Old 08-04-2014, 04:44 PM   #15
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by DeliciousTuning View Post
Spoke with EcuTeK about this, this morning. They are releasing an update that will be available tomorrow to everyone for download that resolves this issue.
Cheers,
William Knose
Thanks for the update Bill.
Dustin is offline   Reply With Quote
Old 08-04-2014, 07:28 PM   #16
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
I got mine to flash using the previous version, going to data log for my tuner once the 5 min recalibration idle time is up.woo hoo! Glad ECUtek is on top of this and putting out an update soon too.
Kwaziekeller is offline   Reply With Quote
Old 08-05-2014, 05:18 AM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
5 mins is too long, it's just a waste of fuel.
If you're doing it on a cold engine:
Flash & Reset
Pedal Push
Start Car & Idle for 1 minute
Exhaust cams don't come active until oil is over 30C + some other conditions met so drive down the road for 1-2 mins and then stop the car. Wait until you see movement on the VVT Exhaust Angle. Drive and log.
If you're doing it on a warm engine:
Flash & Reset
Pedal Push
Start Car & Idle for 30 secs. You should see movement on the VVT Exhaust Angle after about 10-15 seconds.
As soon as the exhaust cam is active, you're ready to go.
I would just make sure you start logs when oil and water is up to temperature. For me, that's over 50-60C for both. The above is also why it's easier to flash if you've already warmed up the car.
.: Stealth 86 :.
Kodename 47 DJ:
Kwaziekeller (08-05-2014)
Old 08-05-2014, 08:43 AM   #18
Kwaziekeller
Thanks for the info... good to know. I was just going off of my u tuner's recommendation. I hadn't heard of the pedal push, but I'll have to try it. Makes sense and I've had to do similar things on other vehicles.
Old 08-05-2014, 12:36 PM   #19
acro
Drives: GT-86
Flash & Reset
Pedal Push
Flash & Reset
Pedal Push
Sorry mine had to be left for 5 min. The racerom features didn't work when I did otherwise.
acro is offline   Reply With Quote
Old 08-05-2014, 02:21 PM   #20
Kuros
Drives: 2014 FRS Raven. 2011 sti red (gone)
Very few times do I come on this forum and actually read something of value lol.
This is one of those times.
Kuros is offline   Reply With Quote
Old 08-07-2014, 01:11 PM   #21
Kuros
Does anyone know if the latest version has resolved the issue?
Old 08-07-2014, 03:48 PM   #22
Dustin
Twin Screw You
Dustin's Avatar
I'll check later today.
The Following User Says Thank You to Dustin For This Useful Post:
Kuros (08-07-2014)
Old 08-07-2014, 05:36 PM   #23
Kuros
Please do! My tuning is on hold until it is. And I wanted to Auto X this weekend!
Old 08-07-2014, 06:37 PM   #24
Dustin
Twin Screw You
Dustin's Avatar
Good to go.
Kuros (08-07-2014)
Old 08-07-2014, 06:55 PM   #25
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Cheers,
William Knose
Was it released?
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
The Following User Says Thank You to zoth For This Useful Post:
Kuros (08-08-2014)
Old 08-08-2014, 08:51 PM   #26
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by zoth View Post
Was it released?
Yes, it was available Tuesday.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
zoth (08-09-2014)
Old 08-09-2014, 11:56 PM   #27
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Successfully updated to the new version and got the map to load correctly!
All I can say is WHAT A DIFFERENCE!!! The low gears/speeds is so smooth now!
JesseE is offline   Reply With Quote
Old 08-10-2014, 01:39 AM   #28
afishl1
Drives: Raven FRS MT
Ugh, worst luck ever, I just wrote this super long post and was about to post when I decided to copy it so I could paste it just in case it didn't post for some reason. When I hit select all text, it crashed firefox on my phone and i lost it all
Anyway, lesson learned is to make it shorter.
I am doing an HID/angel eye install and like a dumbass listened to a post to tap into a wire in the bundle of wires coming out of the engine bay fuse box.
After also disconnecting the battery I remembered that I might have to reflash.
I got this problem and also my dash/and hid system now flickers after trying to flash several times.
I'm not sure if this is a coincidence because you guys got a similar problem recently or if I might have pulled a random wire when tapping.
Unfortunately I tried the latest software update today and it didn't work.
Still want to try locking the car and coming back after 5min of it off, but I'm practically crying on the inside that I may have royally screwed myself
Any thoughts, suggestions?
If anyone knows of a shop or an individual near LA that could help I'm all ears.
Pray for me that this is a quick fix.
afishl1 is offline   Reply With Quote
Moto-East EcuTek RaceROM and Tune Update! Xero-Limit Software Tuning 50 10-30-2015 02:03 PM
PS3 (GT6?) won't update 1.03 ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 3 01-22-2014 01:33 AM
Ecutek reads ecu as unsupported after rpm tsb update help please Frs32907 Software Tuning 14 12-20-2013 10:19 AM
Where can i get an ECUtek license update? ag144 Engine, Exhaust, Transmission 2 07-25-2013 08:32 AM
Ecutek gas gauge issue fixed maj75 Engine, Exhaust, Transmission 1 03-23-2013 11:49 AM
