Old 08-17-2014, 03:10 AM   #799
CSG Mike
CSG Mike's Avatar
Originally Posted by K-NoMs View Post
Last question, i have a full exhaust system from speedfactory, will those parts work with the JR kit?
Define "full exhaust system".
If you've deleted cats, then you'll need a custom tune. If you still have the stock header and overpipe, then you're good with the CARB tune.
Catbacks don't add power, no matter what the manufacturer/vendor claims. You'll see why FI is the way to go once you get your kit. More hp/dollar
Old 08-17-2014, 04:52 AM   #800
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Catted UEL headers, Motiv front pipe and over pipe, and greddy exhaust
K-NoMs is offline   Reply With Quote
Old 08-17-2014, 02:21 PM   #801
Sirsimon
Sirsimon's Avatar
Drives: 2021 GR Supra A91 Edition
My apologies if I missed this, I've read so much over the past month my head is spinning. Are there any high boost pulleys in the works for the JRSC?
What is the stock pulley's size and max boost?
Sirsimon is offline   Reply With Quote
Old 08-17-2014, 03:35 PM   #802
CSG Mike
CSG Mike's Avatar
You'll probably need a custom tune.
Old 08-17-2014, 03:36 PM   #803
CSG Mike
CSG Mike's Avatar
Boost depends on where you live and how the conditions are. Stock pulley is 110mm.
I can't comment on the rest
Old 08-17-2014, 05:56 PM   #804
K-NoMs
Where would i get the tune done? Like i said all new to this
Old 08-17-2014, 06:19 PM   #805
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
If you are having it tuned locally...
California - Delicious Tuning
NW USA - Probably Drift Office
NE USA - Moto East
SE USA - Jamesm at HRI Tuning
Central USA - ???
E tunes - Jamesm, Delicious Tuning or Moto East. Jamesm would be my top pick overall for either types of tuning. Apparently, he's an absolute baller tuning this car.
Cheeseballs is offline   Reply With Quote
Old 08-17-2014, 07:41 PM   #806
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Why not?!?! Come on!!!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 08-17-2014, 07:45 PM   #807
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
NDA for any possible future products and as for a maximum... Legal liability. While his engine might have a max boost of 25psi, yours might only be 20 psi. So if you try to go for 25 and how your motor, you might try and sue him over it.
ScionOfHorus is offline   Reply With Quote
Old 08-17-2014, 08:11 PM   #808
CSG Mike
CSG Mike's Avatar
read between the lines guys :p
*LongFella (08-17-2014)
Old 08-17-2014, 08:19 PM   #809
*LongFella
*LongFella's Avatar
Yes. Yes I am
I just like bugging you about it. Constantly.
It would be nice if JR comes out with an "upgrade kit" that includes everything (pulley, new track tested tune, etc.). I'd gladly fork over more money.
Wishful thinking. I know
The Following User Says Thank You to *LongFella For This Useful Post:
CSG Mike (08-17-2014)
Old 08-17-2014, 08:49 PM   #810
CSG Mike
CSG Mike's Avatar
patience!
*LongFella (08-17-2014), ScionOfHorus (08-18-2014)
Old 08-18-2014, 12:22 AM   #811
Poodles
Originally Posted by Sellout View Post
A Moroso vacuum pump is comparable to a PCV system now? Wow.
Would you like to discuss the horsepower gained from the evacuated crankcase (on a motor with a third of the piston underside surface area of that rat motor) and how that compares with the horsepower lost from the intake system being restrictive enough to allow a turbocharger to draw the kind of vacuum it would require to actually evacuate the crankcase? Because we could do that...
If you know how those pumps work, yes.
You're still missing the point that PCV is not simply about emissions. The percentage change is the obvious point in the HP figures or does a smaller motor magically turn into something different that defies physics?
Also, one doesn't need a major restriction to draw a vacuum.
It's not hard to add catch cans into this setup:
Old 08-18-2014, 08:59 AM   #812
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
I do know how they work. I know why you gain power with them, and I know the PCV system will never be able to draw any real vacuum in the crankcase, which makes your comparing the two ridiculous.
I'm not the one missing the point here. I completely understand your point and I am rejecting it as ridiculous. Big difference.
No shit there would be a percentage change. I'm not asking a system to defy physics, that's you. You're the one claiming you can gain power by evacuating a crankcase to nowhere near the level that a vacuum pump does...
You can't evacuate a crankcase with the turbocharger's intake pipe without that intake pipe being under a deep vacuum. When that intake pipe is under a deep vacuum your compressor is working at a high pressure ratio and producing a lot of heat. Not to mention that when you pull a vacuum on a chamber that's full of oil vapor you pull that oil vapor out and coat the inside of all your intercooler piping and the intercooler itself.
I invite you to prove me wrong. Hell, I hope I am wrong. Rig up a vacuum gauge to that crankcase in your supra and make a video. Let's see the pcv system in action pulling a partial vacuum on the crankcase.
I work with vacuum systems every day. You're wrong. Did you bother to read that article you quoted? It said they had pulled 6" of vacuum on their engine with that pump. How are you going to do that with a PCV system on a turbo engine without a restriction at the intake that soaks up power by moving you into a higher PR on the compressor? Remember you need to flow all that crankcase pressure through your small PCV lines and catch can. Drawing a minor partial vacuum in your turbo inlet pipe isn't going to cut it.
Which brings us right back around to my statement that no oil separator is 100% efficient. I work with the most efficient oil separators in existence at my job, and I get to deal with the problems caused by the less than 1% of oil being left in the discharge of the oil separator quite often.
Sellout is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
