Old 07-30-2014, 07:48 PM   #15
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I'll report back after my next track day. I'm also going to order a smaller mesh screen and see what that looks like.
Lunatic is offline   Reply With Quote
Old 07-30-2014, 08:12 PM   #16
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Very interesting. I had that idea for a while... but don't have balls to cut the fender lol
Old 07-30-2014, 08:32 PM   #17
sirisvirus
Drives:
Maybe someone can make a DIY on this.
Sent from my BRZ limited using plastic cup 2.0
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Old 07-30-2014, 08:40 PM   #18
Gunman
Drives: 2019 Mazda Miata RF
Please let us know if this helps while tracking...I am sure it will, even if its not a low-pressure area (I don't know whether the fender vent location is or not)
You could always play with a small wicker on the leading edge, and try to create a low pressure area, if there isn't enough, or it's positive right there. @plucas may have some CFD to reference?
The Following User Says Thank You to Gunman For This Useful Post:
plucas (07-31-2014)
Old 07-31-2014, 08:05 AM   #19
plucas
plucas's Avatar
Drives: Subaru
I will look into it. I believe (just from memory and don't take it as correct until I verify) it is a lower pressure zone. However, you should get flow out of the vent since the pressure in the engine bay "SHOULD" be higher than what is on the outside by the vent.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
Gunman (07-31-2014)
Old 07-31-2014, 08:35 AM   #20
s2d4
s2d4's Avatar
Yeap, it definitely works. I dropped a small piece of cardboard (template for the fender cut out) in the engine bay and I found it next to the fender vents a week later.
I did mine with colour coded prova vents so it looks as OEM as possible.
Old 08-09-2014, 05:55 AM   #21
Lunatic
Lunatic's Avatar
My finial design is finished and installed. I went with a smaller mesh, 1/8th inch diamond screen, and painted the screen gold to match my wheels.
If anyone wants a set pm me.
The Following 6 Users Say Thank You to Lunatic For This Useful Post:
8686 (08-09-2014), cdrazic93 (08-09-2014), Hyper4mance2k (11-07-2015), midnight23 (08-11-2014), Viper8 (10-03-2018), _Kodiak (03-13-2020)
Old 08-09-2014, 06:59 PM   #22
Whitesoul
Wow those are beautiful did you use the original fenders too !
Whitesoul is offline   Reply With Quote
Old 08-10-2014, 12:24 AM   #23
Lunatic
Lunatic's Avatar
Yes, they are on the stock steel fenders.
Old 08-10-2014, 12:52 AM   #24
Whitesoul
Ugh wish I could do that thats perfect and the heat release is perfect
Old 08-10-2014, 01:45 AM   #25
Xovit
Drives: 2002 Camaro
Sent a PM!
Xovit is offline   Reply With Quote
Old 08-10-2014, 10:30 AM   #26
Gunman
I really like that, I'd add the OEM chrome piece back for myself.
Old 08-10-2014, 07:00 PM   #27
ML
ML's Avatar
Drives: 13 White MT FR-S
can you maybe edit a picture of the stock area you cut to show exactly where to cut? what tool did you use to cut? You could mod the stock fender garnish in a similar way with the mesh.
Old 08-10-2014, 07:05 PM   #28
plucas
plucas's Avatar
Drives: Subaru
I would like to see more pictures of the car with the vents. Looks very good!
FS - Carbon Fiber Fender Vents. VIS. BNIB. js0uth Exterior Parts (Aero, Lighting, Etc.) 28 01-26-2015 07:53 AM
FS: brand new Seibon carbon fiber fender vents (SF east bay) serial gixxer Exterior Parts (Aero, Lighting, Etc.) 17 07-20-2013 12:26 PM
VIS Racing Carbon Fiber Fender Insert Vents deedz Exterior Parts (Aero, Lighting, Etc.) 5 06-20-2013 09:21 PM
Photos of carbon fiber fender vents Pneub BRZ Photos, Videos, Wallpapers, Gallery Forum 0 06-11-2013 06:13 PM
VIS Racing Carbon Fiber Fender Vents deedz Cosmetic Modification (Interior/Exterior/Lighting) 10 05-09-2013 10:17 AM
