Old 07-25-2014, 03:56 PM   #1
radroach
Drives: car
Priming the oil filter
Hi doing an oil change today. Do I need to prime the oil filter or can I just put a little oil on the seat and screw it on?
The Following User Says Thank You to radroach For This Useful Post:
ZionsWrath (07-25-2014)
Old 07-25-2014, 04:00 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
I just fill it with oil before I put it on. Very easy on this motor since oil filter is directly on top, won't even spill a drop.
Overall though I don't think it matters too much or manufacturers would specify to do it in the shop manuals.
The Following User Says Thank You to ZionsWrath For This Useful Post:
gramicci101 (07-25-2014)
Old 07-25-2014, 04:01 PM   #3
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Considering the filter location and position when installing all priming it will do is make a mess.
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
evan (07-25-2014)
Old 07-25-2014, 05:13 PM   #4
evan
Drives: fr-s
What he said.
evan is offline   Reply With Quote
Old 07-25-2014, 05:34 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by evan View Post
What he said.
clearly you haven't actually done it lol
Old 07-25-2014, 05:37 PM   #6
charged86
charged86's Avatar
i always prime my filters. just fill it and let it soak up for a few mins. Youll be amazed on how much it can hold then quickly install. without spilling. it can be done. This is really important on turbo cars so the turbo bearings dont go starved for oil.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-25-2014, 05:39 PM   #7
radroach
Drives: car
Hi priming the filter worked. No mess! Yay.
I used about 5.5 quarts of synthetic total in the oil change, a little less than the 5.8 quarts subaru specifies. People are saying this is ok. OK?
Old 07-25-2014, 06:10 PM   #8
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
check your fluid level, only way to be sure.
There are a bunch of idiots on this forum(myself probably included lol) so don't just follow blindly, plus its super easy to check.
Old 07-25-2014, 06:17 PM   #9
wheelhaus
wheelhaus's Avatar
I always prime and wet the gasket, but never fill it up completely, maybe half. With motorcycles, some people have had issues where not enough oil pressure is generated because of a big air bubble stuck in the filter, and it either remedied itself after 10-20 sec of idle or a throttle blip, or it had to be burped, can't remember... May be apples and oranges, but I don't like the idea of leaving any potential for that.
Old 07-25-2014, 08:48 PM   #10
BRZnut
Drives: BRZ DGM Limited
if you fill the filter with oil and then turn it over to install, how can it not result in a mess?????
The Following User Says Thank You to BRZnut For This Useful Post:
stugray (07-25-2014)
Old 07-25-2014, 09:23 PM   #11
FRSpappa
FRSpappa's Avatar
Drives: 2014 FR-S Whiteout
Fill about 1/3 and let soak in, oil will saturate into material and you will be fine...
FRSpappa is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSpappa For This Useful Post:
charged86 (07-26-2014), SloS14 (08-19-2014)
Old 07-26-2014, 11:11 PM   #12
evan
Drives: fr-s
I love you too man
Old 08-10-2014, 07:40 PM   #13
radroach
Drives: car
I don't know, it's just you do it in a quick enough motion turning it over and screwing it on, that barely any comes out.
Old 08-10-2014, 08:16 PM   #14
Foobar
SLO NO MO
Foobar's Avatar
5.5 is what I've been using, two oil changes so far.
The Following User Says Thank You to Foobar For This Useful Post:
radroach (08-11-2014)
OEM Subaru engine air filter + cabin air filter autobrz Mechanical Maintenance and Tools 6 03-09-2014 09:28 PM
FS: Oiled Panel Filter + AFe Oiled Filter & Kit JPxM0Dz Canada Classifieds 0 01-27-2014 11:48 AM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
WTB: TRD oil filter 86_ZN6 Engine, Exhaust, Bolt-Ons 0 08-26-2012 12:50 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
