#799 | |
If you've deleted cats, then you'll need a custom tune. If you still have the stock header and overpipe, then you're good with the CARB tune. Catbacks don't add power, no matter what the manufacturer/vendor claims. You'll see why FI is the way to go once you get your kit. More hp/dollar
#800 | |
Drives: 2015 BRZ Series.Blue in WRB
#801 |
Drives: 2021 GR Supra A91 Edition
My apologies if I missed this, I've read so much over the past month my head is spinning. Are there any high boost pulleys in the works for the JRSC?
What is the stock pulley's size and max boost? |
#802 |
#803 | |
I can't comment on the rest |
#804 |
#805 |
Drives: Really slow
If you are having it tuned locally...
California - Delicious Tuning NW USA - Probably Drift Office NE USA - Moto East SE USA - Jamesm at HRI Tuning Central USA - ??? E tunes - Jamesm, Delicious Tuning or Moto East. Jamesm would be my top pick overall for either types of tuning. Apparently, he's an absolute baller tuning this car. |
#806 |
Drives: 2014 Scion FR-S|Whiteout
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#807 |
Drives: 2015 Series.Blue BRZ
NDA for any possible future products and as for a maximum... Legal liability. While his engine might have a max boost of 25psi, yours might only be 20 psi. So if you try to go for 25 and how your motor, you might try and sue him over it.
#808 |
read between the lines guys :p
| The Following User Says Thank You to CSG Mike For This Useful Post: | *LongFella (08-17-2014) |
#809 |
Yes. Yes I am
![]() I just like bugging you about it. Constantly. It would be nice if JR comes out with an "upgrade kit" that includes everything (pulley, new track tested tune, etc.). I'd gladly fork over more money. Wishful thinking. I know
| The Following User Says Thank You to *LongFella For This Useful Post: | CSG Mike (08-17-2014) |
#810 |
patience!
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (08-17-2014), ScionOfHorus (08-18-2014) |
#811 | |
If you know how those pumps work, yes. You're still missing the point that PCV is not simply about emissions. The percentage change is the obvious point in the HP figures or does a smaller motor magically turn into something different that defies physics? Also, one doesn't need a major restriction to draw a vacuum. It's not hard to add catch cans into this setup: ![]()
#812 | ||||
Mr. Cranky Pants
Drives: 2013 Argento FR-S
I do know how they work. I know why you gain power with them, and I know the PCV system will never be able to draw any real vacuum in the crankcase, which makes your comparing the two ridiculous.
You can't evacuate a crankcase with the turbocharger's intake pipe without that intake pipe being under a deep vacuum. When that intake pipe is under a deep vacuum your compressor is working at a high pressure ratio and producing a lot of heat. Not to mention that when you pull a vacuum on a chamber that's full of oil vapor you pull that oil vapor out and coat the inside of all your intercooler piping and the intercooler itself. I invite you to prove me wrong. Hell, I hope I am wrong. Rig up a vacuum gauge to that crankcase in your supra and make a video. Let's see the pcv system in action pulling a partial vacuum on the crankcase. Quote:
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
