Old 08-03-2014, 12:54 AM   #421
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Remove the weather stripping as posted in a picture a few posts ago. Then remove the two small pieces bolted to the corners of the hood. Mine are gone so I can't take a picture of them. If your not ready to cut anything up remove the half moon looking piece behind/above the battery on a LHD car. This will let hot engine bay air into the cowl. It will have to escape either out through the small holes in the cowl (this is where I made big holes) or if you turn you hvac to external air it will suck air out of the engine bay.
Old 08-03-2014, 03:21 AM   #422
MyRx
MyRx's Avatar
Originally Posted by sw20kosh View Post
Can you please point out these pieces to remove in a picture? I am at the track in 100+ deg ambient and I can't go 2 hot laps before having to cool down. I want to try this tomorrow (2 day event).
They are on the corners of the windshield/rain guards. They pop right off without any tools needed - just be gentle on removing them. Once removed, you can see the hood struts hence an opening to the engine bay.
Removing the weather stripping may also help. So will shimming the lower bolts of the hood/hood struts. Shimming (putting washers) can create a gap similar to removing the weather stripping.
But of course all these recommendations are temporary use only. I wouldn't trust these simple aides as perm to reduce heat. GL!
Old 08-03-2014, 08:45 AM   #423
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
So who wants to fab up an air conditioning assisted intercooler?
www.iosrjournals.org/ccount/click.php?id=2616
pixel67 is offline   Reply With Quote
Old 08-03-2014, 01:24 PM   #424
Reaper
Reaper's Avatar
Drives: violent
Went for a hard drive in the mountains and forgot to log. Whenni got home i used my pyrometer. my intake manifold/throttle body?112*f. The roof of my car? 138*f. Engine bay was noticeably cooler than other cars out today and I was making the most power and with a front mount turbo. No oil cooler and factory radiator with ducting and 8 at pan. It was hot out today too. North georgia.
Old 08-03-2014, 01:27 PM   #425
mike the snake
VERY interesting!
I've always wondered if this were possible.
Old 08-03-2014, 01:45 PM   #426
charged86
charged86's Avatar
Originally Posted by zoth View Post
Hoping somebody will make a skid plate like this for our cars.
GrimSpeed are you there ;-)
you could have the stock one louvered
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-03-2014, 01:54 PM   #427
mike the snake
OR, you could modify your skidplate like I've done.
I also added a rubber strip to trip the air and cause a low pressure area behind the hole, which helps to draw hot air out.
The Following User Says Thank You to mike the snake For This Useful Post:
AJPG (08-07-2014)
Old 08-03-2014, 04:20 PM   #428
Reaper
Reaper's Avatar
Drives: violent
yup. My splitter has this on it in a similar location. My engine bay is colder than my roof on a hot day. I still don't understand how people are having overheating problems.
Old 08-03-2014, 05:15 PM   #429
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
IR thermometer?
Sellout is offline   Reply With Quote
Old 08-03-2014, 06:04 PM   #430
Reaper
Reaper's Avatar
Drives: violent
Yeah I was trying to type it while doing something else and auto correct wanted to say pyrometer so I just went with it.
Old 08-03-2014, 08:39 PM   #431
sw20kosh
Drives: 2013 Black FR-S
Removing the weather stripping and plastic pieces did not allow me run cooler on track. And ambient was cooler today.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
EAGLE5 (08-03-2014), rb6freak (08-03-2014)
Old 08-03-2014, 10:30 PM   #432
Reaper
Reaper's Avatar
Drives: violent
Time to holesaw. Is your radiator sealed in with foam on the sides? Otherwise the air just moves around it.
Old 08-05-2014, 04:38 PM   #433
charged86
charged86's Avatar
Originally Posted by FullBlown View Post
The shrouds are done. There will be an option for SPAL 12" fans as well.
would this setup fit a koyo?
Old 08-05-2014, 07:22 PM   #434
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
Check out:
http://www.killerchiller.com
romin is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
