Old 08-09-2014, 01:08 PM   #15
Lonewolf
Lonewolf's Avatar
Drives: Moped
Great interior shots...keep em coming!
The Following User Says Thank You to Lonewolf For This Useful Post:
Piercemotorsports (08-09-2014)
Old 08-09-2014, 01:28 PM   #16
Piercemotorsports
Piercemotorsports's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by philooo View Post
Keep the pics and updates, this is VERY interesting. You seems to have a knack to highlight the build important point
I'll try to post update as good as your in my thread:
http://www.ft86club.com/forums/showthread.php?t=71806
Quick Question: how much did you sell the whole interior for ? How do you deal with all the parts you are removing ? ebay ?
It was just from this thread-a local guy popped in and bought it all except for the passenger seat/seat belt. I'm not sure what the going rate would be---I'd imagine you could part it out easier than selling it complete-definitely make more money that way. We got less than $500 for everything. We have the stock wheel's tires left for sale if anyone needs another set...
Piercemotorsports is offline   Reply With Quote
Old 08-09-2014, 07:11 PM   #17
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Awesome job selling all your interior. I've not been so lucky. At this rate, I'd probably take $500 for the entire lot just to have it gone.
Did you happen to weigh the heater core and A/C components?
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
The Following User Says Thank You to phastafrican For This Useful Post:
Old 08-09-2014, 09:45 PM   #18
Piercemotorsports
I will Monday---we just got them out yesterday and they didn't get picked up yet---I'm betting the fan assembly/core/ducting inside is around 25lbs easy.
The Following User Says Thank You to Piercemotorsports For This Useful Post:
phastafrican (08-10-2014)
Old 08-12-2014, 02:43 PM   #19
Piercemotorsports
So the fan/heater core/AC stuff weight 19lbs---probably close to 30lbs with the engine lines/condenser etc...anyone found an AC Delete option (haven't even looked yet)? Also because your gaming chair needs a head support seat (we build some goofy stuff)!
Old 08-12-2014, 03:09 PM   #20
phastafrican
I work for simcraft. I see your goofy stuff, and I raise you our goofy stuff.http://www.simcraft.com/
We talk about A/C delete in this thread: http://www.ft86club.com/forums/showthread.php?t=59950.
This post has contains what you need: http://www.ft86club.com/forums/showp...40&postcount=9
Thanks for weighing. 20-25lbs would be very useful. I like the mods that cost little $. For now, I'm already underweight in my class so I'll be doing later once I figure out exactly how much $$$ I want to spend on relocating weight from the front to the rear.
Piercemotorsports (08-13-2014)
Old 08-13-2014, 02:56 PM   #21
Piercemotorsports
Those are awesome! The kit's/packages look intriguing as well. I'd absolutely get nothing done if I had one of your units in the shop! Thanks for the links---so much good info on the forums. We're starting the cage today-should have some pics this week.
Old 08-13-2014, 02:58 PM   #22
phastafrican
Gonna upload the pics from my cage in a few. Finally gathered them all into google photos.
Old 08-14-2014, 12:58 PM   #23
Dezoris
Dezoris's Avatar
Before you install the wood flooring I suggest running radiant heat system works great in the winter or on those cold days where snuggling is not possible.
Old 08-14-2014, 03:14 PM   #24
Piercemotorsports
We're working on the roll cage boxes/lower plate area's, but in the meantime we installed some coilovers/our 3 point chromoly strut brace up front. Pretty snazzy reservoir holders!
Old 08-22-2014, 02:46 PM   #25
Piercemotorsports
After a week of Monterey car stuff we're back in here finally---got 4 points of Jet's cage mocked up. We build quite a few racecars but this is our first FRS cage---the roof line has a nice little pocket for a tube to sit up in and it really helps head clearance for the drivers helmet. I think maximizing the envelope of safety is one of the most important aspects of cage design---this isn't an all out racecar (at least not yet) build, just a fun track car so we're not going to get to involved with tubing/re-enforcing everything, just minimal design/something safe. Also got a steering wheel/quick release and hub installed as well as the rear stoptech brake rotors and Hawk pads-still waiting on the front BBk...
The Following 2 Users Say Thank You to Piercemotorsports For This Useful Post:
phastafrican (08-22-2014), Ryaquinn (08-22-2014)
Old 08-22-2014, 03:00 PM   #26
phastafrican
Looking very good. I messed up a bit with my down-bar positioning while trying to give my feet the maximum room.. The ends of my dash meet the very center of the down bar, so I'm unable to put the side rubber piece back. In hind sight, I would have moved the down bar slightly inwards to allow the dash pieces to fit back.
Piercemotorsports (08-22-2014)
Old 08-22-2014, 04:50 PM   #27
Piercemotorsports
Ok-gotcha-that may help us as well. I put our roof spreader up high and had to notch the roof beam/visor area and slid the A-Pillar bar straight down the pillar and then turned down inside those dash mounts (almost cut them off), touching/pushing them out for sure...Thanks!
Old 08-22-2014, 05:16 PM   #28
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Do you have another pic of your front down bar. Are you connecting it to the oem dash bar?
Ryaquinn is offline   Reply With Quote
piercemotorsports, racecar, track build
Pure Motorsport: JDL Turbo BRZ Track Build ATL BRZ Member's Car Journals 2165 07-10-2023 04:24 PM
FRS partout (2,319 miles) doing full track car build Joshinpa Engine, Exhaust, Bolt-Ons 123 04-05-2016 11:12 AM
Matt's CwestXRays BRZ peebking Member's Car Journals 26 10-13-2014 08:48 PM
NJMP track after big build - observations dp1 Tracking / Autocross / HPDE / Drifting 15 07-21-2014 12:15 PM
WTB: Local shop for track build DatApex Great Lakes 1 06-17-2013 07:56 PM
