Old 08-11-2014, 05:11 PM   #15
BRZUK
Drives: GT86
Originally Posted by Kiske View Post
You can easily do your fuel pump instal before hand. Make sure it is running right well before the avo kit is added. Same with the clutch. May also consider getting any scanning/guages you may need before-hand.
scanning ? sorry i don't understand.
BRZUK is offline   Reply With Quote
Old 08-11-2014, 06:47 PM   #16
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Some guages run off your vehicles OBD2 port. These guages usually display a variety of information in real time.
Old 08-11-2014, 06:57 PM   #17
BRZUK
Drives: GT86
Thank you for clearing that up.
Old 08-11-2014, 07:27 PM   #18
Squishy
Drives: 2013 WRB BRZ
STI BRZ engine mounts! I just went and did the transmission mounts along with it.
The stiffer rubber keeps the engine movement down to a minimum with little to no increase in NVH. This I had to do as even with my mounted intercooler - it rocked enough to work one of the intercooler couplings off. Boost leak!
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
Old 08-11-2014, 07:35 PM   #19
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by solus View Post
I'm in the process of doing the same kit... I would suggest a full exhaust, OP/FP and catback.
My question is oil cooler... how necessary is it? Mine will be DD zero to very little track use.
In the long run the oil cooler will help keep the viscosity nice when the IAT's go up. Thinner oil as the IAT's go up means you could have a spin bearing potential loss on your hands. Not something worth risking. This car's engine bay runs not just hot but hawt. I would reccomend the oil cooler, larger radiator, you could look into potential functional side venting or a vented hood; trust me it helps.
Old 08-11-2014, 07:42 PM   #20
BRZUK
Drives: GT86
How is an engine mount installed can it been done my someone handy with tools or are you looking at a shop to do the job?
Old 08-11-2014, 10:23 PM   #21
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Calum View Post
Your use of quotation marks.
I just mean that I would get a thermostatically controlled oil cooler. Hence that...
Old 08-11-2014, 10:31 PM   #22
Squishy
http://www.ft86club.com/forums/showp...0&postcount=29
This step by step is what I used to do it myself - took longer to take off the bumper and loosen intake tubing to allow the lifting of the engine about 5-6 inches. This is needed for clearance to slide out the mounts. you should not need to take off the bumper like me.
You do not need to loosen the engine braces. I did this with jack stands and a typical hydraulic jack. 14mm sockets for the bolts and extensions to get leverage on the socket wrench but that was it. Took me about 20 minutes for swapping the actual engine mount and transmission mounts. the rest took about 30-45 minutes to take off the covers and put them back on since I was trying to find a boost leak in the piping couplers. Honestly you only need to undo the intake tube from the airbox so the bumper would stay on. This assumes you do this before having an FI kit installed.
Dale Earnhardt
Old 08-12-2014, 05:28 AM   #23
Calum
That Guy
Drives: 2013 asphalt FRS MT
oh, so the quotation marks were to emphasize those words. I get it.
The Following User Says Thank You to Calum For This Useful Post:
OICU812 (08-12-2014)
Old 08-12-2014, 11:07 AM   #24
BadBRZ
Drives: Subaru
Why you say that? Do you not the the AVO kit? and why.
@Sportsguy83
^thats why
BadBRZ is offline   Reply With Quote
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
