Old 08-11-2014, 01:53 PM   #43
Firestorm_86
Drives: FRS
Originally Posted by themajesticone View Post
After what you mentioned in the other thread and this thread regarding post modification to the Bilstein coils I am reconsidering my options. I was not aware that was possible. Darn you! lol
I think they're conspiring against us...
Firestorm_86 is offline   Reply With Quote
Old 08-11-2014, 01:58 PM   #44
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Originally Posted by Firestorm_86 View Post
So your recommendation would be to go big or go "RaceSeng CasCam plates, SPL Rear LCAs, and Swift Spec-R springs on stock dampers"?
TEIN's weren't in his initial list. I know you guys love your SRC's. What about the rest of the TEIN lineup, specifically the Mono Sport and Street Flex? It seems the KW's and RCE's get a lot more attention for the $2000 price range.
Is there really nothing between just springs and $2000 coilvers that would ride nicely on the street but be an improvement, however minor, on the track?
The way you have to look at it is that coilovers are damper upgrades as well. What you're paying for with coilovers is the quality of the damper, for the most part.
You can always get springs and Koni/Bilstein/etc dampers.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
themajesticone (08-11-2014)
Old 08-11-2014, 02:19 PM   #45
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Serious! I think I am still going to go the swift spec r spring/HVT/SPL progressive upgrade path, just because I realistically shouldn't be throwing $1.5k+ down at one time. But it is tempting...
themajesticone is offline   Reply With Quote
Old 08-11-2014, 02:25 PM   #46
CSG David
CSG David's Avatar
Hey David! So we talked briefly before, and I'm still doing research...
What's you and Mike's take on: ST or B14's (or TEIN's)?
ST Suspension & Bilstein B14 require the use of OEM top hats. You can certain use a Raceseng CasCam plate if you want so you can get full camber adjustments. They are good lowering setups with no need to "headache" over damper adjustments for desired setup.
The TEIN Street Basis is a basic lowering coilover that is designed for street use. Don't expect to have mindblowing performance with these coilovers. They are designed to look good and be comfortable. Obviously be smart with how you setup the height. Slammed doesn't always equate to pimp daddy status when the girl hates the ride.
Old 08-11-2014, 02:26 PM   #47
CSG David
CSG David's Avatar
Serious! I think I am still going to go the spring/HVT/SPL progressive upgrade path, just because I realistically shouldn't be throwing $1.5k+ down at one time. But it is tempting...
There are several setups to go with. Obviously develop your driving application, goals, and budget. We can create a modular setup that accommodates the parameters.
The Following User Says Thank You to CSG David For This Useful Post:
Old 08-11-2014, 02:32 PM   #48
Firestorm_86
Drives: FRS
Actually, that's quite the problem already, she's not quite pleased with the ride. So softer on a DD basis is desired. Then the ability to tweak for the mountains when needed.
Also, how about the other TEIN offering/Mono Sport?
Old 08-11-2014, 02:37 PM   #49
CSG David
CSG David's Avatar
I would just find a comfy setup and dial in your alignment. You can always manipulate how the way the car dances by weight transfer. TEIN Mono Sport is tailored more towards tracking...it's a little rough around town...
Old 08-11-2014, 02:48 PM   #50
Firestorm_86
Drives: FRS
Direct me to that comfy setup!
Go Ohlins or go home is not a valid reply.
Old 08-11-2014, 02:56 PM   #51
CSG David
CSG David's Avatar
Oh. Penske/Ohlins/Sachs custom valving...$25k.
Old 08-11-2014, 03:07 PM   #52
Firestorm_86
Drives: FRS
And what about for the $1000-1100 price range and the $1500-1600 price range?
Old 08-11-2014, 03:15 PM   #53
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
*cough*oemdampers+springs+tophats+LCA*cough*
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following User Says Thank You to Turkish For This Useful Post:
Old 08-11-2014, 03:34 PM   #54
Firestorm_86
Drives: FRS
*cough* that might be the choice for performance/dialed in alignment, but I don't recall an option for a more comfy ride...
Old 08-11-2014, 03:53 PM   #55
CSG David
CSG David's Avatar
~1k coilover?
ST Suspension, Bilstein B14, TEIN Street Basis. (notice only height adjustment available)
Performance on stock suspension for ~$1.2k?
Raceseng CasCam, SPL Rear LCA (notice only alignment setup)
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Firestorm_86 (08-11-2014), themajesticone (08-11-2014)
Old 08-11-2014, 04:27 PM   #56
Racecomp Engineering
If you do track the car and are comfortable with -3 or so degrees front camber (and all that comes with that), then camber plates + rear LCAs is not a bad way to go if you only have that much cash to spend. It gets you good gains and you can keep the parts if you upgrade to quality coilovers or a strut + spring package down the line.
If it's more of a 98% DD street car with some fun track time thrown in when you can, then I would go a different route. The reason I say that is that when you upgrade your shocks, it's a more noticeable improvement on the street. Not "faster"...just a better drive for me personally. At the track, you'll likely increase cornering speeds more with a bunch of camber, but the drive on the street even when not pushing the car to the limit will be more enjoyable with a good shock and spring package AS LONG AS your alignment is still pretty good and balanced, meaning at least get camber bolts.
To keep it under 1500, this package with the WL rear LCA upgrade would be tempting.
http://www.ft86speedfactory.com/ft-8...-rce-1081.html
Koni Yellows
RCE Yellows
front camber bolts
Whiteline rear LCA
Maybe swap the Konis for Bilsteins but you'll just barely go over the 1500 mark. Or go with Bilstein B14 or ST coilovers if you really want height adjustability (I'm fine with a set 20mm drop).
Or go without the rear LCA and spend the money saved on something to make your gf/wife/whatever happy. And pizza and beer. And entry fees. Probably brakes too.
- Andy
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
BRZ21 (11-19-2014), MidnightRunner (08-11-2014), Tanstin (05-19-2020), themajesticone (08-11-2014), unsurety (08-11-2014)
The ISC Suspension-NA N1 Coilover System for the BRZ/FRS ISC Suspension Brakes, Suspension, Chassis 17 04-29-2014 09:56 AM
Can shock-dynos tell you what the highest spring rate it can handle? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 02-16-2014 04:43 PM
coilover shock body height adj garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-19-2013 03:32 AM
