Old 08-06-2014, 08:56 PM   #1877
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by nlowell View Post
Wow, I wished I read this while I was installing my SC and Oil kit over the weekend...complete FAIL.
After installing everything per the instructions and even adding some zip ties to the lines - they blew right off while Bill @DeliciousTuning was logging to make sure the tune was solid (which it was!!). Oil everywhere!
Mike at Infamous came to the rescue to push them back on and clamp them down so I could limp home and get new lines put on. After some degreasing and while limping home the lines popped on the radiator side. F! Oil EVERYWHERE again! I had to borrow some tools from a shop nearby where I broke down, rip the bumper and intercooler off in a parking lot, get an Uber driver to take me to Parker Hoses where they press fitted some fancy new blue high pressure high temp hoses and installed permanent oketer clamps. Reinstalled and degreased (again) and now I'm all set. 18 quarts of oil and $350 later...I'm installed the way it should have come from the beginning.
.....Jesus Christ..... yeah it's a huge over sight not putting clamps on, or even mentioning that in the instructions. I'm going to look into having custom lines made. So I don't have to worry about going through this again in the future.
Freeman is offline   Reply With Quote
Old 08-06-2014, 09:14 PM   #1878
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
What do these fittings look like? Freeman, your pictures that guy quoted still dont work
Sellout is offline   Reply With Quote
Old 08-06-2014, 09:18 PM   #1879
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Originally Posted by KraftWerks View Post
@Freeman - The line and fittings are rated to up to 250psi without a clamp. You should not have any issues with these while running without clamps.
Proven otherwise - please revise your kit before sending more out. Not trying to be an ass I just don't want other to go through what we had to. Luckily no perm. damage was done.
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Freeman (08-06-2014)
Old 08-06-2014, 09:22 PM   #1880
Freeman
Freeman's Avatar
Yeah, fixing the pictures hasn't been too high on my priority list. KW has the pictures. I can guarantee they aren't as juicy as people think.
Old 08-06-2014, 09:27 PM   #1881
nlowell
nlowell's Avatar
Size:  240.0 KBName:  ImageUploadedByTapatalk1407374758.888160.jpg
Here are the new hoses I purchased for the fittings - professionally installed. They said the lines should have never shipped separate from the fittings as they require a special hydraulic press tool to properly install.
The Following 2 Users Say Thank You to nlowell For This Useful Post:
D-VO (08-07-2014), Freeman (08-06-2014)
Old 08-06-2014, 09:30 PM   #1882
Freeman
Freeman's Avatar
That's what I was thinking. How much did the new lines run you?
Old 08-06-2014, 09:47 PM   #1883
nlowell
nlowell's Avatar
$40 for the hoses.
$150 in oil (18 quarts)
$90 in labor (tool usage and some assistance)
$20 in degreaser
$40 in Uber charges
6 hours of unexpected time off
Old 08-06-2014, 10:41 PM   #1884
CSG Mike
CSG Mike's Avatar
Attachment 87317Attachment 87318
Those are pretty
Hopefully there's no unseen long term damage from the oil lines popping off.
Old 08-06-2014, 11:07 PM   #1885
nlowell
nlowell's Avatar
Those are pretty
Both times the car was shut off instantly when the lines blew so I'm fairly confident that the car is fine. I'm now questioning the SC oil lines. What kind of pressure do those see? Are the spring clamps enough?
Btw, I'm loving the KW SC kit and the power! It's a shame this happened with the oil cooler because I'm really happy with the rest!
I'm so paranoid after the brake lines though that I keep thinking I hear other noises.
For instance, after a WOT run I hear a flutter at cruise speed. It shouldn't be the bypass because I'm only running 3k or so and not varying speed. The flutter increases with RPM. It's almost like a belt or pulley flutter noise but the belt is taught and the pulleys are spinning true. I'm going to have Mike at Infamous check everything over tomorrow just to be sure
Old 08-06-2014, 11:23 PM   #1886
Poodles
Drives: 2015 Series.Blue
True push-lok (or loc) hose and fittings shouldn't have these issues...
Old 08-07-2014, 08:18 AM   #1887
Sellout
Mr. Cranky Pants
Sellout's Avatar
Only thing I can think of is maybe the hose that was shipped out isn't correct for the application and expands a little too much under pressure. Obviously the push-lok hose has to stay tight as hell to keep it from flying off those fittings under pressure.
Here's what Parker says in the push-lok manual
Caution: Push-Lok fittings will
properly grip Push-Lok hose
only when pushed all the way
in with the cut end of the hose
completely concealed by the
yellow plastic cap.
Sealing integrity may be damaged
by using exterior clamps.
I'm sure you've got to try pretty hard to get that hose shoved into place properly...
Old 08-07-2014, 09:38 AM   #1888
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Best use of Uber I have seen yet.
Old 08-07-2014, 09:43 AM   #1889
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Attachment 86727Attachment 86728
That's all I got for now
If you need me to snap some more I can try
Also the instructions don't mention it, but clamp the ends of the lines. Otherwise lines will pop off....
Did you loose a lot of Rotrex Oil? I only have a little bit left over the install. Darn oil ain't cheap.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-07-2014, 09:50 AM   #1890
Freeman
Freeman's Avatar
I lost none, the oil cooler I was taking about is the engine oil cooler. Now engine oil..... yeah I lost a lot.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
