Old 08-06-2014, 09:50 AM   #1
FR-S Matt
ARP Wheel Studs
So just like most of you, I am getting sick of stripping the stock wheel studs just from working on my car. My back right wheel stud was stripped when I got my last tire rotation and balance, but the one stud that finally stripped already started to become difficult even before that. I don't use any power tools even though the shop did. They're just really cheap. So I'm looking to get an entire set of ARP wheel studs but my question I have is, can I use my Rays close ended lug nuts with these even if they are extended? I've got 18X9.5 +38 offset wheels, so I figure they won't extend out too far, but I want to make sure I don't have to get open ended lug nuts just because of the extended ones.
Anyone with the ARPS confirm they aren't stripping from just removing wheels on a consistent basis? Not too concerned with how they hold up on the track which they are meant for. I'm more concerned with the ability to remove my wheels without having to worry about stripping a bolt all the time.
Old 08-06-2014, 10:38 AM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I think the safe bet is to just purchase some open ended lug nuts and not worry about it.
Someone on here will buy your current lug nuts.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 08-06-2014, 10:45 AM   #3
wparsons
wparsons's Avatar
Without spacers, I think you'll need open ended lugs.
With the ARP studs and RPF1's (17x8 +45 if that matters for wheel thickness) I have about 1/4" of stud sticking out through the Muteki lugs I'm running, which are the long lugs.
http://www.ft86speedfactory.com/mute...black-417.html
If you want better studs that aren't as long, Nismo sells 50mm long studs that fit perfectly.
flickr
Old 08-06-2014, 11:04 AM   #4
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
Ive run ARP studs on my MR2 and also my FRS. And never had any issues with stripping them. They are designed to be stronger than stock.
Alain is offline   Reply With Quote
Old 08-06-2014, 11:06 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
How deep are those lugnuts? R40s barely cover the ARP studs:
Some pics of stud length comparison in the DIY thread: http://www.ft86club.com/forums/showthread.php?t=21563
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
DustinS (11-03-2015), FR-S Matt (08-06-2014), Sportsguy83 (08-06-2014)
Old 08-06-2014, 11:27 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm using Nismo studs and have no problems with my 32mm Leggdura close ended nuts with room to spare.
Actually instead of 1.25 studs why not just go with 1.5 studs as they're less likely to strip.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
FR-S Matt (08-08-2014)
Old 08-06-2014, 12:08 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I've got similar wheel spec, 18X9 +40, and same as Dave ROR, my R40's open ended barely cover the stud.
Get open ended ones.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 08-06-2014, 12:28 PM   #8
FR-S Matt
They aren't too deep. Probably a little over an inch. They're steel close ended with wheel locks.
Swapping to an entire new set of lugs and studs is probably a bit much right now, but I really need to do this in the future. Stripping the stock ones just because I want to work on brakes is a pita.
Hard to pass up the cheap $5 one from Toyota and swap it in.
Thanks for the DIY too btw @Dave-ROR. I ran into the "siezed" hub scenario and had to use bolts in the small holes to get the rotor off. Got that far only to realize the aftermarket stud I got from O'Reilys was too small on the base of it to where it just went directly in the hole and didn't need to be pressed. I really hate doing the rears.
Washer method and hammer... the dirty way. Probably grabbing a ball joint separator so I don't look ghetto as hell beating on my hub with a great looking car.
Old 08-06-2014, 12:31 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The factory studs are fine. I never had issues with them and had about 6 month's worth of on/off before I swapped out for ARPs. Most of the time they get stripped due to thread contamination.
Went ARP only because I sometimes run a 15mm spacer on my RE30 wheels. Even with a 15mm spacer I still needed an open-ended lug on the studs.
As for ARP, no issues with using it. I swap wheels probably 4-5 times a month.
-alex
Old 08-06-2014, 01:45 PM   #10
wparsons
wparsons's Avatar
SR48's look to cover about the same, no close ups of my wheels but it looks nearly identical.
If anyone wants to run 12x1.5, get the EVO VIII studs, same length and knurl diameter as the "proper" ones, just a different thread pitch.
I only went with 12x1.25 because I didn't order ahead and the store didn't have any open ended 12x1.5 lugs in stock.
flickr
Old 08-06-2014, 06:08 PM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Just run cheap open ended pepboys ones. That's what I did until I got the R40s for cheap. I think the steel ones were $20 at pepboys.
I use the dirty way sometimes on my other cars, and did on the BRZ some but wanted to document the proper way
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-17-2014, 08:54 AM   #12
chris86
Drives: 2013 Dark Gray BRZ
Is this picture with no spacers or anything? I've been trying to find pictures of the wheels on this car without spacers but with the ARP studs.
chris86 is offline   Reply With Quote
Old 09-17-2014, 11:08 AM   #13
wparsons
wparsons's Avatar
^^ Mine look VERY similar to that with 17x8+45 RPF1's, ARP studs and Muteki SR48 lugs, no spacers.
flickr
Old 09-17-2014, 11:22 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No spacers. I only own spacers so the OEM wheels will fit over the brakes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
A warning about wheel studs post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-05-2015 03:07 PM
WTB: ARP extended wheel studs mikep Canada Classifieds 2 05-22-2014 01:00 PM
non-extended wheel studs BadCompany235 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-14-2013 08:02 AM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
