Old 08-06-2014, 01:22 PM   #15
Racecomp Engineering
Originally Posted by themajesticone View Post
What do these charts tell me in relation to springs rates? Is there any correlation? I am learning...
The first chart displays the amount of force the shocks generate vs. the piston speed of the damper. Not vehicle speed, piston speed. So if the shock is compressing at 1 inch per second, the shock is generating a force of approx 25 lbs. That's the top half of the chart...compression. Rebound or extension is the bottom half with negative force values as the shock is resisting extension.
Lower piston speeds = body roll, higher piston speeds = bumps.
You can use this information to get an idea of how much spring rate the shocks can control effectively. This post talks about that a bit:
http://www.ft86club.com/forums/showp...84&postcount=8
But there's much more reading you could do.
The other 2 charts are just showing the spring rate of the various springs. No direct correlation to the shocks.
- Andy
themajesticone (08-06-2014)
Old 08-07-2014, 04:16 PM   #16
xwd
Originally Posted by CSG David View Post
@dwx Can you tell Lex to contact me back?
Sure I'll try and talk to him tomorrow morning.
Old 08-07-2014, 09:04 PM   #17
CSG David
CSG David's Avatar
Ask him to send me those dyno sheets. Been waiting for awhile.
Dyno Day @ WGP Doug@WGP New England 56 11-09-2012 11:30 AM
Dyno Day @ WGP Doug@WGP NY / NJ / CT / PA 5 09-21-2012 06:42 PM
extended DDPR stock FR-S Dyno testing Illusive Engine, Exhaust, Transmission 5 08-26-2012 10:20 AM
My fr-s on the dyno doriNIGHTS Engine, Exhaust, Transmission 12 06-25-2012 07:32 PM
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
