Old 08-02-2014, 04:00 PM   #141
CSG Mike
CSG Mike's Avatar
Originally Posted by LoCo View Post
How can anyone say "depressing" when you're told about costs...
NA power costs money. More money than anything. And reliability is poor when pushing limits - RPM kills engines slowly, even when working correctly.
What @CSG Mike said about building - pistons rods bearongs crank valve springs and cams: that's BASIC. It's nothing special. It's a starting point for a real engine... There's oh so much more where you are able to spend money to gain that 1,2 or 3hp... But in the end - if you're the breed of person that loves NA - it's all worth it. All of it. I've sat in a 270hp NA S2k... Fuck yes!
So I'm looking forward to NA tuners developing something useful, if not - I'll probably start designing some cams sooner or later.
All that takes is cams and a tune... but the motor is a ticking time bomb. We're talking low double digit race hours. It'll make 285 if you delete the cat too.
A 2.4 stroker F2xC will be good for ~50 hours and make ~300hp, but now you're looking at a 30k engine build.
On the other hand, a solid 25% of my motor's 130k+ in my s2k has been over 6000 RPMs.
Old 08-05-2014, 04:13 PM   #142
Griever423
Drives: 2020 BRZ PP
If you want fast for cheap, the C5Z is the way to go. I can guarantee that you'll be using the power as a crutch though.
How many videos have you seen where the vette driver won't go WOT until they're pointed straight *after* the corner? How many of these drivers smoothly transition from partial to full throttle?
These are skills that you most likely will not learn in a vette.
I learned how to drive in a 5.0 Mustang. You can learn with big power, long as you have good instructors and can listen.
Griever423 is offline   Reply With Quote
Old 08-05-2014, 04:22 PM   #143
troek
troek's Avatar
Drives: 2012 Toyota 86
Stock power?(referring to mikes s2000)
troek is offline   Reply With Quote
Old 08-05-2014, 07:27 PM   #144
CSG Mike
CSG Mike's Avatar
Hrm?
Old 08-05-2014, 07:29 PM   #145
CSG Mike
CSG Mike's Avatar
You realize your foxbody made... 205hp, assuming it was a later model...
Old 08-05-2014, 10:14 PM   #146
troek
troek's Avatar
Sorry, referring to you saying u put 130k on ur s2k motor. Id love to see that kind of longevity on the fa20 with a slight tune.
Old 08-05-2014, 10:23 PM   #147
CSG Mike
CSG Mike's Avatar
It's had various tunes over the years, but I'm back to stock + test pipe at the moment.
I played with higher redlines, but the engine showed exponentially higher wear at anything more than 100 rpm higher than stock. What really hurts is that the F22C continues to make more power as you increase redline, whereas the FA20 doesn't, making me want to run a higher redline....
Old 08-05-2014, 10:54 PM   #148
troek
troek's Avatar
Yeah, my r32 made more power the higher you went, it was addicting lol. Do you run you fa20 on stock tune?
Old 08-05-2014, 11:02 PM   #149
gramicci101
Off Topic
Short of tearing it apart for inspection, or at least borescoping the block, how can you tell?
Old 08-05-2014, 11:14 PM   #150
CSG Mike
CSG Mike's Avatar
Used oil analysis had higher iron wear, which in the S2000, is the cylinder sidewall. Makes sense; this is where the most stress is at high RPMs.
Old 08-05-2014, 11:15 PM   #151
CSG Mike
CSG Mike's Avatar
We're boosted with the Jackson Racing supercharger.
Old 08-05-2014, 11:28 PM   #152
troek
troek's Avatar
jealous
The Following User Says Thank You to troek For This Useful Post:
CSG Mike (08-06-2014)
Old 08-06-2014, 02:20 PM   #153
Griever423
Drives: 2020 BRZ PP
New 5.0. Sorry, should have clarified.
The Following User Says Thank You to Griever423 For This Useful Post:
Old 08-06-2014, 03:37 PM   #154
CSG Mike
CSG Mike's Avatar
The new 5.0 is a really forgiving platform... you can do all sorts of stupid stuff with the power and recover. The Mustang's wheelbase is long, giving it a large moment of yaw inertia, so it's much easier to recover than one of the twins. Also, you have enough power available to just spin both rear tires if needed, whereas the twins can't really do that.
FS: go fast track tires for your FR-S! l8apexr Canada Classifieds 2 10-02-2013 06:28 AM
Track Day @ Mid America Motorplex - Fast Fridays enigma Rocky Mountains / Great Plains 1 08-24-2013 12:00 AM
BRZ in Born To Race Fast Track Trailer switchlanez BRZ First-Gen (2012+) — General Topics 34 06-28-2013 07:21 PM
A FR-S with star spec is about as fast as a (fill in the blank)_____ at the track? stealth1 Tracking / Autocross / HPDE / Drifting 15 10-18-2012 05:46 PM
Aug Fast Track out. feldy Tracking / Autocross / HPDE / Drifting 27 09-12-2012 09:03 AM
