Old 08-10-2014, 06:00 PM   #1
BRZUK
Drives: GT86
Prep for forced induction
Hi guys,
I plan to go Avo Stage 2 Turbo kit in about 6 months and i am trying to do all my prep ( everything thats needs installed before turbo ) now.
My powers goals are 280 WHP to achieve this i will be buying the following:
Avo Turbo Kit with ceramic coating.
Avo Breather System
3 bar map sensor
Clutch
Oil cooler
Oil cooler will be going on the car when the turbo kit is i want to reframe from removing the front bumper more times than i have to.
My questions are:
Pistons and rods do i need them for my power levels? I think not but would like your thoughts on this.
Brakes, do i need a BBK or will discs, pads, SSL and fluid swap be enough i do not track the car nor will i be in the future.
What other supporting mods would you install yourself to keep the car reliable as possible.
Thank you very much guys for your help learn so much for this forum and hopefully about to learn more.
BRZUK is offline   Reply With Quote
Old 08-10-2014, 06:55 PM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
With what you said no tracking then you've already covered the needs. No need for brakes etc..
The only thing from your supporting mods list I'd ensure of is that your Oil Cooler is thermostatically controlled "at least I would"..
Under 300 RWHP you should not require any internals. Your main concern should be a quality tuner who will tune your kit to a safe and reliable margin. Not knowing shops where you live leaves out a suggestion for that portion.
Old 08-10-2014, 07:45 PM   #3
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Under 300whp won't require internals on the engine to be done, as long as your tune is solid.
My own personal list would be this:
Pad/Rotor upgrade because it's really easy to get up to speed on the street
Clutch (Stage 1 organic is enough)
Oil Cooler (I went FBM so it didn't block the intercooler)
Boost Gauge
AFR Gauge
Exhaust (overpipe, front pipe, cat back)
Intake (panel filter is fine)
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 08-10-2014, 08:09 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Who are you quoting?
Old 08-10-2014, 08:57 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
You can easily do your fuel pump instal before hand. Make sure it is running right well before the avo kit is added. Same with the clutch. May also consider getting any scanning/guages you may need before-hand.
The Following User Says Thank You to Kiske For This Useful Post:
Basket Case (08-10-2014)
Old 08-10-2014, 09:58 PM   #6
OICU812
Just a dude
OICU812's Avatar
I was responding to the OP was not quoting anyone why?
Old 08-11-2014, 03:22 AM   #7
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
add clamps on every possible line that may cause a leak down the road, because it will
glamcem is offline   Reply With Quote
Old 08-11-2014, 05:07 AM   #8
Calum
That Guy
Your use of quotation marks.
The Following User Says Thank You to Calum For This Useful Post:
jebuwh (08-11-2014)
Old 08-11-2014, 05:16 AM   #9
HRTROB
HRTROB's Avatar
Drives: Toyota 86
If you think you will need a bigger radiator, better do it now before you go FI. Install is a breeze when NA but a PITA once you go FI because of all the additional piping
HRTROB is offline   Reply With Quote
Old 08-11-2014, 01:00 PM   #10
BadBRZ
Drives: Subaru
I'd start by selecting a differant turbo kit, then (depending on power lvl) get supporting mods.
Just a turbo kit and tune should get you 260-280, start throwing in exhuast injectors fuel pump etc you can get 350 on pump 500 on e85. Of ourse by that point you'll want a built block.
Etc
More power = money^n
BadBRZ is offline   Reply With Quote
Old 08-11-2014, 03:57 PM   #11
solus
Drives: 2014 Scion FRS (Ultramarine)
I'm in the process of doing the same kit... I would suggest a full exhaust, OP/FP and catback.
My question is oil cooler... how necessary is it? Mine will be DD zero to very little track use.
solus is offline   Reply With Quote
Old 08-11-2014, 05:04 PM   #12
BRZUK
Drives: GT86
Now that you have said i will buy one was looking that koyorad radiator. What one would you personally go for, thank you.
Old 08-11-2014, 05:05 PM   #13
BRZUK
Drives: GT86
Etc
Why you say that? Do you not the the AVO kit? and why.
Old 08-11-2014, 05:07 PM   #14
BRZUK
Drives: GT86
Thank for the advise on that one.
The Following User Says Thank You to BRZUK For This Useful Post:
glamcem (08-11-2014)
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
