Old 08-08-2014, 06:51 PM   #1737
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
I knew they valved based on the spring settings but I thought having stiffer( well not really stiffer but relatively stiffer than 6k F/ 7k R setup ) might be a better idea..
I don't really know about the distribution but it might be slightly front heavy due to KW kit. I haven't had it corner weighted yet. Do you mean the corner weighted alignment?
A corner balance would be making the cross weights even (FR/RL vs RL/RR).
I'm strictly interested in the front axle weight vs rear weight in this case. You'll want to factor that vs the motion ratio of the wheel/suspension setup in your specific car to come up with the theoretically ideal spring balance ratio. Then you'll want to tweak this based on the squat/antisquat you have dialed into your suspension, and your specific driving preference. Once the rates (or range of rates) are chosen along with sway bars, you'll want to have the dampers valved to match those rates.
glamcem (08-09-2014)
Old 08-12-2014, 03:00 PM   #1738
Tainen
Drives: First SWP BRZ-L
Cross-posting a bit here, need you track guys' input:
http://www.ft86club.com/forums/showthread.php?t=72027
Basically, looking for a slight improvement over stock tire, but not an all out track tire, so I can continue developing my skills at a good pace, as per my instructor's recommendations.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 08-13-2014, 03:25 AM   #1739
Food
Drives: ...saving up for FRS/BRZ still
Ok...since we know how the FT compares to a Miata and S2k...what about this (it hasn't been mentioned yet):
stock FT vs stock S13/S14 (both with SR engines, but stock)
stock FT vs stock S13/S14 (both usdm KA engines, stock)
This would be a good comparison I think yes? ....since they weigh very similar, both FR rwd, and also make the same power (SR anyways).
But...I had an S13 with swapped SR, more than 10 years ago. All I remember it handled like sht lol - even though it was supposedly light, it felt sloppy, heavy and sways like crazy. Felt like a cadilac more or less. No where as precise, nice and nimble as my prior EG before that. I've test driven the FT...all I can say is Wow, when I drove it. The FT reminds me of the tight'ness, lightness and precise nimble feel of my old EG, but with rwd like an S13 ....so that said, I assume the FT will smoke the ish out of a stock SR S13 on the track, correct??
Food is offline   Reply With Quote
Old 08-13-2014, 03:58 AM   #1740
CSG Mike
CSG Mike's Avatar
I actually think the BRZ/FRS is a modern day 240, but I get shit for it lol.
I've never driven a stock 240 (do those even exist anymore?), so I can't say...
Old 08-13-2014, 04:25 AM   #1741
lbejosano
Drives: 2014 Firestorm Scion FR-S
What about in comparison to an E36 M3?
lbejosano is offline   Reply With Quote
Old 08-13-2014, 04:36 AM   #1742
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@CSG Mike does increasing track width have any adverse effects on track?
I've put in 25mm spaces with my 18x7.5" +46 wheels for the flush look but was wondering if I'd notice any difference at my next track day.
And, next question. I was thinking of going to 18x9.0 +44 wheels (again, for the looks). Likely to be TWS so pretty light even though wider. I am a pretty average track day participant (no racing, just fun days). I've been told wider wheels will likely adversely affect track performance but as a real amateur would I really notice?
nzer is offline   Reply With Quote
Old 08-13-2014, 05:23 AM   #1743
CSG Mike
CSG Mike's Avatar
Wider wheels =/= wider track width.
I wouldn't worry about track width. By the time you need to worry about it, you'll already know how you want to address it.
Old 08-13-2014, 08:49 AM   #1744
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Both of my parents had multiple versions of the 240Z to 300Z vehicles. I agree with this statement completely because every time I'm in my car, I'm reminded of riding around with my father as a child. It just feels the same.
Now if we could just get one of those raging L6 engines in there (Maybe that will happen with the Toyota/BMW joint venture)
bimmer635csi is offline   Reply With Quote
Old 08-13-2014, 10:32 AM   #1745
btsokolas
Where would you suggest putting a GoPro on the car when you track/autocross? I want to be able to see the track/course but I also want to be able to see myself and what I am doing inside the car. I know on a S200, for example, there is a great spot where you can put a GoPro on and see everything, the road ahead, yourself, etc. I mainly want this so I can review the videos and see what I need to improve on
btsokolas is offline   Reply With Quote
Old 08-13-2014, 10:54 AM   #1746
bimmer635csi
For about the same money as the top-dog GoPro, I was able to purchase THREE JVC Addixion cameras and make the videos you will find in my red thread below.
Also, you can look at random "autocross" and "track event" videos on U2B to figure out placement. A lot of people put the camera behind the driver on the left side of the car to try to achieve what you are looking for, but in my opinion, three cameras works better because you can see both sides of the car.
The Following User Says Thank You to bimmer635csi For This Useful Post:
finch1750 (08-13-2014)
Old 08-13-2014, 11:02 AM   #1747
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
I'm in the market for a new hood and I figure I might as well upgrade to one with vents and/or a scoop to manage engine bay temps. Living in New England, it doesn't sound like a smart idea to get vents, correct? And with that, I should just go with a plain OEM hood?
I know there's a hot debate between what's best (vents vs scoops) for our cars too.
Books is offline   Reply With Quote
Old 08-13-2014, 02:11 PM   #1748
CSG Mike
CSG Mike's Avatar
Upside down at the top center of the rear windshield. Make sure you put the go-pro in upside down mode, and spot metering (I wish GoPros did HDR).
Also, use the "medium" field of view.
Old 08-13-2014, 02:11 PM   #1749
CSG Mike
CSG Mike's Avatar
If you need cooling, a (properly) vented hood will do wonders.
Old 08-13-2014, 04:02 PM   #1750
nzer
nzer's Avatar
Thanks, not sure what you mean. Do you mean that I wouldn't notice wider track until I get a lot better on track and at that point I'd know enough about if and how I wanted to change it? Or, are you saying it doesn't matter anyway?
For wider track I was talking about the 25mm spacers I have installed (not wider wheels). I assumed that this would put the inside of the wheels farther apart thereby creating a wider track.
My second question was about 9" wide wheels rather than 7.5" wheels (not track width). I am more asking about if I'd notice the extra resistance of wider wheels and/or whether the extra grip would be detrimental given I am a very amateur track driver ?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
