Old 08-09-2014, 01:46 AM   #1
dragonwiddd
dragonwiddd's Avatar
Drives: 2013 Scion FR-S Asphalt
Long sitting maintenance?
Stationed in Korea. Sitting here at work. Day dreaming about my FRS that is sitting in a U-Haul temp controlled storage unit in Florida only being started by my dad every 2 weeks. 10 months to go until I can drive my baby again. Sad face. What should I do right when I get back maintenance wise? I'm chaning the oil, tranny fluid, and rear diff fluid. Might change the tires depending on how well they held up. Anything else?
dragonwiddd is offline   Reply With Quote
Old 08-09-2014, 01:55 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I think the transmission fluid and rear diff fluid can stay.
I would be more concerned about the brake fluid and the battery.
N1rve
Old 08-09-2014, 01:56 AM   #3
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
It's important to add forced induction after a long period of inactivity.
NWFRS is offline   Reply With Quote
Old 08-09-2014, 02:15 AM   #4
Mini Cooper S
Mini Cooper S's Avatar
Drives: '16 MX5 rip '14 FRS
I'm pretty sure you looked up how much it would cost to ship a car to different countries. How much would it cost to do yours?
Mini Cooper S is offline   Reply With Quote
Old 08-09-2014, 03:35 AM   #5
dragonwiddd
Not aloud to own one here. Not enough space on base.
Old 08-09-2014, 03:55 AM   #6
Mini Cooper S
Damn! That's crazy bro!
Old 08-09-2014, 08:50 AM   #7
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
Did you pump up the tires to their max inflation pressure? This helps to avoid flat spotting during long storage periods. I'd also keep the battery on a tender if possible, which should protect it just fine. If your Dad could take the car out to fully heat up the engine every month or so it would help boil off fuel and moisture that gets into the oil system. A lot of cold starts with short run periods tend to aggravate this. I agree about changing the brake fluid. Might as well put in some higher performance stuff when you get home.
Lavalover is offline   Reply With Quote
Old 08-10-2014, 03:05 AM   #8
aptan
Drives: 2014 Whiteout Monogram FR-S
The battery should be kept on a tender. Just starting it every two weeks may not be enough to keep the voltage on the battery up, and the battery will degrade if the voltage is held low for too long. If you don't have an outlet in the storage unit, you might just want to take it out of the car and tend it elsewhere.
Gas goes bad too. I would drain the tank, or at the very least add some fuel stabilizer. Even if you do add stabilizer, it will only keep the gas for a few months ...
If you take the battery out and put it on a tender, and drain the gas, you shouldn't have to touch it at all until you get back.
aptan is offline   Reply With Quote
Old 08-13-2014, 02:17 AM   #9
sastexan
Drives: '13 FR-S Ultramarine manual
Agree with all the above comments. Best course of action is for your dad to give it a nice long drive once a month to make sure the engine is fully warmed and tires heated up. Also cycle the ac to keep all those seals lubricated. Battery tender is a must, as is fuel stabilizer. Keep the tank fairly full to prevent condensation in it due to water vapor.
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer)
'01 Camry 5S-FE (wife's old car)
'11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features
sastexan is offline   Reply With Quote
Car's sitting on jack stands while waiting for new wheels. hanabie DIY (Do-It-Yourself) Guides 9 02-08-2014 03:03 PM
Stocks sitting in the lot longer now... Iixii Scion FR-S / Toyota 86 GT86 General Forum 38 09-13-2012 03:44 PM
Firestorm sitting on lot for 3 weeks FirestormFRS Scion FR-S / Toyota 86 GT86 General Forum 6 09-10-2012 06:30 PM
What's Everyone's Mileage Sitting At Right Now? IchigoIchie CANADA 28 08-12-2012 12:56 AM
Pics of people sitting in rear seat glorydays FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 12-08-2011 05:54 AM
