Old 08-10-2014, 03:31 AM   #7141
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by jflogerzi View Post
...Thanks for the cool comparison. One other videos I would love to see if from a roll in 3rd or 4th.
+1
If you ever get the chance It would be cool to see how they would compare in a DD situation, like driving 4rd or above at low revs: ex: 2500, like you were just cruising, and then had to floor it. I think the end result would be very similar to the launch video, but with the increased speed and drag it would take him longer to get up to high revs, and you would climb so much faster in the low revs that it might take him longer to catch up.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 08-10-2014, 07:38 AM   #7142
WNDSRFR
Drives: FR-S,GTI
I can't help but wonder...
If the aux charger charges the batteries so rapidly then why have the batteries at all? Seems like the compressor motor could be run directly from the alternator via the charger. If the alternator can't take it then maybe an aux alternator?
I wonder what it would be like to have full time boost?
Old 08-10-2014, 09:13 AM   #7143
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
The video doesn't tell me much personally. We've got an automatic versus a manual from a dig. Even a mediocre launch is going to give the manual a serious off the line advantage.
Another video, from a roll, with the manual in 5th gear and the auto in 4th gear will give us a much better idea of how these things compare in power made.
Just find yourself a nice clear stretch of road.
You'd be better off with a normal supercharger at that rate.
The beauty of this system is you can "slowly" loan energy over time to a 3rd party electrical system when your car is not running hard, and then cash in on that energy in order to make even more power later over a short period of time. While it may seem like the alternator can recharge that energy quickly, even the difference between a recharge taking 30 seconds and a discharge taking 15 for instance, is a huge disparity in rates.
One reason batteries are used at all is an alternator, likely even two, are still not going to produce enough current to power the turbine. The cost to properly engineer and install a second alternator would be a poor investment and kind of defeats the entire purpose of the system. Running an alternator off the engine UNDER LOAD in order to spin the compressor will rob the engine of power while you're asking the most of it. This makes it act like a normal supercharger, except now because you are converting that energy from mechanical to electrical energy via an alternator and then back into mechanical energy with the compressor, you've just forfeited a lot of efficiency.
In addition the use of batteries also allows the energy to conveniently be placed in a medium with significantly higher voltage. The higher voltage is very important, as it means the compressor can be run at significantly lower amperage than the ridiculous sustained amperages a 12v system would have to operate at.
Like all FI applications it is a game of compromise. This system has advantages, but a disadvantage is it cannot compete as a full time system. If that is your goal, a traditional supercharger or turbo system is going to be vastly superior. Thing is, when you really look at the vast majority of consumers, they're unlikely to outpace a system like the Phantom under almost any conditions aside from driving on a road course during a track day.
And at any rate, if you have a full time FI system and you take it to a road course, you're probably going to have to invest substantial amounts of money in serious upgrades to manage heat in your drivetrain and brakes.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 08-10-2014, 10:36 AM   #7144
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
We wanted to do a third gear pull but I swear there were cops in our area so we didn't want to push it. Maybe for the next video.
Installed Mods:
Old 08-10-2014, 11:07 AM   #7145
shif7i7down
Erected Member
Drives: frs
Originally Posted by s2d4 View Post
Mfactory ones are "semi" helical, less angle than OEM.
Not sure how any minutes you're talking about, but helical is helical, it's got both helix angles and invoute. Allot different then your first statement about it being a straight cut.
Anywho, I'm not here to argue gear geometry with you. Have a good day
shif7i7down is offline   Reply With Quote
Old 08-10-2014, 11:52 AM   #7146
MmmHamSandwich
Drives: '13 FR-S
Understandable.
If possible a 4th AT and 5th MT will give the best comparison as both correspond to 1:1 on their respective transmissions. Granted you'd be moving pretty quick if you wound all the way to 7k. Though I think it is safe to say we all know the Phantom can't compete that high. Maybe a pull starting at 2.5k RPM or so (which would keep the speed pretty low) until the other car passes. From there we already know the rest of the story.
I don't think most of us are too critical on the performance comparison in a drag, but a rolling pull at equal gearing would demonstrate the practical difference in power down low, which I think is what we're really interested in. If a similar setup video could be made against a Rotex car, and a stock car as well at a later time, that would be amazing.
Regardless thanks for taking the time to make the vid!
Says Thank You to
MmmHamSandwich For
This Useful Post:
Old 08-10-2014, 11:53 AM   #7147
Sojhinn
Sojhinn's Avatar
Originally Posted by MmmHamSandwich View Post
Understandable.
If possible a 4th AT and 5th MT will give the best comparison as both correspond to 1:1 on their respective transmissions. Granted you'd be moving pretty quick if you wound all the way to 7k. Though I think it is safe to say we all know the Phantom can't compete that high. Maybe a pull starting at 2.5k RPM or so until the other car passes. From there we already know the rest of the story.
Not a bad idea that way. Next time we meet up will try.
Installed Mods:
Old 08-10-2014, 12:44 PM   #7148
fenton
Understandable.
I think the blue car has a smaller final drive installed though...I could be wrong bit I thought he had 4.88.
If that's the case a 3rd gear roll from 2500 would give us a nice comparison.
fenton is offline   Reply With Quote
Old 08-10-2014, 12:49 PM   #7149
WNDSRFR
Drives: FR-S,GTI
You're right. It would be pretty much exactly the same as a belt driven supercharger where the belt is replaced by wires.
I'm sure Rob has already considered most if not all the possibilities.
Old 08-10-2014, 12:51 PM   #7150
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
How fast were you going when he passed you? I think you mentioned him catching up at 4000rpm in 3rd.
My car hits 60 at just under redline in 2nd. Is that telling us that your car was actually quicker 0-60 than the Kraftwerks?
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 08-10-2014, 12:57 PM   #7151
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Yes. But he had an auto.
Installed Mods:
Old 08-10-2014, 03:59 PM   #7152
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
0-60 I was measuring 6.5 with the 1.5 ESC. I've been hitting 5.3-5.5 with the KW. Not an accurate measurement but consistent - same road and same method.
My final drive is stock - no mod there
nlowell is offline   Reply With Quote
Old 08-10-2014, 04:03 PM   #7153
raven1231
isn't stock 6.5???
Old 08-10-2014, 04:32 PM   #7154
DAEMANO
Time Traveller
I was regularly under 6 (5.7-5.9) with 1.5x, haven't measured with e85 but I'm expecting consistent low 5's. This is with 6MT.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
