#141 | ||||
Drives: ZC6, Junk of ALL sorts
Hence▼ Quote:
I'm confident, and knowledgeable enough to see the level of completion / attention to details. Relating to you, some things e.g, engine internals just can't be reasonably inspected, for the most part. Quote:
Or naa. Yup, subjective.
# 1. Always know where your towel is.
ZC6-CBS, is home |
| The Following User Says Thank You to Floggin Tires For This Useful Post: | wsites (07-30-2014) |
#142 |
Drives: stock
Ls or gtfo
#143 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
![]() Forget the whole thread. You quoted ME, I had said that the swapped car PROBABLY has a better CG than a car with a typical HIGH MOUNT turbo kit. You ran off at your keyboard about a completely different turbo setup as if I had said something else entirely. One might even think you didn't bother to read what you were replying to... |
#144 | |
#145 | |
Drives: 08 STI|15 BRZ|95 L Coupe
#146 | |
#147 |
It's the Mad Cow
Honestly you could swap in a Geo Metro Motor and have a more reliable setup than a Rotary Engine. But then I am a little bias from my many fights with them.
"My FD RX7 is one of the best looking cars ever... but it doesn't really move all that much"
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#148 | |
![]() I'm rolling right now hahahahahaha |
#149 |
Drives: Whiteout 6Sp FR-S
Good bye my sweet car. Next time I see her she will be transformed
#150 | |
Right on.
ZC6-CBS, is home |
#151 |
Drives: 2013 FRS Whiteout
I would sell mine for the right price
Serious inquiries only
#153 | |
Automotive Connoisseur
Drives: too many cars
LSx Powered 86/ASE Master Certified Automotive Technician
#154 |
Just talked to them the other day. They got the engine and they are cleaning ut up and inspecting it prior to putting it in. I created about a 2-3 day delay because I decided that while the engine was out I wanted to replace the flywheel and clutch. They offered a z06 setup but I decided to go chromemolly 14lb and a MF clutch so the shippinh delayed my set up. I hope to have her back by labor day but will keep you all informed
| The Following User Says Thank You to C130NAV For This Useful Post: | AZFA20 (08-16-2014) |
| 'Sloane' - Cali first time build | Re~Mix | Member's Car Journals | 6 | 06-24-2015 08:22 PM |
| The time attack build by Rob | SavingManuals | Member's Car Journals | 8 | 04-27-2014 08:01 PM |
| Adventure Time! (E.Ts BRZ/86 Build) | E.T | Member's Car Journals | 4 | 01-20-2014 01:02 AM |
| Frs300 Fa20club built motor and turbo build | Frs300 | Member's Car Journals | 32 | 01-18-2014 05:27 AM |
| New FRS owner.. time for a build? | sero901 | Forced Induction | 5 | 10-24-2013 09:40 PM |
