Old 08-16-2014, 06:42 PM   #15
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by wparsons View Post
Don't bother with the +48, especially if you plan to add any camber up front. +38 will sit a lot better with 8" wheels. I have 17x8 +45 and wish I had gone for +35 instead.
If he's married to +48, could he not get camber plates to add it without rubbing?
drewbot is offline   Reply With Quote
Old 08-16-2014, 06:59 PM   #16
stugray
Drives: 2013 GBS BRZ Limited
Half the time I dont know what the hell you guys are talking about.
Springs ARE coilovers.
Coilovers ARE springs.
When people talk about "getting coilovers".
The car HAS coilovers stock.
Talk about a confusing discussion.
To me it sounds like: ""I want to upgrade my springs with some springs, but I dont know if I should get springs or springs......" WTF??
The Following 2 Users Say Thank You to stugray For This Useful Post:
Captain Snooze (08-16-2014), wootwoot (08-16-2014)
Old 08-16-2014, 07:19 PM   #17
gramicci101
Off Topic
Ok, let's define "coilover" as an integrated spring/strut combo such as a KW v3, and "spring" as a product that does not have an integrated strut from the factory, such as RCE Yellows. That's why I try to specify spring/strut combo (RCE Tarmac & Bilstein B8) vs. coilover (RCE Tarmac II).
So while coilovers do have springs as a part of them, springs do not necessarily have struts as a part of them.
The Following User Says Thank You to gramicci101 For This Useful Post:
stugray (08-16-2014)
Old 08-16-2014, 08:35 PM   #18
stugray
That makes more sense.
That is why "spring/strut combos" can accommodate a bigger tire than the stock "spring/strut combo" because they engineer it from the beginning with a smaller diameter (and more expensive) spring.
Old 08-16-2014, 08:44 PM   #19
gramicci101
Off Topic
You're not helping.
So to you, what is the generic term for a product such as a KW v3 or RCE Tarmac II? And then the same question for RCE Yellows combined with Bilstein struts?
Old 08-16-2014, 08:52 PM   #20
wparsons
wparsons's Avatar
He could, but that's another ~$500. Plus, camber added at the knuckle is slightly better for geometry than camber added at the upper mount.
flickr
Old 08-16-2014, 08:57 PM   #21
stugray
You're not helping.
No I was agreeing with you.
Now I understand how the terminology works.
If you are buying "springs" and using the stock strut, you have fewer choices than if you buy a complete package (combo) because the end result can be more room for an over sized or inset tire.
Old 08-16-2014, 09:02 PM   #22
gramicci101
Off Topic
That's how I mean it. Springs can be used with the OEM strut. You can replace the strut as well, but they're purchased as separate items from the springs. Coilovers are integrated units right out of the box.
Old 08-16-2014, 11:50 PM   #23
CSG Mike
CSG Mike's Avatar
Originally Posted by FloridaBRZ View Post
I wasn't asking for advice justifying coilovers. I was asking, for someone that doesn't need track adjustability, is there ANY reason to just get springs instead of coilovers? I can't see a reason why. That is why I asked.
Ride quality.
finch1750 (08-17-2014)
Old 08-17-2014, 12:57 AM   #24
themajesticone
themajesticone's Avatar
Drives: '13 UM86
I have been trying to decide about coilovers vs springs. It seems they are within 3-400$ of each other. The RCE/Bilstein combo is around 1400$. I can get nice Cusco coilovers with camber plates front and back for 1800$. What, if any, is the benefit of getting springs over coilovers? This is my DD and I want to start autoX possibly or getting some track time.
http://www.ft86club.com/forums/showthread.php?t=71386
themajesticone is offline   Reply With Quote
The Following 2 Users Say Thank You to themajesticone For This Useful Post:
Captain Snooze (08-17-2014), FloridaBRZ (08-17-2014)
Old 08-17-2014, 08:18 AM   #25
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
"Nice" coilovers with 40 click 1-way adjustment have been designed by the marketing department.
wparsons (08-17-2014)
Old 08-17-2014, 12:30 PM   #26
White64Goat
If you want to just do springs first, take a look at these. This link (http://www.fastwrx.com/collections/w...ducts/rota-rkr) is for the wheels that Dan (owner of Mach V) currently has on his BRZ. This will give you a reference to what size the wheels are and what size tires he is running on the Mach V springs. Here are some close up pictures.
Wheel opening spacing is even front and rear and I think this set up really looks nice.
Old 08-17-2014, 12:37 PM   #27
gramicci101
Off Topic
RKRs look too much like 1980's Japan for me.
Suspension Question TONYpepperon1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-12-2013 08:57 AM
Question for you suspension Guru's invzabomaster Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-13-2013 05:26 PM
Suspension (Coilover) Install Question crizkay Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-28-2013 09:17 AM
suspension question Bruninho8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 08-14-2012 05:03 PM
BRZ vs. FRS suspension question smbrm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-12-2012 09:55 AM
