Old 08-11-2014, 04:21 PM   #1
sidebrake
Drives: '14 BRZ Limited
Question on rear toe
Hi Fellow FT86 Owners,
I'm preparing to install 18 inch wheels with coilovers and adjustable RLCA. Is an adjustable rear toe arm necessary if I want to zero out the rear toe or will I be able achieve zero with the stock toe arms?
I'm aiming to dial around -1.5 degrees of rear camber and only lowering enough to eliminate the wheel gape. Thanks to anyone that can provide some info on this.
-SB
sidebrake is offline   Reply With Quote
Old 08-11-2014, 04:48 PM   #2
Ubersuber
Drives: BRZ Pearl White
Just BTW I'm running 1.6 degrees negative with just Subaru camber bolts in the LCA.
If you lower the car you'll get more negative camber to begin with.
Unless you want even more extreme camber you should need a LCA.
Can't help you with the toe question.
Ubersuber is offline   Reply With Quote
Old 08-11-2014, 04:55 PM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I didn't realize subaru made camber bolts for the rear.
Using upper control arms is the "preferred" method of adjusting camber without changing geometry.
JDKane527 is offline   Reply With Quote
Old 08-11-2014, 05:10 PM   #4
wparsons
wparsons's Avatar
If you're going to need toe arms or not will depend on how much the camber is adjusted from what it naturally is for your ride height.
If you're dialing camber back to ~1.5 from ~2, then the stock toe arm should probably have enough adjustment.
A ~1" drop will put you around -2* in the rear without any adjustment, so if you want less you'll need adjustable arms (upper or lower) for sure. Upper arms are nice because they don't screw up the toe setting, but are more expensive and not as easy to adjust on the car.
flickr
Old 08-11-2014, 05:55 PM   #5
sidebrake
Thanks Wparson,
I know for sure I will need an adjustable upper or lower arm to properly correct the rear camber after lowering with the coilovers. I'm just concerned about the stock toe arms not having enough adjustments to zero out after lowering and adjusting the camber, but sounds like I should be able to get zero with the stock toe arms based on your reply right?
Old 08-11-2014, 07:26 PM   #6
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
You can handle toe corrections with the OEM links but camber can be excessive if you lower too much. Remember you don't need as much static camber with the FRS/BRZ as gain negative camber as the suspension compresses.
Aftermarket links are more about correcting the camber and reducing geometry changes from high load cornering.
I wouldn't rush to zero toe with the OEM arms however since there's a lot of dynamic toe changes. With aftermarket arms that will hold the geometry more true you can go straight there
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
CSG Mike (08-13-2014)
Old 08-11-2014, 09:09 PM   #7
wparsons
wparsons's Avatar
You *should* be totally fine without aftermarket toe arms. Keep it in the back of your mind that you might be limited to how much camber they can dial out just in case, but you really shouldn't have any issues at all.
flickr
Old 08-12-2014, 12:23 AM   #8
sidebrake
Phil,
Thanks for your input, that makes a lot of sense. Basically I should be fine with stock toe arms and setting toe to zero shouldn't be a problem but aftermarket arms will hold the alignment/geometry more true when suspension is under load. Gotcha.
Old 08-12-2014, 12:30 AM   #9
sidebrake
Ok, I see. The amount of camber that can be dialed back out will depend on how low the coilovers are set right?
Old 08-13-2014, 12:43 AM   #10
Element Tuning
Exactly so if you run very low you will have too much negative camber for optimal grip. You'll be hellaflush doe
TRD rear bumper question ciotime Cosmetic Modification (Interior/Exterior/Lighting) 18 10-29-2018 12:59 AM
KW Rear Top Hat Question Sikkwidit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 08-07-2015 01:36 AM
SPC rear camber arm question Chopstick Northern California 6 06-10-2014 12:18 AM
Rear diff LSD question Dephective Engine, Exhaust, Transmission 15 09-01-2013 06:30 PM
TRD Rear Lip question/opinion DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 2 08-18-2012 02:50 PM
