Old 08-07-2014, 07:45 AM   #57
puma
crew chief
puma's Avatar
Drives: Race car FR-S
everyone, please bug them to put the fuel level in the next version also, i so much want this
puma is offline   Reply With Quote
Old 08-07-2014, 11:17 AM   #58
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Any idea what the source of that data is - in-tank sensor, injectors, or...?
dradernh is offline   Reply With Quote
Old 08-07-2014, 11:34 AM   #59
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Most (if not all) cars use in-tank sensors now. Otherwise, there'd be no way to watch the tank fill up in "accessory on" like I do when setting tank levels before an autocross.
bimmer635csi is offline   Reply With Quote
Old 08-07-2014, 11:40 AM   #60
bimmer635csi
Originally Posted by RehabJeff86 View Post
I have heard it won't work with splitter
Did we figure out if this is true or not? (Maybe I missed it in an old post)
Old 08-07-2014, 12:40 PM   #61
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Still a myth cuz I have not tired it personally but heard from a person "whom has tried" stating it don't work - waiting for CSG Mike to try it out lol
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 08-07-2014, 02:42 PM   #62
CSG Mike
CSG Mike's Avatar
We don't have a splitter!
Old 08-07-2014, 03:21 PM   #63
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
I believe the OBD2 protocol allows only one client adapter connected to the port. I don't know what equipment people use with the splitters, but everyone that I know that has tried to connect two OBD2 client devices (like the Solo DL and another OBD2 reader) has not been able to make it work.
Sleepless is offline   Reply With Quote
Old 08-07-2014, 03:46 PM   #64
RehabJeff86
Lmfao ok ok!! Lets eat Burmese food!
Old 08-10-2014, 07:10 PM   #65
philooo
Drives: 13' Scion FRS Track car
Can a video camera be connected to it in order to get video with overlap ?
I use Harry's lap timer because the video overlays are really cool
Not as professional but fun
I pair it with the vbox sport and it is quite accurate but I can't read it while I drive
philooo is offline   Reply With Quote
Old 08-10-2014, 07:23 PM   #66
juliog
juliog's Avatar
Drives: 86
You can use RaceRender (free) to overlay data on top of any video.
juliog is offline   Reply With Quote
The Following User Says Thank You to juliog For This Useful Post:
CSG Mike (08-10-2014)
Old 08-10-2014, 08:00 PM   #67
dp1
driving smoother faster
Drives: Sold
Aim Solo DL Datalogger
iPhone + Harry's Laptimer for data and video mounted to windshield + Dual GPS (5Hz) + GoPro attached to the inside of the rear window pointing forward + DashWare to overlay data and video. Have Kiwi WiFi for additional ODB2 data but rarely use it and only with DashCommand for diagnostics.
Many people I know who frequent tracks use Aim Solo DL and like it.
dp1 is offline   Reply With Quote
Old 08-17-2014, 01:55 AM   #68
juliog
juliog's Avatar
Drives: 86
By the way, don't leave Solo (or other OBD2 gadgets) connected when the car is off for long periods, it drained my lightweight battery over a weekend..
Old 08-17-2014, 08:19 AM   #69
bimmer635csi
That's one thing that is nice about the Torque app, it reminds you to unplug the gizmo when you turn off the app.
Old 09-03-2014, 01:53 PM   #70
mkivsoopra
Exclamation
Water temperature update! (BETA)
Originally Posted by AiM Tech Support
Hello,
Attached is a revised ECU driver set for the SoloDL. This will hopefully correct the offset readings in the water temperature channel coming from the ECU.
In order to test, you will need the latest version of RaceStudio 2 installed on your PC... http://aim-sportline.com/download/so...140723_WEB.exe
Here is what you will need to do in order to install and test the beta ECU drivers...
Instruction for upgrade RaceStudio 2 :
1) Close RaceStudio 2 , if it is already open
2) Unzip the first set of enclosed files in a temporary folder or for example onto the Desktop
3) Check your current RaceStudio 2 Installation folder (you can do so by checking the “Properties” of the Desktop shortcut. If you used the standard installation folder it should be either (depending on your PC's operating system):
Windows XP
- c:\ program files \ AIM \ Database
Windows 7 and 8
- c:\ Aim Sport \ RaceStudio2 \ DATABASE
4) Once you have located the “Database” folder, select and copy the two ECU driver files and paste and replace the default files present (after the Paste and Replace has been completed, recheck date and time of the files that were replaced to ensure that the new files are loaded.
5) Launch RaceStudio 2.
6) Create a new configuration from scratch by going to Device Configuration>>SOLO DL>>New and select Toyota>>GT86. If this option is not available in the ECU Model drop down menu, please check once more where you copied the two ECU driver files to).
And finally Transmit the new configuration back to the SOLO DL. Hopefully this will correct the temperature issue. Please let us know if it still appears to be off.
Regards,
Josh
Josh Hanrahan
Technical Service
I had to ZIP the original file that they sent (DB6.rar) so that it can be attached to the forum. You'll have to unzip, then unrar it.
I haven't tested this myself yet... been too busy putting my car back together . I also have their blessing to pass this along to the community.
mkivsoopra is offline   Reply With Quote
The Following 5 Users Say Thank You to mkivsoopra For This Useful Post:
BRZkitty (03-16-2015), CSG Mike (09-03-2014), frssfo (08-14-2015), juliog (09-03-2014), rb6freak (09-03-2014)
Solo 1 kombatlion SOUTH AMERICA / CARRIBEANS 6 03-20-2015 04:01 AM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
N.J. Pro Solo Simmons Tracking / Autocross / HPDE / Drifting 20 03-11-2013 05:32 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
