Drives: Subaru
re-install Front bumper to headlight gap fix
Anyone have one? I read a thread about this some time ago but search button has failed me....
#2 |
Boosted
Drives: Not a supra....yet
Run a race beam
#3 |
Drives: 14 FRS Whiteout
#4 |
Drives: 2014 FR-S
There was a TSB a while back that had replacement brackets that should have fixed this problem.
Also check this thread: http://www.ft86club.com/forums/showt...t=37694&page=7 Also you are in the wrong sub-forum |
#5 | |
Boosted
No he's not, when installing an intercooler the bumper usually doesn't go back together .
#6 |
Boosted
Its the part in the top right black, replaces the factory crash beam
#7 |
Drives: Subaru
Check my build, i have that bar and my bumper still doesn't go back together properly... Tsb huh... I'm in!!!
#8 |
#9 | |
Drives: 2017 Camaro 1SS
#10 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Don't know about you guys, but my bumper fits fine. I had the gap you're talking about but I just had to exercise a little patience and it installed just fine.
#11 |
This is worrisome. I really want to do up my headlight and install a oil cooler but I also like to not have gaps on my bumper
is this problem so prevalent that I should probably not diy bumper removal?
#12 |
Drives: Subaru
Any bumper removal diy or not will cause this...
#13 |
#14 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
take a look at this.
http://www.ft86club.com/forums/showthread.php?t=37694 post #138 looks promising. I've used the speaker wire trick in the past with good results. (piece of wire jammed in the gap to hold the tab and hook together) My bumper has been off since then, just too lazy to fix it again! |
| Front bumper sagging where it meets headlight? | 1Cor10:23 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 10-10-2020 09:57 AM |
| WTB: Raven front bumper plus front underpanel and passenger side front fender liner | THEmailman | Want-To-Buy Requests | 1 | 04-20-2014 12:05 AM |
| JDM Headlight Washer ”Sticker“ on Front Bumper | Figo | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 04-04-2014 07:01 PM |
| WTB: Seat Belt Buckles, Driver's Headlight (BRZ), Front Bumper Cover (BRZ) | DatApex | Want-To-Buy Requests | 2 | 03-19-2014 01:21 PM |
| WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit | Guildjs | Want-To-Buy Requests | 5 | 10-31-2013 08:35 PM |
