Old 08-05-2014, 08:27 AM   #43
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
How are the rc6's when cold? My track pads on my bike are a death trap without heat in them.
Old 08-05-2014, 08:45 AM   #44
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Do you like the RC6 as much as I do?
They are amazing so far though I've only used them at Atlanta Motor Speedway so far which isn't very hard on brakes. Road Atlanta this weekend should be a better test.
They bite okay when cold, I wouldn't call them deadly, but after tracking with them once they are ridiculously loud against cold rotors to the point where it's embarrassing on the street, lol. They also don't have painted backing plates which is good since there's nothing to burn off but the pistons don't grab them at all so you get clunk noises with pedal application at low speeds and they also clank in the calipers over bumps. Because race car
The Carbotech Bobcat street pads do not make any noises at any temperatures after bedding.
Old 08-05-2014, 08:51 AM   #45
Reaper
Reaper's Avatar
Drives: violent
I'm not to concerned with noise.
In the two wheel world I use ebc sintered pads for street and only use carbon on the track. The carbon tend to "un bed" themselves on the first long downhill corner leaving my house in the morning when cold and never quite recover before I get to work since its mostly uphill from there. I had to re bed them on my rides home!
The Following User Says Thank You to Reaper For This Useful Post:
CSG Mike (08-05-2014)
Old 08-05-2014, 08:54 AM   #46
Reaper
Reaper's Avatar
Drives: violent
Csgmike recommended ap s100 for the street. Who's running them?
Old 08-05-2014, 09:26 AM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They are OK. They aren't the best pads I've used cold and aren't the worst. They are LOUD though and since they are sintered pads are actually smaller than normal so on the BRZ with no anti-rattle provisions they move around a bit.
I've driven them cross country (well south to north and back..) a few times on my track car and never felt unsafe at all. They actually aren't even loud on the track car, just the BRZ.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 09:31 AM   #48
buddy32
Drives: WRB Subaru BRZ Limited
I was kind of in the same situation. I went with the AP sprint kit and figured I'd grow into them. I'm currently on XP10s at the track and 1521s on the street all around. I'll move on to XP12s when these 10s are done.
buddy32 is offline   Reply With Quote
Old 08-05-2014, 09:49 AM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
As much as I normally agree with Mike... I wouldn't run the S100s on the street. They are decent pads but too loud. Get one of the pads that others here have had good luck with being quiet.
I still run the S100s myself and I think they'd last forever on the street but the noise is a bit annoying after awhile.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 10:10 AM   #50
WWEVOX
Drives: White Lancer Evolution X
Is there something wrong with the Brembo GT kits? I hardly ever see those mentioned in these forums, good or bad. But some of the mentioned kits are definitely in the price range.
WWEVOX is offline   Reply With Quote
Old 08-05-2014, 10:14 AM   #51
Model Citizen
Lacking brains
Drives: frz
price is a pretty good place to start.
at the end of the day if you can justify dropping 5k+ for brakes on a 25k car than you probably had enough brains to buy a better car to start with
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 08-05-2014, 11:04 AM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've installed and used a $10k brake setup of Brembo race bits (calipers/rotors) and a prototype Ford Racing booster and BMC and they were fantastic bits though. However, like AP, Brembo makes a bunch of different parts. Without having touched the GT kits, I'd imagine that they are similar to the AP Formula stuff quality wise.
Spec wise, they are frankly too big for the car for most users (I'm focused purely on function here). I haven't looked at consumables but that all plays a role in selecting brakes for your car. Price wise, I don't think they are close.. isn't the GT kit ~$3,500? Compared to the Essex kit at $2,100.. or the Essex Endurance at $2,600. (to be fair that was the first google price I saw, I didn't go shopping for them).
My motivation for a BBK was more or less the following: I destroyed the OEM rotors quick and boiled fluid (good fluid, not the OEM crap, which I did boil as well but...).
The factors in picking a BBK were more or less the following:
-Functionality in terms of thermal mass and cooling with my target being as SMALL of a brake system as possible to meet my needs with room for reasonable growth in power (due to temps in Florida, tracking FI cars isn't something I prefer to do, at least not aftermarket FI cars) as well as feel/modulation
-Component quality
-Consumable cost
-Weight savings
Going with HUGE rotors is just adding weight on most of the cars here.. without a need to do so.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ATL BRZ (08-05-2014)
Old 08-05-2014, 12:49 PM   #53
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
The fact that they are 14" means that aren't a serious consideration beyond looks. Unless you like slowing your car down... when you aren't using the brakes.
That would be a true statement IF they weighed more however, they do not! In fact the entire front and rear kit weighs in 3lbs less than the stock system. That's a whole lot more stopping power and less weight to boot.....
Not to mention both the OP and myself have over 400whp so being slowed by rotational mass isn't as much of a concern.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 08-05-2014, 01:01 PM   #54
CSG Mike
CSG Mike's Avatar
Only to reduce your up front cost. Remember, spending the $25 on race pads and paying for street pads is ultimately the better deal, in which case I'd recommend the Carbotech 1521.
ATL BRZ (08-05-2014), Reaper (08-05-2014)
Old 08-05-2014, 01:03 PM   #55
CSG Mike
CSG Mike's Avatar
Nothing except a higher cost. You can't go wrong with the Brembo GT kits, but like any other painted caliper, the paint turns an ugly brown if you actually track it and get a lot of heat into it.
Old 08-05-2014, 01:16 PM   #56
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
But Wilwood calipers do flex more than APs. Talk to some dirt track guys, they can show you some Wilwood tacos...
interesting, this is the first time I am hearing this problem with Wilwood calipers and I've spoken with many track guys with different setups I don't see as many FRS/BRZ owners with BBKs though.. Can you provide a link/more info about this? Is this with their steel pistons or thermlock? I wonder if this is a car specific issue or a mismatched kit issue
after certain amount of time and heavy use every caliper will flex for sure..
many makers claim that the Monobloc design tend to flex even more than the 2 pc designs (unless it's an F1 superior race brakes )
How is that so? Larger rotors in general (with same width) should provide better thermal efficiency which ultimately affect the consistency ..then again I am not talking about the stopping distance ...but in fact even the "stopping distance" is effected after certain temps
link to source:
http://zeckhausen.com/Testing_Brakes.htm#Summary
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
DAEMANO (08-05-2014)
Deciding on LCA's. natesparxxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 08-17-2014 01:33 PM
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 05:10 PM
Deciding on an exhaust JohnAyySays Engine, Exhaust, Transmission 32 12-28-2013 11:31 PM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 03:49 AM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 03:53 PM
