Old 08-12-2014, 08:45 AM   #1
qtwre
Drives: White FR-S
What is the expected vacuum reading at idle?
I'm trying to diagnose a potential vacuum leak and it would be good to know what I should be expecting at idle. If anyone could take a look at their boost gauge or obd2 readout it would be most helpful.
Thanks
qtwre is offline   Reply With Quote
Old 08-12-2014, 09:41 AM   #2
Admired
Drives: 2013 Scion FRS
Admired is offline   Reply With Quote
Old 08-12-2014, 09:46 AM   #3
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I believe mine is around -60kpa (-17.72 inHg). Defi boost gauge hooked up to the brake booster line.
HRTROB is offline   Reply With Quote
Old 08-12-2014, 10:27 AM   #4
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I pull ~ -20 @ idle. That's measured using the P3Cars gauge reading from the OBDII port.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-12-2014, 10:46 AM   #5
sw20kosh
Drives: 2013 Black FR-S
-20
The Following User Says Thank You to sw20kosh For This Useful Post:
SoundsOfTheUniverse (03-20-2016)
Old 08-12-2014, 10:49 AM   #6
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
-19 AEM Boost gauge, brake booster source. If I recall correctly when I had a vacuum leak I still read the same on my gauge. I found out through the fuel trim in the EcuTek logs that it was most certainly a vacuum leak due to lean AFR's.
Edit: Good read for common vacuum leaks - http://www.ft86club.com/forums/showthread.php?t=62709
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
Kris86 (05-03-2017)
Old 08-12-2014, 10:54 AM   #7
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Your idle should bounce a bit but a strong idle is -18 and up
Old 08-12-2014, 11:13 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
On the new WRX (still FA20 block) at idle the dash boost gauge reads -9PSI, sometimes as low as -10 PSI momentarily.
Probably the same as the FA20 as idle is off boost.
Old 08-12-2014, 11:50 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
PSI is not equal to inHG which is what omst gauges read.
Idle should be -18 to -21 inHG.
Old 08-12-2014, 11:51 AM   #10
Sportsguy83
Drives: Limited BRZ
Similar, but not same because not same motor compression, not same intake manifold siz, etc.
Old 08-12-2014, 12:34 PM   #11
qtwre
Drives: White FR-S
Thanks guys. Mine reads around 20in/hg from my obd2 readout but it still behaves as though there is a leak with a high/bouncy idle when warm.
Old 08-12-2014, 01:45 PM   #12
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Injector scaling and fuel trims may be an issue more so than a vacuum leak. Without knowing anything about your setup though that's just me pissing in the wind.
Old 08-12-2014, 02:25 PM   #13
qtwre
Drives: White FR-S
Interesting that you mention fuel trims because I find my idle is always reading in the -20s. That means it's pulling fuel, right? While a vacuum leak would be causing it to add fuel? Is -20 a lot?
Here is a short Ecutek log in case you or anyone else is interested in taking a look. My issue is that once the car is warm, when I disengage the clutch (press the pedal) while in motion, it keeps the RPMs at around 2k (sometimes it bounces instead.) Sometimes it even propels me in gear with no throttle at 2k rather than slowing to idle. This persists until I put the transmission in neutral and re-engage the clutch. It will then idle nicely so long as it's spinning the input shaft.
So this log is of me moving slowly in a parking lot, then the clutch pedal is pressed and I'm rolling for a few seconds, then stopping.
I'm going to have my mechanic check for a vacuum leak tomorrow because I can't find one by eye and poking around.
This is with a stock fuelling system and AVO turbo.
Old 08-12-2014, 09:45 PM   #14
Admired
1 inHg = .5 PSI
vacuum at idle/decel jamesm Engine, Exhaust, Transmission 7 09-07-2013 07:04 PM
Seeing more than expected? CLTBRZ BRZ First-Gen (2012+) — General Topics 26 07-09-2012 03:47 PM
Expected Price of car in 3-5 years? FRSDREAMER Scion FR-S / Toyota 86 GT86 General Forum 72 03-20-2012 06:44 PM
BRZ expected to be at LA Auto Show MF_DEUCE Southern California 9 10-18-2011 09:21 PM
Not what I expected. Casual Scion FR-S / Toyota 86 GT86 General Forum 34 11-23-2010 07:25 PM
