven604
Get a splitter and Duct/dam the rad
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 08-22-2014, 07:41 AM   #499
Boba_kz
Which one? Pics please
Old 08-22-2014, 08:04 PM   #500
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by Boba_kz View Post
FBM Stage 1
2) Koyo radiator
3) FBM oil cooler
5) Motul Mocool
6) Heat wrap
what temps are you seeing in various situations?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 08-22-2014, 08:11 PM   #501
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
4) Additional hood and bumper ventilation...
Maybe an aftermarket bumper (not necessarily this one...)?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-22-2014, 08:48 PM   #502
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The 'grille' portion of that front end isn't a mesh, it's solid and the opening is pretty much the same as stock. minus the foglight area.
Old 08-22-2014, 08:51 PM   #503
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Nothing a dremel and a few hours cant fix.
Old 08-22-2014, 09:04 PM   #504
mike the snake
This is what I've done, along with a Drift Armor front crash bar replacing the stock crash beam. This allows a LOT more air in through the front.
I also modified my skidplate, cutting a hole and adding a rubber "trip strip" to help draw air out of the engine bay.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
