Old 08-14-2014, 04:51 PM   #1
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Cool Rev match downshift possible with OFT
Hey guys, got my OFT today, pretty exciting, updating to the latest files and such, modifying the RPM delta, that kind of basic stuff. I remember that RaceRom (Ecutek) had the option of rev matching downshift on manuals cars, I was wondering if such a thing was possible with the OFT ? I know most of you guys will tell me just do it yourself and such and I'm not agaisnt that since I really improved my technique, but still wondering if it's an option that I didn't see and if it could be added ? @Shiv@Openflash
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 08-14-2014, 05:37 PM   #2
jvincent
jvincent's Avatar
Nope, it's not a feature.
I'll save Shiv the keystrokes and tell you to keep doing it yourself.
Old 08-14-2014, 05:37 PM   #3
Simon99
Simon99's Avatar
Hahahaha so nice of you just trying to mess with the most possible options u know
Old 08-14-2014, 05:46 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
I think it was on visconti tune where they said it was finicky and only recommended for track use. And it was't very accurate either. They took it out of their standard maps for that reason.
If you can heel toe it is probably much better than this "feature". I can heel toe [poorly] and I haven't blown it up yet in 30k miles (fingers crossed)
Old 08-15-2014, 05:59 PM   #5
OmarYasin
OmarYasin's Avatar
I heel toe revmatch
OmarYasin is offline   Reply With Quote
Old 08-15-2014, 08:03 PM   #6
Tromatic
Heh. The AT rev match does a better job than I ever could with a manual.
Old 08-15-2014, 09:04 PM   #7
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Here here. Even if we had a solution for auto-blip, I could never see myself every using it. Kind of takes much of the fun out of driving a manual transmission. And unless it's done perfectly, it actually gets in the way of performance driving.
Shiv@Openflash is offline   Reply With Quote
Old 08-15-2014, 10:08 PM   #8
OmarYasin
OmarYasin's Avatar
So shive, I just updated oft to 2.0 stage 2 uel e85 and feel like its bogging down low, does it take time for the ecu to relearn the new map or is it pretty normal or expected out of the latest map?
Old 08-15-2014, 10:09 PM   #9
OmarYasin
OmarYasin's Avatar
[quote=OmarYasin;1902022]So shive, I just updated oft to 2.0 stage 2 uel e85 and feel like its bogging down low, does it take time for the ecu to relearn the new map or is it pretty normal or expected out of the latest map? @Shiv@Openflash
Old 08-15-2014, 10:11 PM   #10
Simon99
Simon99's Avatar
I don't see why he would look again on an unrelated thread, but from what I've understood, flash the car, turn the key on for 20 seconds without pressing the throttle, start the car then leave it idle a bit, it should stabilize everything. Also make sure you got E85 haha
Old 08-16-2014, 01:23 AM   #11
OmarYasin
OmarYasin's Avatar
Did that, let it idle for 5min, definitely e85 in there. Ill just call em up mondat
Old 08-16-2014, 03:04 AM   #12
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
Use them feet! it's more fun anyways. practice on the freeway offramps
Ocean-Grown 86 is offline   Reply With Quote
Old 08-16-2014, 04:50 AM   #13
steve99
Drives: FT86
Hi, read the info on logging and E85 tunes below
Log your fuel trims and see what your LTFT looks like at low rpm if its over 10 its either still learning (should only take 15 minutes) as per learning info drive smooth and steady for 10-15 minutes should sort it , do you have stock intake aftermarket intakes can cause problems.
Old 08-16-2014, 05:18 AM   #14
akahenry
akahenry's Avatar
Drives: '18 STi
I did the same thing, updated to Stg 2 v2.03 UEL e85 map and the "dead pedal" also happened to me. Just drive slowly with moderation to the gas pedal, making sure to keep it under 3,500 rpms. It should take about 15- 20 miles for the pedal to stiffen up so the ecu relearns from the map.
akahenry is offline   Reply With Quote
The Following User Says Thank You to akahenry For This Useful Post:
OmarYasin (08-16-2014)
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 04:41 PM
Rough Downshift (bog?) from 3rd to 2nd... enwave Issues | Warranty | Recalls / TSB 8 08-29-2013 01:01 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 11:00 AM
transmission noise (when going to downshift) Hotlava86 Issues | Warranty | Recalls / TSB 5 09-03-2012 11:04 PM
