Old 08-09-2014, 09:33 AM   #1
redburn86
Drives: red gts 86
How wide can I go with the stock rims
How wide can I go with the stock rims I'm thinking about 245/45 or 235/45 will it fit without in issues.
redburn86 is offline   Reply With Quote
Old 08-09-2014, 09:39 AM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
Old 08-09-2014, 12:30 PM   #3
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
A 225/45 is a safe bet I'd say. But you might be able to slap a 235/40 (note, not a 235/45 because that's too tall) but it might be a bit balloony, especially if you get a tire that runs wide. Also, 235/40 is a rare, relatively expensive size, and depending on if you want a specific tire or not, you probably won't find it. Get a 225/45.
Nevermore is offline   Reply With Quote
Old 08-09-2014, 01:18 PM   #4
Brianjoy77
Brianjoy77's Avatar
Drives: 2013 FR-S Silver 6AT
Why put a wider tire on if at stock power? Also why use stock rims if you have more power?
A 205/45/17 would be cheaper and save a few pounds too. Stock tires for me were bridgestones and 27k miles in they're toast. I like the stock rim look and plan to keep them but they are a bit heavy and the tire selection for them stock was a joke.
Add some front negative camber and stickier stock sized tires and you will probably be happier than going with wider tires all around.
Brianjoy77 is offline   Reply With Quote
Old 08-09-2014, 02:23 PM   #5
redburn86
Drives: red gts 86
Thank you I think I'm gonna put the 225
Old 08-09-2014, 02:33 PM   #6
redburn86
Drives: red gts 86
But is it true changing the tire width will change the car speed like if your doing 60 actually your going 63 I saw this in a website about tire fitment
Old 08-09-2014, 03:05 PM   #7
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
that happens when you change the tire height.
there is a calculator here that will tell you the speedo difference
http://www.kouki.co.uk/utilities/vis...ize-calculator
G-Man is offline   Reply With Quote
Old 08-09-2014, 09:48 PM   #8
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
A 225/45 on the stock wheels will cause a 1.3% error. You will be doing 60.8 when speedo says 60.
Will AMG stock rims fit on my Stock Scion FRS? Nicolas0esp1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2014 07:01 PM
FS: 4x stock FRS rims + 2x stock BRZ rims = $300 + shipping retrosmiths Wheels and Tires 3 08-13-2013 08:18 PM
How wide and aggressive on stock tires? euroshowoff Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-19-2013 07:40 PM
Fitted 9.5inch wide rims, on the FRONT.. No rubbing, no guard rolling :) WTF AUSTRALIA 32 03-27-2013 02:42 AM
Picture Request: Stock Turanzas on 8" wide wheels Robmilkshakes Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-17-2013 07:05 PM
