#421 |
in orbe terrum non visi
Drives: violent
Remove the weather stripping as posted in a picture a few posts ago. Then remove the two small pieces bolted to the corners of the hood. Mine are gone so I can't take a picture of them. If your not ready to cut anything up remove the half moon looking piece behind/above the battery on a LHD car. This will let hot engine bay air into the cowl. It will have to escape either out through the small holes in the cowl (this is where I made big holes) or if you turn you hvac to external air it will suck air out of the engine bay.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#422 | |
Removing the weather stripping may also help. So will shimming the lower bolts of the hood/hood struts. Shimming (putting washers) can create a gap similar to removing the weather stripping. But of course all these recommendations are temporary use only. I wouldn't trust these simple aides as perm to reduce heat. GL!
#423 |
Drives: 13 Asphalt FRS AT
So who wants to fab up an air conditioning assisted intercooler?
www.iosrjournals.org/ccount/click.php?id=2616
#424 |
Drives: violent
Went for a hard drive in the mountains and forgot to log. Whenni got home i used my pyrometer. my intake manifold/throttle body?112*f. The roof of my car? 138*f. Engine bay was noticeably cooler than other cars out today and I was making the most power and with a front mount turbo. No oil cooler and factory radiator with ducting and 8 at pan. It was hot out today too. North georgia.
#425 | |
VERY interesting!
I've always wondered if this were possible. Quote:
#426 |
you could have the stock one louvered
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#427 |
OR, you could modify your skidplate like I've done.
I also added a rubber strip to trip the air and cause a low pressure area behind the hole, which helps to draw hot air out. |
| The Following User Says Thank You to mike the snake For This Useful Post: | AJPG (08-07-2014) |
#428 |
Drives: violent
yup. My splitter has this on it in a similar location. My engine bay is colder than my roof on a hot day. I still don't understand how people are having overheating problems.
#429 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
#430 |
Drives: violent
Yeah I was trying to type it while doing something else and auto correct wanted to say pyrometer so I just went with it.
#431 |
Drives: 2013 Black FR-S
Removing the weather stripping and plastic pieces did not allow me run cooler on track. And ambient was cooler today.
#432 |
Drives: violent
Time to holesaw. Is your radiator sealed in with foam on the sides? Otherwise the air just moves around it.
#433 | |
would this setup fit a koyo?
#434 | |
Drives: BRZ, STI, 535, Tiffin Allegro
http://www.killerchiller.com |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
