Old 08-11-2014, 06:54 PM   #1
merino_frs
merino_frs's Avatar
10mm bolt broke
Hey guys,
So I was installing the Supertek hood damper kit and I was almost done when the 10mm bolt from the drivers side broke off. The threaded part is still inside the hole and the top half is in my hand. Any suggestions on how I can take it out? Thanks guys!
merino_frs is offline   Reply With Quote
Old 08-11-2014, 07:07 PM   #2
gramicci101
Off Topic
Drill a hole into the threaded part, then use an easy-out to back it out.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
merino_frs (08-11-2014), Trap63 (08-11-2014)
Old 08-11-2014, 08:00 PM   #3
merino_frs
merino_frs's Avatar
Thanks! I'll try that out.
Old 08-11-2014, 08:03 PM   #4
gramicci101
Off Topic
How did the bolt break? Those aren't torqued super tight, and they're pretty large bolts. Just a manufacturing defect?
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 08-11-2014, 08:04 PM   #5
merino_frs
merino_frs's Avatar
No idea. I was tightening the bolt and it just snapped. I think I might of tighten it too much.
Old 08-11-2014, 08:13 PM   #6
Chimera
Drives: FRS
They are all sheer (think I spelled that right) bolts. They are supposed to break if stressed.
Old 08-11-2014, 08:29 PM   #7
merino_frs
merino_frs's Avatar
By any chance would you guys know the part number for that specific bot?
Old 08-11-2014, 08:45 PM   #8
stevesnj
stevesnj's Avatar
Just take a bolt from the other side and bring it to autozone and match it up
The Following User Says Thank You to stevesnj For This Useful Post:
Wheel spacers 5x100 10mm and 20mm Teku18 Wheels and Tires 3 03-12-2017 08:55 PM
Broke the stock overpipe bolt :/ Sniper2606 Engine, Exhaust, Transmission 44 04-26-2015 01:19 AM
seibon 10mm front fender. anyone have it? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 11 12-01-2013 10:32 PM
18x8 +40 WITH 10mm spacer? LFA wheels :) jacobzking Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 06-06-2013 02:11 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
