| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Subaru BRZ Limited (SWP)
BRZ TRD
After over a year in my '13 SWP BRZ limited, I decided it's time for some performance parts. Being conservative in nature, I was attracted by the TRD exhaust and cold air intake. The sound (a little deeper) is just right to my ear. And it appears there's a minor performance boost as well. So I just pulled the trigger. My local Scion dealer (just down the street from my Subaru dealer) will install the parts and I'll get the mfr warranty on them. Can't wait!
#2 |
Drives: 2015 Series.Blue BRZ
I wouldn't bother with the intake. Aftermarket intakes make no difference on these cars.
#3 |
Drives: n/a
I'm no expert, but from what I've been reading an aftermarket intake can get you ~5 hp, but an aftermarket cat-back exhaust won't get you anything without doing the rest of the exhaust as well.
#4 | |
Read through here and the linked threads before spending ~$500 on something that's more cosmetic than anything: http://www.ft86club.com/forums/showthread.php?t=71813 |
#5 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
The TRD, at least on my car, is a lot deeper down low
If I were you at least plug up the sound tube in the foot well to remove extra loudness and keep the OEM intake |
| The Following User Says Thank You to drewbot For This Useful Post: | MarcL (08-16-2014) |
#6 |
I have both the intake and the exhaust and like them. I recommend running a modded snorkel with the TRD intake.
#7 |
Just Some Dude
Drives: 14 FR-S Raven A/T
You can get same, if not marginally better gains from a $50 drop in filter like K&N. Your better served going that route.
#8 |
Drive From Home
Drives: BRZ STI Performance
Aftermarket intake tends to shift your power band higher into the rev range, hence your "5hp" gain but you won't get it until you hit close to redline. Your midrange will goto shitz. No thanks!
#9 |
Drives: n/a
That's the route I went, got a Green Filter drop-in. Plan to go FI one day so I'll mess with the intake then.
#10 |
Drives: 2014 Subaru BRZ Limited 6smt
Plus to truly gain any HPs you would have to tune the car. Drop in filter is the way to go.
#11 |
Spun
Drives: 23' Supra
#12 |
Boy, everyone's pouring a lot of cold water on this. I have no illusions that this will have anything more than a negligible impact on power. I like the sound and the look of the TRD exhaust. And it seems appropriate to add the matching intake - it also looks nice and deletes the silly sound tube. Nuf said.
#13 |
You're better off grabbing one of these if you want to delete the sound tube: http://perrinperformance.com/i-13324...-fr-s-brz.html
#14 | |
Drives: Subaru BRZ Limited
There is still some people get better HP with TRD intake. http://www.ft86club.com/forums/showp...&postcount=195 Thanks. |
| The Following User Says Thank You to cslntuee For This Useful Post: | MarcL (08-16-2014) |
