Old 08-11-2014, 10:25 PM   #183
chkltcow
Drives: 2013 FRS White w/ cone marks
Originally Posted by AustinTX View Post
Pressure: 38F/36-38R pressures were working the best. Considerably higher in the rear than most have been running, but it gave the car the best balance to me.
And that's on 235s? I'm curious to see how this weekend goes. I'm going to the Virginia AutoX Championships and we're going to try to swap my SoloStorm between my car and my friend's. I'm on 215 RS3s... he's on 235s. I settled on 40F/34R as my happy point... but I don't know what he's running. I'll pass on your info about pressures to him if you're on the 235 RS3s like he is.
chkltcow is offline   Reply With Quote
Old 08-11-2014, 10:53 PM   #184
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I'm on 245's
Autocross nut
AustinTX is offline   Reply With Quote
Old 08-12-2014, 05:54 AM   #185
chkltcow
I'm on 245's
Thanks for making my 215s feel inferior! :p
Old 08-12-2014, 08:31 AM   #186
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I'm on 245's
Between the three of us, we have the whole gamut covered. I'm on staggered 225 & 235, right in the middle.
bimmer635csi is offline   Reply With Quote
Old 08-12-2014, 01:39 PM   #187
Biggins
Drives: Yes
I drove home on the RS3v2 this weekend and noticed they are annoyingly loud, is this common for these tires? I had to turn my radio way up to drown it out.
Biggins is offline   Reply With Quote
Old 08-12-2014, 01:41 PM   #188
Jawnathin
Drives: Toyobaru FRZ
On Sunday, I ran with the local club. I had a consistent understeer at the practice, so I decided to try setting some rear toe out Saturday night. I changed it from 1/8" in per side to 1/8" out per side. The car still drove straight and had no odd behavior in a test drive, so I drove it to the event and ran it that way. Result: pretty dang good. The car had just a bit of extra turn in before stabilizing into normal understeer. The car was fast all day, and I ended up 2nd in X class, 3rd in PAX. Looks like I've found my setup for nationals, and just in time
Nice work on dialing it in time for Nationals. Best of luck and I'm looking forward to seeing how it turns out. This year will be very interesting.
I'm still in the process of dialing in my car now and am starting to look at alignment changes. Do you mind sharing whatever guide/thread you used (if there was one) for adjusting toe & alignment? I might want to try it for my next event as I felt the car was a little pushy with its current setup.
I wouldn't mind a little better turn in and better rotation upon corner exit for these higher speed 90 degree turns the local club likes to run. I think a bit of toe out on both front and rear should help with that.
Also, did you feel you lost any transitional stability upon the tow adjustment?
Thanks.
Jawnathin is offline   Reply With Quote
Old 08-12-2014, 01:55 PM   #189
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Common for most hardcore street tires. The older they get, the louder they'll be too.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-12-2014, 02:10 PM   #190
AustinTX
AustinTX's Avatar
Thanks.
I used flat plates on each wheel and tape measures to check/set toe. The change did not destabilize the car, just seemed to improve the early to mid corner rotation. Mid corner to exit stability was not significantly affected, IMO.
Why don't I remember meeting you or Chris yet? We're all running at the same events in the same car
Autocross nut
Old 08-12-2014, 02:37 PM   #191
AustinTX
AustinTX's Avatar
I'm sharing everything I've done all year with the hope that we can all do well at nationals. We're all team mates here
I think all current cars will stay in CS, with the 370Z adding a bit of a course dependency twist to the class. Initially, I figured this car was done for in CS. Now, I'm not so sure. It'll take a heckuva drive, though.
Autocross nut
Old 08-12-2014, 03:03 PM   #192
Biggins
Drives: Yes
True, but my 120+ run AD08R's are totally silent and my wearbar ZIIs are not THAT bad. I'm definitely not driving 18 hours on the RS3v2s to Lincoln!
+1 and thanks for posting. I assume you're still using the Perrin bar too? I'll try to drop by and meet you in a few weeks at Nats. I think we have a nearly identical set-up except I'm on 235 RS3s.
Old 08-12-2014, 03:29 PM   #193
bimmer635csi
We just haven't been formally introduced. I was on grid during your heat in the big straw hat and the "Beer, its cheaper than gas" t-shirt.
Old 08-12-2014, 05:42 PM   #194
Jawnathin
Thanks so much. Now that you bring it up, I think I remember reading up on that DIY, I might give it a shot. I could benefit from some better mid corner rotation. Still have the Konis and air pressures to play with to try to balance the car too.
I assume you bring that up since I had my location as SA TX at some point. I did have that in my location not long ago, but that isn't where I am. Sorry for any confusion. I've since changed that to be even less descriptive .
Just got the car setup very recently, so depending on how things work out between now and into next year, giving Nationals a shot is on the table for 2015. Still have a way to go before I would consider myself and the car competitive, but it would be a pleasure to meet you then.
+1! Thanks so much and completely agree. I've shared my notes with many of the local 86 guys. Taking them for rides, riding with them, being open with feedback as it relates to course lines, car setup, etc. In my opinion, the better the competition we face, the more we develop and grow ourselves.
Old 08-12-2014, 07:20 PM   #195
renfield90
The Stig's German cousin
There is a decent argument to move the twins out based purely on registration numbers - I think it's almost half the class. Hell, they carved out a brand new AS for cars that couldn't cut it in SS, and there are roughly as many twins entries as there are AS entries (that's a good line, I'll put that in my letter).
There is a strong argument to change nothing if the Miata wins. And there's a strong argument to move the 370 out if it wins and locks out most of the trophies.
I'm hoping for the last of these scenarios as it's realistically the best shot we'll have for next year - if you look at the Prosolo points standings, it's a little depressing. It's going to be rare that a Miata beats a twin.
Old 08-13-2014, 08:26 AM   #196
piknockout
Drives: 2014 BRZ
Let me rephrase that for you: "I'm so much better than all of you that you can have all of my setup notes and information...and I'll still beat your @ss."
:p
piknockout is offline   Reply With Quote
The Following User Says Thank You to piknockout For This Useful Post:
Kido1986 (08-13-2014)
DC's Progression Thread. DC@RoadRace Member's Car Journals 8 11-10-2014 09:22 PM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
[Elysiam]Kayhettin's 1st '86 Firestorm 6MT Progression kayhettin Member's Car Journals 1 12-06-2013 08:01 AM
What is your progression with Toyotas? WLY AFRICA 26 11-18-2013 01:08 PM
