Old 08-11-2014, 06:21 PM   #5167
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by sickmint79 View Post
hi guys looking for some advice wit plans to get the twin screw intercooled kit next year.
1. i see people getting the dw fuel pump upgrade, is this only necessary for e85? any other mods needed/good for e85 (injectors?)
2. how many people just stick with 93 and why? given the location of filling stations and the extra things to support e85 it seems i may just stick with 93 octane gas here in IL/midwest.
3. given different exhaust mods or oem how does a tuner's downloadable map handle all the possible combos?
4. what supporting exhaust mods are advised? should these be done prior to sc install?
5. i see the bolts on the manifold occasionally break, are there any harder ones advised to replace them with that have been found?
6. i plan on doing the forester oem type oil cooler kit, anyone have track temperature numbers with this setup? solo dl posted 270-277 my last time at the track (all n/a, no kit)
7. radiator upgrade must/nice to have?
8. advised intake vs. stock - does it help, which? i see delicious specifically calls out a perrin 3" CAI
9. seems the 69mm pulley on stage 2 kit is the new way to go?
10. i have 225 direzzas, will this push me to 235 245 for suresies? think i'll need to buy wider wheels (have 17x7.5 now)
thanks.
Looks like a lot of your questions were answered but just wanted to show what we offer in regards to the tune for the Innovate Kit and our recommendations from another tuning facility. If you did not have enough already.
1. We have seen no need to go with a larger pump or injectors on E85 up to our 69mm pulley. But we feel this is about the limit, but you could go smaller if the ethanol content was lower.
2. The one other option you have is FlexFuel so you could run 93 octane most of the time but if you had the option to use E85, you could just fill it up and enjoy the new found power. We are finalizing our FlexFuel Kit and should have it very soon. Otherwise or 93 octane tune works incredibly well with the 69mm pulley. Especially since it was tested on California 91 octane.
3. Our system works with just about any header and exhaust system, but we can review your logs to see if any adjustments are needed.
4. We currently run a stock exhaust system on our shop vehicle, though have seen some benefits with a nice set of headers and a custom tune, beyond the standard tune. Adjusting the cams and timing a bit can get you a little more.
8. We actually prefer the Airaid Intake of all the intakes for this vehicle. We have seen improvements on the the top end while also keeping the air relatively cool. The Perrin CAI seems to work similarly, better flow and cooler air.
9. We have tested the 69mm pulley pretty intensively for many heat ranges from LA traffic, to hot desert heat, all on 91 octane and have no problems with it. We have of course adjusted the tune for the new smaller pulley and it does make a little more on 91, so on 93 it will be even better. Our current tune will work on any pulley size you choose, 80, 75, 72.5, 70 or 69mm. So choose your poison and enjoy.
Cheers,
William Knose
Old 08-11-2014, 06:22 PM   #5168
DeliciousTuning
Originally Posted by calispec View Post
Is anyone's fuel trims going crazy with the new tune? I get values in the teens and twentys on both short and long term during normal driving. Wot is 0.00.
Positive or negative?
Positive would be a sign there is a possible vacuum leak.
Send an email if you like.
Cheers,
William Knose
Old 08-11-2014, 09:40 PM   #5169
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Cheers,
William Knose
long term pegs to the positive and short term pegs to the negative. I just took a log and sent it to you in an email.
Should I try reflashing and let the ecu reset? I am fairly certain that the car is mechanically fine but I have been wrong before..
Thanks Bill!
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 08-11-2014, 10:47 PM   #5170
Firestorm_86
Drives: FRS
Originally Posted by stevo585 View Post
I'm not biased here just stating they seem to dyno about the same numbers. You gotta love than whine though!
Also if their the same in hp how is it vs.? Only talking dyno numbers not the systems
Most of what I've seen shows that the ESC Phantom only works WOT. It doesn't really do a partial throttle or 'heavy' throttle. So getting the same numbers WOT isn't quite the same as overall improved drivability.
Firestorm_86 is offline   Reply With Quote
The Following User Says Thank You to Firestorm_86 For This Useful Post:
Khorne (08-12-2014)
Old 08-12-2014, 12:01 AM   #5171
DeliciousTuning
We have tuned a couple of these now. They are pretty good down low but they really do not make much power on the top end. Below is a dyno chart of the ESC versus the Innovate Supercharger Kit with an Intercooler and 69mm pulley on 91 octane.
It may not be a fair match up with, being you may expect a non-intercooled 75mm setup but most customers seem to run the Stage 2 package and usually go with a smaller pulley. That is from what we have seen at least.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Xero-Limit (08-12-2014)
Old 08-13-2014, 12:54 PM   #5172
DeliciousTuning
Cheers,
William Knose
I am no English major that is for sure. Need to work on my grammer. Lets' try that again...
It may not be a fair match up, being most people may want to compare the ESC to a non-intercooled Innovate 75mm setup. From what we have seen most customers seem to run the Stage 2 package and usually go with a smaller pulley.
Old 08-13-2014, 03:23 PM   #5173
Calum
That Guy
Drives: 2013 asphalt FRS MT
I just really liked seeing a rotrex kit and the sprintex kit dyno's from the same tuner and same dyno.
Old 08-14-2014, 02:12 AM   #5174
michael_king
Drives:
I'm running the CARB tune still. Once I'm warmed up I'm fine, but I usually drive once the cold start idle drops down. It's been stalling out when I'm stopped and in neutral. Any thoughts?
michael_king is offline   Reply With Quote
Old 08-15-2014, 10:03 AM   #5175
choi0706
Drives: t
anyone not use the MAP sensor extension?
choi0706 is offline   Reply With Quote
Old 08-15-2014, 10:09 AM   #5176
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Lefthand drive cars shouldn't need it. Mine plugged in just fine without it.
Old 08-15-2014, 04:14 PM   #5177
BrianBlueBRZ
Drives: 2014 BRZ
I don't really have a lot of time to be reading this thread but I wanna pick up a complete stage one kit. What can u guys ell me about it?? How much power will I gain and will I be happy with it? What can u tell me about stage 2 and the diff in power? If I buy the stage one complete kit can I just bolt that up and go and not have to worry about tuning or anything else if I'm just going to use it as a weekend casual driver Who just wants more power because it's too slow in stock form
BrianBlueBRZ is offline   Reply With Quote
Old 08-15-2014, 04:24 PM   #5178
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Whe tuned your car?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 08-15-2014, 05:58 PM   #5179
michael_king
Drives:
Originally Posted by Boofneenee View Post
Whe tuned your car?
It's the stage 1 CARB tune that comes with the stage 1 complete kit. So it's technically a delicious tune but they don't offer support unless you buy a tune from them not innovative.
Old 08-15-2014, 07:11 PM   #5180
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Gotta love that crap. The guys at OFT will review and offer support regardless if its a base or custom map. Either you installed it wrong or their is something wrong with their idle data.
FRS
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
