Old 08-16-2014, 07:45 AM   #15
OmarYasin
OmarYasin's Avatar
Hi, read the info on logging and E85 tunes below
Log your fuel trims and see what your LTFT looks like at low rpm if its over 10 its either still learning (should only take 15 minutes) as per learning info drive smooth and steady for 10-15 minutes should sort it , do you have stock intake aftermarket intakes can cause problems.
Drop filter, inlet tube and modded snorkel
OmarYasin is offline   Reply With Quote
Old 08-16-2014, 03:34 PM   #16
OmarYasin
OmarYasin's Avatar
Size:  113.7 KB so I just re flashed again, after I left it idle for 5min this is what I saw on tablet, how does it look at idle, idk how to read it all I know about is afr and what to expect under loads?
Old 08-16-2014, 03:38 PM   #17
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Just drive the car smoothly so the ltft goes below 10
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 08-16-2014, 03:48 PM   #18
OmarYasin
OmarYasin's Avatar
Drove around and is at 10.93 at idle as of now
Old 08-16-2014, 04:33 PM   #19
Lytheum
Drives: 2013 BRZ Premium 6MT
Mine has high ltft at idle but is within a couple % at cruising and wot. Wouldn't worry much if its only high at idle speeds.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
OmarYasin (08-16-2014)
Old 08-16-2014, 10:45 PM   #20
steve99
Drives: FT86
@OmarYasin @Lytheum , high fuel trims at idle only unlikely to cause any serious issues other that hesitation or bogging when you first get on throttle.
if you stock intake ect then maf scaling in that area is only fix if your keen see links below
Old 08-17-2014, 12:47 AM   #21
OmarYasin
OmarYasin's Avatar
Actually I reflashed and drove 54miles shifting no more then 3500 and its feeling alot better then yesterday, I dont usually have any issues, I also filled up e85 today, so maybe this isnt the thread for this im sure I can find it but exactly what is maf scaling? More air coming in?
Old 08-17-2014, 02:53 AM   #22
steve99
Drives: FT86
maf is mass air flow sensor, rescaling it reduces the fuel trim corrections needed by the ecu to account for maf being out of calibration see the links below
dont try maf scaling on E85, wait till you back on petrol.
Old 08-17-2014, 12:54 PM   #23
Lytheum
Trims are fine at idle on 93 but e85 seems off there. They are good everywhere else...never noticed any issues.
Stock intake with shortened snorkel and k&n drop in.
Old 08-17-2014, 04:14 PM   #24
steve99
Drives: FT86
Trims will move arround on E85 due varying ethanol content (as long as they say under 10% your pretty good) thats normal, if they are good on petrol all is ok.
Old 08-17-2014, 04:20 PM   #25
OmarYasin
OmarYasin's Avatar
Yeah I can see that, yesterday was jumping frm high 8s to 10s?? Im keeping my eye on it for a couple more days
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 12:01 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 10:04 PM
