Old 07-30-2014, 01:26 PM   #113
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
This information is awesome, thanks guys!
I figured that I would share my experience:
I tried the 445u amp without thinking about it's specs too much. I believe that it worked so well for the first guy that used it because perhaps his 6.5 speakers are two-way and have a crossover of some sort.
I tried using this amp on the stock speakers and, while way louder and cleaner, this amp only has a high-pass filter - which is not good for our stock woofers. My plan is to use this info and hook up an amp with a low-pass filter to the stock speakers, specifically this one:
Kicker 11DX125.2 (It will also work with the stock wiring - 15A)
***Only $67.99 at Best Buy***
I like the highs that the stock system offers and figure that by using this amp I can flatten low frequency EQ settings on the head unit, which should clean up the highs for the dash speakers even more, and then use the gain and bass boost on the amp to enhance those signals going to the door woofers for a fuller, more crisp sound.
Any which way, I have this amp being shipped to store and it should be there by this weekend. I'll give this a shot and report back with my findings.
alexand3r is offline   Reply With Quote
Old 07-30-2014, 01:33 PM   #114
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
In my BRZ the door speakers rattle and sound terrible. Once I installed a sub in the trunk I just disconnected the factory amp to eliminate the door speakers. I can now turn my volume up to 100% and the highs are loud and clear and it all together sounds great.
B-R-Z is offline   Reply With Quote
Old 07-30-2014, 02:02 PM   #115
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I've already 'matted my door skins, cards and foamed all switches to take care of the rattles. I've actually never tried pushing a pair of 6.5 speakers and am curious to see how much bass I can get and if it will be acceptable (as I do not want to take up trunk space with a sub).
If not, I may try switching out one of the door speakers with a 4-ohm woofer, hooking up a 4-ohm 8" or 10" speaker in the trunk and running both of those off of one channel (Amp is stable at 2-ohms). Or perhaps I could replace the doors with 8-ohm speakers and put in a 4-ohm sub, bridged to both channels.
Old 08-07-2014, 03:40 PM   #116
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Update:
Just installed the amp and went ahead with door speaker upgrades. Sounds great, IMO much better than the Alpine amp. However, there are only two channels - but the sound stage is very nice with the factory dash speakers (Being powered off of the headunit). It really just fills in the sound all around you with more frequency, not just highs/lows, but better mid-range imaging.
I did some tests bridging the two channels to a 4-ohm speaker and it seems to handle it just fine. Therefore my next step is making a 80 Hz passive crossover (I want to leave the fronts set to full-range) and testing that with a 10" sub, bridged to the L/R channels. For the crossover I'll be testing 330-350uF caps and 10-12mH inductors to see what sounds best.
This amp is much bigger than the Alpine unit, but still fits nicely in the stock amp location. I'll take some pictures once I'm done with the whole thing for those who are interested. I'm just going for a nice, clean install that is easily put back to stock. Again, I would like to thank the OP for the wiring schematic, it is much appreciated and has been very useful.
Old 08-07-2014, 04:51 PM   #117
B-R-Z
B-R-Z's Avatar
I have been running on everything except the door speakers and I am missing the mid bass. I need to fix my window switches to not rattle and get better speakers that will allow me to max out my volume.
Old 08-07-2014, 05:50 PM   #118
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Oh yeah, that'll do the trick.
In case you haven't done it before:
Just take your door cards off, pop open the window switch case with a flat head and cut a piece of dense foam to go in there under the circuit board (I re-purposed some foam from packing material that came inside of a sound card box). Just don't get it too tight (ie - cut the foam too thick) or your switches will be overly sensitive.
Old 08-13-2014, 10:48 PM   #119
OneMic
OneMic's Avatar
Drives: FireStorm
I didn't change a thing as far as speakers and deck. I kept the factory system. I just added amp and sub. If you plan on doing the same thing I recommend the AC LC2i. I love it!
OneMic is offline   Reply With Quote
Old 08-14-2014, 08:41 AM   #120
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Just ordered some new goodies, gonna use this thread to help me re-pin the line level inputs:
http://www.polkaudio.com/products/mm1040
http://www.polkaudio.com/products/pad4000_4
http://www.polkaudio.com/products/mm6501
Cockatoo is offline   Reply With Quote
Old 08-26-2014, 08:25 AM   #121
Cockatoo
TALLY FT86
Cockatoo's Avatar
Just put my speakers and amp in! Lightyears better than the stock setup with just a component set up front and a 10 inch sub in the trunk.
*I took the stock dash speakers out and its the perfect place to stuff the crossover!
Old 08-26-2014, 08:37 AM   #122
Cockatoo
TALLY FT86
Cockatoo's Avatar
Also for those that need speaker adapters but don't want to buy those expensive ones, these worked perfect!:
[ame="http://www.amazon.com/gp/product/B007ZQGZWO/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1"]Amazon.com : Toyota Aftermarket 6.5-Inch Plastic Speaker Adapter (Black) : Vehicle Audio Auxiliary Adapters : Car Electronics[/ame]
The Following 2 Users Say Thank You to Cockatoo For This Useful Post:
86geek (03-08-2015), Chimera (08-26-2014)
Old 08-26-2014, 08:38 AM   #123
Chimera
Drives: FRS
any plans for rear speakers?
Old 08-26-2014, 08:45 AM   #124
Cockatoo
TALLY FT86
Cockatoo's Avatar
I don't like rear fill.... so pointless. Especially since there will be no back seat passengers in this car.
Old 08-27-2014, 09:30 PM   #125
SubieNubie
SubieNubie's Avatar
Drives: 2013 WRB BRZ
How much juice can the stock wiring to the door speaker and handle? I'm looking at purchasing an Alpine MRV-F300 (75RMS @ 2ohms) to power the OE door speakers before I purchase some upgraded ones. Also I have yet to dig around the trunk, would anyone happen to know if that Alpine amplifier would fit in the stock amplifier location?
UPDATE
I got around to taking some measurements yesterday after I was done washing the BRZ. From the measurements on Crutchfield, the MRV-F300 won't fit without some modification to the foam piece surrounding it. It looks like I'd need to take at least 1/2" off the inside and chamfered corner. Adding to that bad news, it looks as if you need to disassemble the rear seat just to remove that foam piece (reference). In addition to that, it is not flat where the OEM amplifier is mounted. The bottom slops down towards the rear seats. Also the rear seats taper toward the front as well.
Daily Driven 2013 6MT Subaru BRZ Premium in WRB
SubieNubie is offline   Reply With Quote
Old 08-28-2014, 08:42 AM   #126
Chimera
Drives: FRS
Idk about size but if you run the 445u bridged it pushes 90 w. I did that for quite a bit with no issues.
The Following User Says Thank You to Chimera For This Useful Post:
SubieNubie (08-31-2014)
Wideband LC-1 wiring. MattF Forced Induction 9 07-09-2013 09:33 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 01:02 PM
So is there a DIY yet for BRZ headlight wiring for the FR-S? seven Cosmetic Modification (Interior/Exterior/Lighting) 4 11-25-2012 09:24 PM
x940bt wiring help encity5 Electronics | Audio | NAV | Infotainment 10 08-31-2012 04:08 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
