| Software Tuning Discuss all software tuning topics. |
#15 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
#16 |
Drives: '13 Argento MT FR-S
I got mine to flash using the previous version, going to data log for my tuner once the 5 min recalibration idle time is up.woo hoo! Glad ECUtek is on top of this and putting out an update soon too.
#17 | |
Drives: UK GT86
If you're doing it on a cold engine: Flash & Reset Pedal Push Start Car & Idle for 1 minute Exhaust cams don't come active until oil is over 30C + some other conditions met so drive down the road for 1-2 mins and then stop the car. Wait until you see movement on the VVT Exhaust Angle. Drive and log. If you're doing it on a warm engine: Flash & Reset Pedal Push Start Car & Idle for 30 secs. You should see movement on the VVT Exhaust Angle after about 10-15 seconds. As soon as the exhaust cam is active, you're ready to go. I would just make sure you start logs when oil and water is up to temperature. For me, that's over 50-60C for both. The above is also why it's easier to flash if you've already warmed up the car.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Kwaziekeller (08-05-2014) |
#18 |
Thanks for the info... good to know. I was just going off of my u tuner's recommendation. I hadn't heard of the pedal push, but I'll have to try it. Makes sense and I've had to do similar things on other vehicles.
#19 | |
Drives: GT-86
#20 |
Drives: 2014 FRS Raven. 2011 sti red (gone)
#21 |
Does anyone know if the latest version has resolved the issue?
#22 |
Twin Screw You
I'll check later today.
| The Following User Says Thank You to Dustin For This Useful Post: | Kuros (08-07-2014) |
#23 |
#24 |
Twin Screw You
Good to go.
#25 | |
Drives: 2013 BRZ Premium Dark Gray Metallic
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
| The Following User Says Thank You to zoth For This Useful Post: | Kuros (08-08-2014) |
#26 |
PhoneFlash by EcuTeK
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | zoth (08-09-2014) |
#27 |
Drives: LS Swapped BRZ
Successfully updated to the new version and got the map to load correctly!
All I can say is WHAT A DIFFERENCE!!! The low gears/speeds is so smooth now! |
#28 |
Drives: Raven FRS MT
Ugh, worst luck ever, I just wrote this super long post and was about to post when I decided to copy it so I could paste it just in case it didn't post for some reason. When I hit select all text, it crashed firefox on my phone and i lost it all
![]() Anyway, lesson learned is to make it shorter. I am doing an HID/angel eye install and like a dumbass listened to a post to tap into a wire in the bundle of wires coming out of the engine bay fuse box. After also disconnecting the battery I remembered that I might have to reflash. I got this problem and also my dash/and hid system now flickers after trying to flash several times. I'm not sure if this is a coincidence because you guys got a similar problem recently or if I might have pulled a random wire when tapping. Unfortunately I tried the latest software update today and it didn't work. Still want to try locking the car and coming back after 5min of it off, but I'm practically crying on the inside that I may have royally screwed myself ![]() Any thoughts, suggestions? If anyone knows of a shop or an individual near LA that could help I'm all ears. Pray for me that this is a quick fix. |
| Moto-East EcuTek RaceROM and Tune Update! | Xero-Limit | Software Tuning | 50 | 10-30-2015 02:03 PM |
| PS3 (GT6?) won't update 1.03 | ZionsWrath | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 01-22-2014 01:33 AM |
| Ecutek reads ecu as unsupported after rpm tsb update help please | Frs32907 | Software Tuning | 14 | 12-20-2013 10:19 AM |
| Where can i get an ECUtek license update? | ag144 | Engine, Exhaust, Transmission | 2 | 07-25-2013 08:32 AM |
| Ecutek gas gauge issue fixed | maj75 | Engine, Exhaust, Transmission | 1 | 03-23-2013 11:49 AM |
