Old 08-12-2014, 03:20 AM   #183
steve99
Drives: FT86
Originally Posted by dtek View Post
OK, thanks for the input but not having any luck.
In RR (version 0.5.8) I can open the BINs, it warns of a corruption or checksum issue but still opens the tables, all looks OK. Then when I do a 'save as' it prompts to proceed to correct checksums, which I 'ok' of course.
In OFM, when I try to import the new BIN, I get these three pop ups in sequence:
https://imgur.com/a/8dqFg
So end result is, no adding of the map to OFM possible. Pretty frustrating.
Are you using windows 8 if so have you loaded the windows 8 patch from the openflash site, that might be the problem
Old 08-12-2014, 05:13 AM   #184
dtek
Drives: 86 A00I
No, Win7 as a VM on a mac, pretty sure the VM wouldnt be a problem as I am sure Shiv uses a similar setup.
dtek is offline   Reply With Quote
Old 08-12-2014, 05:42 AM   #185
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Can you download the ots 1.59 maps and see if they load correctly?
Old 08-12-2014, 05:53 AM   #186
steve99
Drives: FT86
+1on what @Wayno said above trying 1.59 maps from openflash.
only other thing i can think of is delete all the tunes in the 5 slots and delete the .dev data file as your oft probably came preloaded with .dev database tunes and your now trying to load .bin tunes, you cannot mix the two, its one type or the other.
Old 08-12-2014, 08:13 AM   #187
dtek
Drives: 86 A00I
I'm currently running 1.59 stage 1 OTS tune in the car. The OFT straight out of the box didn't want to play nicely with my ECU – it wouldn't recognise the preloaded dev tunes whatsoever.... ie, the OFT when initially plugged to my ECU (after connecting online to DL the latest firmware, then reading the OEM tune, etc) decided there were no Shiv tunes on it at all.
Only way round that: to load up the OTS BIN tunes dowloaded from the website (Thanks to Dean's advice on that one). So I have gone through manual adding of tunes to the OFT, worked fine with Shiv's files, and they upload to the car no worries.
I'm back to square one though – there is something about these 'aussie' tunes which is either corrupted or some other techical problem to do with the checksum. Unfortunately I don't know enough about software in this context or on this platform to make any further educated guesses.
Admittedly, I haven't tried opening the page 1 98RON G tune and copy/pasting the ignition values and saving as a new file... but I would like to solve the mystery of why only my checksum errors seem unsolvable, seems like a good technical skill to acquire...
While we're at it, here's a quick and not all that ideal log file: Is there enough knocking here need the Oz 98RON spec tunes?
http://datazap.me/u/dtek/stage1?log=0&data=1
Old 08-12-2014, 08:31 AM   #188
Wayno
Wayno's Avatar
"Deans advice". Are you in the Facebook group? You can try the original files edited by Dean there. Pm me if not.
Old 08-12-2014, 12:08 PM   #189
Kodename47
Kodename47's Avatar
Drives: UK GT86
When does the error occur? When you open the file in RR? If so, that's normal and doesn't affect the OFT as it does the Checksum correction for you.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-12-2014, 05:48 PM   #190
steve99
Drives: FT86
Looks like it would benefit cannot see the knock in that log but your IAM started at 0.81 and is recovering towards 1 so their was some knock previous to log.
Do you know what your stock ROM CALID is ? the OFT needs to see roms of same calid or it wont load if your car is quite new it may have an A02I or D00I rom, if you have loaded a tuned ROM from openflash you will inherit its calid which may not be same as the stock ROM.
Just post up your stock ROM and I will be able to tell you. shiv caters for 700I A00I and A01I.
Old 08-15-2014, 10:08 PM   #191
tmichel
tmichel's Avatar
Drives: Sonic Blue 2014 GT86
Hi guys new to this first not sure if this is in right format but any advice would greatly appreciated.
http://datazap.me/u/tmichel/86-first...data=1-8-10-11
tmichel is offline   Reply With Quote
Old 08-15-2014, 11:34 PM   #192
steve99
Drives: FT86
Look like knock is ok as IAM=1 but better if you log as below.
your long term fuel trims look a high do you have aftermarket intake ?
Do a run in 3rd gear from 2000 to redline full throttle
Also remove the VVT exhaust and VVT intake log paramaters and put in FLKC and Knock Correction(FBKC) instead , then post that up
Old 08-16-2014, 12:07 AM   #193
tmichel
tmichel's Avatar
Thanks Steve will do that
Totally stock except for the tune ,is raining at the moment will that make a difference
there was a run on that one in 3rd from 2000 to just over 7000
Old 08-16-2014, 04:52 AM   #194
steve99
Drives: FT86
haha missed that run
yes looking at kc learned their are a few chunky bits indicating knock, much easier to see if you log fbkc knock correction and flkc fine learning knock correction.
i woul load up my 98RON map from first post if you have a manual G rom or @Wayno has done the changes for auto, those maps from first post in thread will go a long way to getting rid of that knock ,
Old 08-16-2014, 06:00 AM   #195
TheRoadWarrior
Much damage?
TheRoadWarrior's Avatar
Drives: Renaultsport Clio200
Curious: is Australian 98-100ron fuel the same as the UK octane rating?
Over here the highest octane rating available is 99ron from tesco.
TheRoadWarrior is offline   Reply With Quote
Old 08-16-2014, 08:06 AM   #196
tmichel
tmichel's Avatar
Thanks Steve have been trying to load that map but still learning how to do it have the manual . Do I just delete one of the other maps off the OFT and then load into the spare slot ?
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
