Old 08-09-2014, 12:16 AM   #29
sickmint79
Drives: bmw
85 degree day stock engine and tune i have my oil rendered on the vid and over 270... 180-185 coolant on my fast lap 270-277 oil per solo dl
[ame="https://www.youtube.com/watch?v=CL5OeHDvIHc"]Subaru BRZ at Autobahn race track in joliet with mvp track time - YouTube[/ame]
sickmint79 is offline   Reply With Quote
The Following 2 Users Say Thank You to sickmint79 For This Useful Post:
AZP Installs (08-10-2014), CSG Mike (08-09-2014)
Old 08-09-2014, 03:33 AM   #30
CSG Mike
CSG Mike's Avatar
I'm assuming no oil cooler and NA?
Old 08-09-2014, 09:46 AM   #31
sickmint79
Drives: bmw
yes that is correct. no cooler no sc. ordered parts to make the forester oem cooler, planning to go twin screw eventualy, methinks.
Old 08-09-2014, 10:20 PM   #32
sw20kosh
Drives: 2013 Black FR-S
@CSG Mike @CSG David I am curious to see data of your iats vs ambient while on track and while cruising.
Old 08-10-2014, 06:47 PM   #33
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Coolant temps seem real low unless you are just heading out of the pits on a cold engine. I'm seeing similar oil temps on my stock setup as well for Oil but hitting 196-200 on coolant temps with the Koyo Racing Rad.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 08-10-2014, 08:07 PM   #34
sickmint79
Drives: bmw
lap 5, over 15 min in. toyo_ect says 180 to 185. i'm confused because toyo_iat also says 68 to 73 and it was 85 out - that sounds quite off no?
Old 08-10-2014, 08:10 PM   #35
AZP Installs
Yes definitely sounds off. On my car which is essentially stock, IATs are at best 7-10 deg OVER ambient. If your engine was running at 180-185 I would think there is a T-stat issue perhaps.
-Mike Paisan
Old 08-10-2014, 08:49 PM   #36
sickmint79
Drives: bmw
hmm how would i identify that ?
Old 08-10-2014, 08:54 PM   #37
sw20kosh
-Mike Paisan
@mkivsoopra
Aim solo DL has a bug for coolant temps. Coolant reads 18 deg lower on aim solo
Old 08-10-2014, 08:58 PM   #38
AZP Installs
Originally Posted by sw20kosh View Post
@mkivsoopra
That solves the coolant temps. What about the IATs?
-Mike Paisan
Old 08-10-2014, 09:30 PM   #39
mkivsoopra
-Mike Paisan
I believe someone mentioned that Coolant, IAT, and ambient are all offset by 18F: http://www.ft86club.com/forums/showp...7&postcount=30
I confirmed that Coolant is off, and AiM acknowledged that it's a bug that they're fixing. I didn't ask about the other temperatures, but hopefully they wil be addressed as well. Oil temp appears to be correct.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
sickmint79 (08-10-2014)
Old 08-10-2014, 11:39 PM   #40
CSG Mike
CSG Mike's Avatar
IATs are usually around 30-35F over ambient, regardless of ambient temperature, when running hard sessions on track.
During cruising, IAT is ambient. For single WOT pulls, you can watch IAT climb with boost, and drop back down as soon as you go partial or lift, but nothing crazy.
Old 08-10-2014, 11:40 PM   #41
CSG Mike
CSG Mike's Avatar
IAT can't be off, because it has AAT, and IAT usually matches AAT when under light load (cruising), which is what it should be.
mkivsoopra (08-10-2014)
Old 08-11-2014, 11:52 AM   #42
sw20kosh
My cruising IAT is always 10 deg warmer than ambient. I am guessing either because:
1. ptuning air filter is in engine bay
2. oil cooler is in front of IC
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 03:08 PM
Robi-Cooler Install....Oil Temps under 180??? Deep Six Engine, Exhaust, Transmission 28 08-07-2014 12:30 PM
Oil Temps Fish Eagle AFRICA 13 07-22-2014 05:53 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
